2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum Regional Forums USA - NY / NJ / CT / PA Centra PA
      09-10-2025, 01:38 PM   #1
pmcmtnbkr
pmcmtnbkr's Avatar
179
Drives: BMW M235I
Centra PA
I am in central PA and need some help with my 2015 m235i. I have a bad abs pump I am replacing it and swapping the good control module from my existing abs unit I was reading up on bleeding the system and I have seen many posts with bleeding with bmw software dose anyone have the ability to do this that would be willing to help me out if needed I am going to try pressure bleeding the system and see how it goes
      10-03-2025, 07:41 PM   #2
T67Regal
Got sleeper?
Drives: 1999 Buick Regal w/T67 build
2020 BMW M240ix  [0.00]
also Central PA
Hi. Also from Central PA.
Just saw your post, But I don't know how to replace an ABS pump. Hope you fixed it.
I don't see much activity from any PA BMW owners.
      10-14-2025, 02:27 PM   #3
pmcmtnbkr
pmcmtnbkr's Avatar
179
Drives: BMW M235I
You are the first to respond to this post. I was able to get it fixed found a use ABS pump out of a salvage car that was the exact same part# swapped over the abs control module and had the thing functioning except for the ee prom was lucky had a friend that has a retired master BMW tech working for him it took him less than 2 mins to read out the module and restore the corrupt data. I prompted me to by a good scan tool so when I change over the rebuilt ABS module I can fix the problem myself
      10-15-2025, 08:52 PM   #4
T67Regal
Got sleeper?
Great. Seems like you found the right person for read/restore the data.
I just joined a couple weeks ago.
Are there any BMW clubs in central PA?
