BMW 3-Series (E90 E92) Forum
Low Oil Pressue Warning + Stiff Brake Pedal
01-30-2024, 02:08 AM | #1 |
Rep 1
Hi all,
Recently, I was driving to work (at low speeds on the freeway) and went to hit the brakes and the pedal would barely budge. I thought my hydroflask rolled under it at first. I tried to then pump the brakes and that didn't really help. I made it off the freeway to check the brake fluid and it seemed to be within normal range. Moments later I got a red oil light on the instrument cluster and the engine started to make strange noises. I shut down the engine and had it towed home. Thus far I've tried replacing the oil pressure switch and then drained the oil and replaced with new fluids to ensure an adequate level. Does anyone have any insight on this? I have not experienced this with any of my other E90s. Serpentine belt is intact and not frayed. Only had inlet and outlet VANOS codes. Both solenoids have since been replaced. Vehicle is a 2009 328i xDrive N51 |
01-30-2024, 08:02 AM | #2 |
Rep 502
Check your brake booster hoses leading from the vacuum pump to the booster. Mine was severely cracked and leaking air.
The section of hose by the brake booster is very hard to get to. With small hands, you can unscrew the abs pump and give yourself a tiny bit more room. Last edited by Suvorovo; 01-30-2024 at 08:18 AM.. |
01-30-2024, 11:03 AM | #3 | |
Rep 4,071
George |
