BMW 3-Series (E90 E92) Forum
KW V3 (xi) settings
01-08-2009, 10:02 AM | #1 |
Rep 6,805
KW V3 (xi) settings
I've gone through the xi subforum and found two threads about the KW V3 xi owners' settings.
By Sparkplug: http://www.e90post.com/forums/showthread.php?t=167598 By longodj: http://www.e90post.com/forums/showthread.php?t=164989 Any other folks here can provide some feedback and recommendations for the setting if I'm looking for a fairly "comfortable" ride? (Yes, I got mine mainly because I want to lower my car) Thanks!
MY07 A22 E90 N52Nxi
01-08-2009, 02:50 PM | #2 |
Lurker
Rep 18
Drives: 08 E92 335CxiA M-Sport
I too would like to hear from fellow KWv3 xi:ers and your settings for a comfortable ride. Like the OP, I got my KW:s mostly as a "4x4-delete". I probably won't ever go to the track with this car (albeit who ever knows?), so my main priority would be comfort. I've been going with the default settings for a while now, but it's a bit too harsh for my liking (feels kind of like my previous car (E46 M3), but since one of the reasons for my changing cars was that I wanted a more comfortable ride, that's not necessarily a good thing).
I do, however, want to be able to use the freeways without the car getting all wobbly on me (I once tried lowering the rebound to -12 clicks (or 2 full turns) on the fronts, and the car was like jelly once past 75mph or so - of course, the reason for that might have been that I was too lazy to change anything but the front rebound ). Anyway, some decent "comfortable ride" settings would be nice if someone's done the research already. Since I don't have any cut-outs in my trunk liner, I don't fancy stripping her down any more than I have to. - Pud.0
2002 E46 M3 SMG II (sold)
2008 E92 335CxiA M-Sport [Sparkling Graphite / Blue Shadow (alcantara) / most factory options] Current mods: M6 19" reps (235/35/19, 275/30/19) / KWv3 / JB3 |
01-09-2009, 12:15 PM | #4 |
Rep 13,583
Drives: JB E92 335i
01-09-2009, 09:30 PM | #5 |
Rep 2,384
Drives: W211 E350 4M MkV GTI 987.2 S
An easy way to improve the ride is to change to non-runflat tires.
07 E93 335i - Returned at lease end
09 W211 E350 4Matic Avant Garde - Blk/Blk, AMG pkg w/18". Sport Susp. F1 Asym. Debadged. 09 MkV GTI w/Leather & 18" Huffs. F1 Asym 10 987.2 S w/Leather sport seat, Sport Chrono, 19" Carrera S II wheels |
01-09-2009, 09:45 PM | #6 |
58
Rep 2,201
Drives: 996TT/ae86
01-10-2009, 08:21 AM | #7 |
Mr. Monaco
155
Rep 4,197
i am wondering if the KW V3s are the right choice for me..progressive spring rate? Are other coilovers a better choice for the XI, i.e Bilsteins, FK ? Also, how easy is it to adjust the KW's ?
01-10-2009, 07:22 PM | #8 |
Rep 6,805
Already got non RFTs... anyone with V3s wanna chime in?
MY07 A22 E90 N52Nxi
01-11-2009, 10:15 AM | #9 |
///M Uber Alles
332
Rep 1,601
I'm still happy with my settings, even in -40 weather These are superior shocks in every respect, so they still absorb shocks very well, even though they are firmer. I think they key for you is to find a good shop to install them that will understand what you want and will let you test drive a few different settings.
die Welt ist meine Auster 2015 M4, MW, Black Full Merino, DCT, CCB, Adaptive M Suspension, Premium, Executive. Technology, ConnectedDrive, CF Trim, Convenience Telephony, European Delivery |
01-11-2009, 10:43 AM | #10 |
Rep 1,003
you kno thats great and all, but the OP wanted to hear about settings (not oh should i buy coilovers for my xi).
i recently set my compressions to a few click away from the softest but left the rebound at the recommended settings, the car still feels stiff as hell and i cringe after every bump/pothole. The rebound was left alone because it was a little more work to get to it. Whats the easiest way to get to the rebound adjust for the front, do i have to take them off the car??? |
01-11-2009, 11:54 AM | #11 | |
///M Uber Alles
332
Rep 1,601
01-11-2009, 01:01 PM | #12 |
Lurker
Rep 18
Yesterday I finally took the time to remove the trunk liner and adjust the rear rebound (top of strut) settings. Turned out that they were at -4 (with 0 being full hard), even though they were supposed to be -6 as per the installation instructions (see second half of document for english instructions)). After changing them to -14 (which it seems I left the front ones at last time) out of 18, and adjusting the front bump (bottom of strut) to -7 (the default being -5) out of 12, I definitely got a much more comfortable ride. It now seems to be about at the comfort level it was with the original (OEM) suspension setup, yet without creating that wobbly feel I had earlier.
The front bump can be "easily" adjusted by turning the wheels fully, and reaching in with your hand to where you can feel the bottom of the strut. There is a hole in the bottom, where you can insert a hex key (not the 2 mm one, I tried a few and I think the right one would be something like 4 or 5 mm (I can verify this later if someone needs the info)). Like the manual says, the bump has an adjustment range of 2 full turns, and I also found that the clicks (6 clicks per full turn) on the bump adjustment were much more pronounced than on the rebound adjustment screw. I didn't take any pictures of this, as all I had was my phone, and the lighting was not good enough. I plan on taking some pictures with a better camera (with flash) later. The whole procedure (including trying to find the right places to adjust and the right tools for the job) took me about two hours (with the hardest part being removing the trunk liner). I could not, however, find where to adjust the rear bump. At the bottom of the strut there is a different kind of knob than on the front, and nothing seems like it's used to adjust anything. I also tried to turn the "knob" with a spanner, but at least it didn't move with the minimal amount of force I used (none of the other adjustments need any force, so I don't expect this one to be any exception). Like I said, I had no useful camera at the time, but I'll take some better pictures soon so you'll see what I mean. Could someone who has actually adjusted the rear bump perhaps give me any pointers as to where I should look? - Pud.0
01-11-2009, 01:07 PM | #13 |
Rep 1,003
no im back on the stock 18's for the winter time. I will try to soften the rebound settings. i know that bump is adjusted from the bottom and the rebound from the top...but how can i access the top of the front shocks? (thats what i was asking before, not about bump)
01-12-2009, 09:12 AM | #14 |
Rep 6,805
Thanks Pud.O!
MY07 A22 E90 N52Nxi
01-12-2009, 01:39 PM | #15 | |
Lurker
Rep 18
Unfortunately I have no pictures with the rubber cap on, but I took a few with the cap removed and my hex key inserted. I know they're shitty quality (again, phone with no flash), but they may still be better than nothing. I'll try to take some better ones tomorrow (as well as some of my mystery rear bump adjustment point). Here you go: Closeup: Hope these help! - Pud.0
