10-27-2022, 12:16 PM | #1 |
Rep 59
Drives: BMW 220D F22, Mazda MX5 ND
Rear Coilover Rebound Adjust?
Hello all,
I am using ST XA coilovers on my 220D for street and track use. Since front top mount is very easy to reach, i like to change the stiffness and try to find the best in track. But of course i cannot reach rear top mount so adjusting rebound on rear is not even possible in track. One of my friends cut a hole in the trunk of his 120D and can easily reach the rebound knob. But i don't know where to cut or is it possible to reach top mount from trunk in F22. Is there anyone who has an experience? I would like to hear your opinions! Thanks in advance |
10-27-2022, 01:33 PM | #2 |
Rep 80
It is possible. Kw v2
I have attached two pictures, hopefully give you the orientation installed in M240 KW sells extensions which install on top of shocks and can be adjusted inside the trunk. I Drilled a 1/2 " hole from inside each rear tower. Bill |
10-27-2022, 05:48 PM | #3 | |
Rep 59
I am not sure about drilling the tower, i am sad that it is not already drilled from factory. But i will talk with my mechanic to see if we can do it in a safe way. |
11-02-2022, 01:34 PM | #4 |
Supreme Allied Commander
3893
Rep 54,603
Drives: F80 M3
If you drill through the body just make sure you use a rubber grommet to prevent moisture ingress.
omerakz11.00 |
