01-19-2023, 09:29 AM | #1 |
Rep 194,503
Pure Turbo BMW N55 PURE750 **NEW PRODUCT**
N55 PURE750 Upgrade Turbo -Upgraded Point-Milled Billet 7+7 High Flow Compressor Wheel (Out Flows Previous Solid 8 Blade Compressor Wheel) -Upgraded HiFlow G35 Style Turbine Wheel -Dual Compressor Oil Seals, Dual Turbine Oil Seals -Large Diameter 360 Thrust Upgrade -New Stainless High Flow Turbofold -VSR Balanced of course -100% Built and Balanced in house in the USA! No out outsourced Machining what so ever
01-24-2023, 07:54 PM | #2 |
Rep 196
How does this compare to Stg2?
How does the 500 compare to a stage 1? Fancy new name to stir up new biz or redesign?
14' Alpine White M235i 6MT, BM3 Stg2+, VRSF DP-CP-FMIC, Dinan Muffler, GFB DV+, 3.5 bar MAP, Dorch Stg1 HPFP, NGK 97506, BM3 Flexfuel Kit, CDV delete, KW V3, EDC delete, Powerflex Camber LCA bushings, VMR 801 18x8.5/9.5 et45, Conti Extremecontact 235/265
Next step: M2 Competition or Manual Supra MKV build Summer 2022 |
01-25-2023, 10:05 AM | #3 | |
Rep 194,503
500 is the new stage 1 w a better turbine wheel design and is a little bigger than the original stage 1 Stage 2 is usually good for up to 550-580whp, and the 750 should be good for up to 700whp. 600-650whp is probably where it would be happiest. Still waiting for results from a built engine car to see its max
01-25-2023, 01:56 PM | #4 | |
Rep 4,969
425-475WHP STG 1 550-580WHP STG 2 650-750WHP STG 3 |
01-25-2023, 04:22 PM | #5 |
Rep 194,503
I think that's accurate.
AmuroRay2851.50 |
02-26-2023, 11:20 PM | #6 |
Rep 33
As much as I want the latest pure 750, I am having a hard time justifying the upgrade from my stage 2. One big reason is for emissions/identification.
Didn’t pure release a dyno of 608whp on Facebook E30+meth at 25psi? Don’t get me wrong I understand the manifold benefit. It would be nice to know the size changes in both wheels and and size of the new turbine housing (if it has changed). P.S Mike, I still want one. After buying suspension and some other stuff from you first lol. Patiently waiting for the SGT exhaust. Excited. Last edited by Steventalon1; 02-27-2023 at 12:08 AM.. |
02-27-2023, 08:41 AM | #7 | |
Rep 194,503
It's the better and more efficient turbo. It makes more power as well. If you are happy with your PS2 power and delivery, there is no reason to upgrade. But if you want more power, this is an excellent option.
02-27-2023, 10:30 AM | #8 | |
Rep 87
Chris |
02-28-2023, 10:22 AM | #9 | |
Rep 194,503
It's perfectly balanced to spool fast and generates significantly more power on the higher RPM.
03-22-2023, 10:01 PM | #10 | |
Rep 33
I am interested to see how reliable these are and power output compared to the CTS turbo. I would rather have the garret DBB center section. |
Efftooto43.50 |
