2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning Oil Starvation B58 vs N55
      02-19-2023, 05:58 PM   #1
ggggbmw
Drives: 2017 M2 Manual
I currently have a M235 with the N55 engine. There is a lot of talk about how the N55 is prone to oil starvation when the car is subjected to high lateral loads, such as long corners on track. I track my car, and l purposely run a narrow-ish tire just to avoid some of the lateral load, along with making sure oil level is at or just above full fill. But I still have a mortal fear of spinning the bearings some day.
The B58 apparently does not have the oil starvation issue in track use. My question is, WHY? What is so different about the B58 in a plain or M-Lite BMW that it doesn't have the same reputation for oil starvation?
      02-19-2023, 06:12 PM   #2
jzeiler4
jzeiler4's Avatar
375
Drives: 2021 M240i xDrive F23
B58 is closed deck, N55 open deck. Intercoolers are different N55 is air cooled B58 is liquid cooled. N55 has cam chain in front B58 has it in the rear. There is just not much in common between the two engines except displacement.
      02-20-2023, 07:03 AM   #3
n55david
n55david's Avatar
1703
Drives: 17 m240i, 20 x4m, 15 X3 x35i
2015 X3 x35i  [10.00]
2017 BMW m240i xDrive   [10.00]
2020 BMW X4M   [10.00]
They did make a few changes.. I believe better oil returns, larger deeper area around the pump pickup and it has a windage tray that the n55 doesn't have.. oh and different rod bearing setup. Whether it's enough or not, who knows but there are less failures..
You didn't even try to answer the question.. just wanted to point out that the engines are different?
2017 m240i xDrive 10.40@133mph w/bm3
2020 x4m 10.63@130.39mph w/bm3 ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: n55david - Youtube: @ n55david For videos or Racing etc
Cos270612.50
ggggbmw543.00
      02-21-2023, 07:32 PM   #4
ggggbmw
So there is a windage tray in the B58. I had not heard that before.
That would help a lot. That and a revised pickup are the key things the N55 in the M2 has that the M235 does not. But sadly it is stupid expensive to retrofit.
n55david1702.50
      02-21-2023, 07:35 PM   #5
n55david
n55david's Avatar
1703
Yeah I'm not sure I've seen it mentioned but I seen one in a b58 tear down video
      03-21-2023, 11:01 AM   #6
mecheng77
mecheng77's Avatar
Drives: 2007 328i / 2014 M235i
  [0.00]
  [0.00]
I also have the same concerns, not sure if I will track the car.
This channel has great videos, turn on English translation, here is a bit of a comparo, B58 to N55
