M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > 295/30-18 Fitment Question
      01-25-2024, 07:19 PM   #1
cme
cme's Avatar
229
Drives: 22 M3 xD Comp
Hi,
Have a set of Apex 18" staggered going on car. 9.5 et28 fr and 10.5 et40 rr.
Has anyone fitted the 265/35 front and 295/30 rear Cup 2's. Any issues with the shorter rear tire as it is a 30 aspect vs 35.
Thanks,
Chet
72 2002tii | 90 E30 M3
13 E92 M3 | 16 F87 M2
20 F87 M2 CS
22 G80 M3 xD Comp
      01-26-2024, 02:48 PM   #2
medphysdave
medphysdave's Avatar
Drives: M2 CS | 85 of 592
Not a cup2 but I've fit 295-18-30 RE71rs on rear with 41 offset. No issues. 10.5 wheel.
      01-26-2024, 09:11 PM   #3
cme
cme's Avatar
229
Ty
      01-26-2024, 09:18 PM   #4
medphysdave
Room to go wider in my opinion
      01-27-2024, 08:58 AM   #5
ZM2
Drives: 2017 LBB M2
I’ve run 305/30/19 19x10.5 ET45 RE71R and 305/35/18 18x10.5 ET40 Toyo RR in the back on a lowered car, so could def go wider than 295 on 18s. Altho, not many tire choices for 305 in 18s, just the RR.
I personally don’t like the feel of a shorter rear tire, but guessing most people wouldn’t notice. On the street, the TC can give you fits around corners until it learns your setup change and the shorter rear.
      01-27-2024, 09:15 AM   #6
medphysdave
Keep in mind if you're still at stock ride height, like mine is, it will look like a monster truck with the 30 18s. Functions great, but asthetically it looks like poop.
GenXG87199.50
      01-27-2024, 03:23 PM   #7
OG Shark
BimmerPost Supporting Vendor
OG Shark's Avatar
4778
Drives: Angry
Having a smaller diameter rear tire vs the front can randomly trip up the DSC and cause it to kick in. I would run a 295/35/18 on the rear and yes they can fit. At worst try to keep them the same diameter (running square setup) or rear a bit larger diameter as per the stock front:rear ratio if you want to avoid this potentially happening. Otherwise just know it might happen.
Andrew2180.00
      01-27-2024, 03:28 PM   #8
medphysdave
Does it fix things to run dsc off? Next track event I'm planning to run no nannies. Saving for Nitrons, so probably not until next Sep or Oct
      01-27-2024, 07:08 PM   #9
jwr9152
Drives: M2 Competition
I run 275/35/18 with 295/30/18 with mdm and haven't had any issues. Only problem I've had is running out of gear to close to the braking zone to shift. Will run 295/35/18 on those tracks.
      01-27-2024, 07:26 PM   #10
medphysdave
I experienced the same thing at the last track day.
      01-27-2024, 07:33 PM   #11
cme
cme's Avatar
229
Went with 265/35 and 295/35 Bridgestone’s. Sizing off the Apex fitment info.
Hopefully works without issues.
Thanks.
Chet
GenXG87199.50
      01-27-2024, 08:46 PM   #12
OG Shark
OG Shark's Avatar
4778
Drives: Angry
Yes DSC off and it will not happen. With a smaller diameter in the rear the car can get tripped by the higher number of rear tire revs than it expects based off what the front is doing and trip the DSC very momentarily. With MDM giving more leeway in slippage it doesn’t happen as much as with DSC on. This happens commonly but not saying it will absolutely happen moving right to that stagger - just something to be aware of.
      02-03-2024, 10:02 AM   #13
Westersund
Westersund's Avatar
Sweden
511
Drives: BMW
I went with Yokohama Advan A052 265/35/18 up front and 295/35/18 in the rear, 10x18" ET 28 up front and 11x18" ET 44 in the rear. Rubbed through the rear wheel liner because of Tiergarten at the Ring but that was with stock dampers/lowering springs, 3 people in the car and pretty much full tank. With slightly stiffer suspension and not so much dead weight it will be fine. Looks the business as well. Went with this setup to be able to use MDM at the Ring without tripping the DSC so easily.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87
      02-03-2024, 01:32 PM   #14
GtSport
Drives: F87N & F30
80% of the guys with BMW M2 on Nordschleife are running with Nankang AR-1 295/30/18 tires in the rear.
      02-15-2024, 08:04 PM   #15
GenXG87
GenXG87's Avatar
200
Drives: 2023 M2 & 2018 M2
2023 BMW M2  [8.80]
2018 BMW M2  [9.75]
Thanks.
Chet
I just installed 275/35 and 295/35 Bridgestone's. Car is stock suspension still. No fitment issues. Will need some negative camber up front when it is lowered though. The rears could use spacers to flush them up.
2023 G87 ///M2 6MT - Ohlins R&T, Vorshlag Camber Plates, Fall-Line Rear Toe Arms, APEX VS-5RS, Conti Extreme Contact Force, Pagid RSL29, BM3 Stg2, MAD CAI, IRL single mid-pipe
2018 F87 ///M2 DCT - MPE, BM3 stg1, MAD Intake, xHP stg2, M4GTS Diff/Steering, Euro MDM, Ferodo 3.12, APEX VS-5RS, Potenza RE-71RS, Cobra Nogaro next mods: Ohlins R&T, Vorshlag Camber Plates, SPL parts
IG: Follow ME: genXg87
      03-08-2024, 02:02 PM   #16
cme
cme's Avatar
229
My rear 295/35–18 RE-71R’s do rub slightly on big dips inside left side rear finder. I checked and there is nothing to roll there as inside lip is tucked in already. Maybe a smidge more rear camber will help.
Chet
m2
