BMW 3-Series (E90 E92) Forum
What is the max size (in cm/mm) of a battery that fits in an e93 LCI?
11-24-2022, 09:19 AM | #1 |
Rep 490
I'm not asking about how many Ah fits, I would like to know what the hole size is of an e93 LCI, so for instance if an 353x175x190 fits?
11-24-2022, 10:31 AM | #2 |
Rep 4,067
I don't know anything about HOW batteries are advertised or sold in The Netherlands, so the following describes US.
H8 or Group 49 is the LARGEST battery that will fit in E9x models. I'm NOT aware of any reason why E93 is different from E91 in that regard. E93 is more difficult to change battery in than other E9x Chassis, due to top causing issues with access to battery well. Batteries are sold by case size and Terminal Orientation (you don't want (+) & (-) Terminals reversed, or on wrong side of case. The E9x battery has (+) terminal Forward on Outboard side as mounted. Ah or CCA ratings are "Electrical" ratings (Amp-hours & Cold-Cranking Amps), and while they have SOME relationship to case size, that is NOT their primary purpose. E9x models have several different threaded holes in the Battery Well Floor for the Rear Hold-down Clamp, to accommodate H8, H7, H6 case sizes, and hold them in place. The following is an example of H8 Battery ($40 more than 3 years ago ;-): https://www.homedepot.com/p/Exide-SP...-49/308488577? Electrically-speaking, you want to make sure you know what the (1) Battery Type (FLA vs. AGM) and (2) Amp-hour Rating (Battery Capacity) SETTING is in your CAS module, and replace with SAME Type/Capacity. Otherwise, you may need to change ("Code") the CAS module setting to properly match your replacement battery Type/Capacity. INPA (free BMW Factory-Level Diagnostic Software) will tell you what that Setting is. For those with INPA, the "Menu Path" is: INPA > DME > F5 Status > F5 PM (Power Management) > F3 PM Info Field 2 If "Battery Capacity" Ah value does NOT say "AGM", the setting is for FLA. George |
11-24-2022, 10:34 AM | #3 | |
Rep 490
BTW where I live they don't do H# sizes, but I looked it up and H9 seems to be 395mm. So I don't know what the battery I'm looking at is, (H8,5?) but I'm just wondering about that size, that's all. Edit: wow a different site says H8 is 354mm. That's why I was wondering what the maximum size is in mm/cm. That H# spec is not very clear. This site says H8 is 315mm: https://carsaxle.com/h7-vs-h8-battery-size/ This site says H8 is 354mm: https://batteryquery.com/h8-vs-h9-battery/ Last edited by Dx11; 11-24-2022 at 10:41 AM.. |
11-24-2022, 11:08 AM | #4 |
Rep 4,067
Sorry I didn't "do the math" previously, but the Exide ad I linked states 14-inch length. That converts to 355.6 millimeters. I have NO IDEA how accurate that "14-inch" spec is in the ad. I've always bought batteries by "H" or "Group" spec, and NOT by inches or millimeters.
Kinda-like putting measurement specs on a loaf of bread to make sure it will fit in your "Bread Box" (as if we still had bread boxes). Are you saying there is NO "Standardization" of Battery Case Size in EU/Netherlands? George |
11-24-2022, 11:10 AM | #5 | |
Rep 490
https://www.accudienst.nl/p71452/varta-g14-accu.html As you can see, no H8/Group 49 marking or anything like that. Also I'm not allowed to visit your home depot link from the Netherlands apparently, gives an error. |
11-24-2022, 11:33 AM | #6 | |
Rep 4,067
Since "Seeing is Believing", see the attached ScreenPrint of the Home Depot Exide H8/Group 49 Specs. 353-355 mm should FIT. One Inch = 25.4 mm; at least that works in US. George |
11-24-2022, 01:21 PM | #7 | |
Rep 490
https://bmwbatteryfinder.com/best-ba...nvertible-e93/ 13.9” x 6.89” x 7.48” 354 x 175 x 190 mm I guess I'll order and try, already saw it's gonna be real not easy to change it in the e93, but it has to happen someday (10 years old, getting the increased battery discharge warning). BTW this is the correct orientation right?: https://www.accudienst.nl/images/acc...nl/layout0.gif Last edited by Dx11; 11-24-2022 at 01:30 PM.. |
11-24-2022, 02:48 PM | #8 | |
Rep 4,067
The H8/Group 49 Battery uses Entire length of Battery Well. Rear Hold-Down Bolt is in Rear-most threaded hole in floor. When Replacing Battery, be careful NOT to damage BST (Battery Safety Terminal) Connector or IBS (Intelligent Battery Sensor). I would ALSO recommend opening the covers of the "Transfer Points" and inspecting for any Rust (2nd photo attached). George |
Dx11222.00 |
11-24-2022, 03:06 PM | #9 | |
Rep 490
11-25-2022, 01:12 PM | #10 | |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
11-25-2022, 01:30 PM | #11 |
Rep 490
The Nightman1091.50 |
11-25-2022, 09:13 PM | #12 |
Rep 553
Maximum allowed battery size dimensions are:
H6: 278x175x190 H7: 315x175x190 H8: 354x175x190 However, some manufactures may make it a tiny bit smaller. For example, actual Odyssey Performance specs are H6 - 277x175x188 H7 - 315x175x188 H8 - 353x175x188 Dx11 - if your E93 is diesel, try to fit H8 AGM My E90 335d came with FLA H6 (from last owner) and it sucks.
Dx11222.00 |
11-26-2022, 04:38 AM | #13 | |
Rep 490
POBEP368.50 |
11-26-2022, 11:15 AM | #15 | |
Rep 553
- 1h drive is good, but one-time full charge could help too
11-26-2022, 11:26 AM | #16 | |
Rep 490
I don't have an AGM charger. Also when starting the first time on the new battery it give me a low voltage warning, it doesn't do that anymore now, only the high discharge warning + no keyless. |
