TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Africa > Spare Wheel
Reply
      01-17-2009, 02:54 AM   #1
mommet
mommet's Avatar
Drives: E90 325
Spare Wheel
How many of you guys have bought the space saver spare wheel
I've bought the one in the bag and it takes up space in the boot when travelling with luggage. Tried placing it under the carpet in the boot but doesn't fit. Any ideas??
Also, under the carpet in the boot, I found a wiring. the end is covered in a velcro bag. Has a buch of connectors etc on the ends. whats this for...
07 E90 325 sports pack - Silver
Ex's
05 Golf 5 Gti - Silver
04 Jag X-type 3litre - Silver
00 Corolla RXi - Silver
      01-19-2009, 01:07 AM   #2
rennzport
Drives: bmw
what did they charge for the space saver?
      01-19-2009, 02:19 AM   #3
Menno11
Member
Menno11's Avatar
South Africa
35
Drives: 320d
2005 320d  [0.00]
The wires are the harness for the factory amps if you have the Logic 7 sound system. If you lift up the plastic container on the left behind the wheel arch you will find a second harness for the CD changer and the second amp for the subs.
      01-19-2009, 06:55 AM   #4
mommet
mommet's Avatar
Drives: E90 325
so can one connect any amp or cd shuttle to these or only one from BMW
paid approx R2k for the spare jack etc
need it. coz i usually only use the car for long distances.
got +- 24000km. its a 2007 model
Ex's
      01-19-2009, 10:04 AM   #5
Menno11
Member
Menno11's Avatar
South Africa
35
Drives: 320d
2005 320d  [0.00]
The harness is a PnP harness, but if you have the standard Professional radio, it will have to be reprogrammed to accept amplification for the speakers. Only if you have the Logic 7 can you replace the existing amps with aftermarket units.
Your car looks very familiar, do you work at CHB?
      01-20-2009, 07:47 AM   #6
mommet
mommet's Avatar
Drives: E90 325
I'm in jozi
I wholesale and retail baby stuff
Ex's
      05-22-2009, 10:01 PM   #7
kurtdaniel
Drives: bmw
the spare wheel is very convenient for me.....
      06-16-2015, 01:21 AM   #8
alstonalvin
Drives: 2002 Ford E350
Spare Wheel
Older models where the mag wheel versions came with a space-saver and the steel wheel ones came with a full size steel spare had a "podium" or "bandstand" in the boot where the wheel poked up through the floor, and the carpet was made to cover it. You might need to make something like this. Spare wheels are supposed to secured by a mounting bracket or device for RWC, as they can become a projectile in an accident. Im not sure anyone makes one for the inside of a subaru, although I have seen externally mounted spare wheel carriers (swing away) on them.
Reply
