10-30-2023, 12:15 AM | #1 |
Rep 3
bimmerlink sensor name help
Hi all,
I’m not sure the sensor names are chosen correctly. could anyone help me with the sensors that I want to record? thanks. 1)boost pressure actual(pre-throttle)(hPa) 2)boost pressure(Target)(hPa) 3)ambient pressure(hPa) 4)MAP(Manifold absolute pressure)(hPa) 5)WGDC(Wastegate Duty Cycle)(%) 6)accelerator pedal(%) 7)throttle angle(%) 8)ignition timing 1(deg) 9)ignition timing 2(deg) 10)ignition timing 3(deg) 11)ignition timing 4(deg) 12)ignition cylinder target(deg) 13)ignition timing correction 14)knock detected 15)lambda(AFR) 16)lambda actual(AFR) 17)IAT(intake air temperature) 18)exhaust gas temperature after catalyst(C) 19)engine speed(rpm) 20)gear actual 21)vehicle speed(km/h) currently, I chose these sensors in the Bimmerlink app. |
