n54tuning.com - NEW BMS Elite F Chassis B58 Intake For F2x F3x BMW 140 240 340 440 |
01-10-2022, 12:45 PM | #1 |
Rep 116,110
ORDER LINK https://www.n54tuning.com/bms-elite-...0-340-440.html Gain Up To 10+Whp Along With Terrific Sound The BMS Elite B58 Performance Intake outflows the OEM intake but retains everything that's good including the cold air ducting and lightweight heat shielding airbox bottom but replaces the top end of the intake with larger higher flow ducting, a heatshield, and a quality BMS inverted cone air filter to match. Available alone or packaged with our B58 turbo inlet maintaining that same high level of flow all the way to the turbo. During our dyno testing, the BMS Elite B58 BMW Intake performed the same or better than other B58 BMW intakes tested posting gains of up to 10+ horsepower to the wheels at 25psi+ boost levels. In addition to freeing up some power turbo spool speed was improved, and there is an incredible sound improvement. You'll finally be able to hear your turbo spooling! Installation is easy and fully reversible. Our proprietary high flow filter can be cleaned every 15-20k miles using an S&B cleaning kit and will last the life of the car. Our intake temperature testing found no significant difference from the factory intake during both sustained cruise and full-throttle operation. BMS Elite S55 Intake FEATURES AND BENEFITS • Adds up to 10+ Horsepower • Dramatic sound improvement • Includes optional high flow turbo inlet • Improves throttle response • Outflows stock intake • Retains OEM airbox base as a heat shield • Upper heat shield included • Retains OEM cold air ducting • Looks great under the hood • Cleanable and renewable air filter • Made in the USA F Chassis Applications BMW 1 Series • 2016+ F20 F21 (B58 engine) 140i/140iX BMW 2 Series • 2017-2021 F22 F23 (B58 engine) 240i/240ix BMW 3 Series • 2016-2018 F30 (B58 engine) 340i/340iX G20 Owners: This intake does not fit the new 2019+ G20 M340. That intake is located HERE BMW 4 Series • 2017-2020 F32 F33 F36 (B58 engine) 440i/440iX |
01-12-2022, 02:30 PM | #2 |
Rep 116,110
01-18-2022, 09:15 AM | #3 |
Rep 116,110
01-30-2022, 07:25 PM | #4 |
Rep 116,110
02-18-2022, 03:23 PM | #5 |
Rep 116,110
04-20-2022, 11:56 AM | #6 |
Rep 116,110
05-08-2022, 08:58 PM | #7 |
Rep 116,110
05-27-2022, 10:30 AM | #8 |
Rep 116,110
06-15-2022, 01:17 PM | #9 |
Rep 116,110
09-29-2022, 11:27 AM | #10 |
Rep 116,110
10-12-2022, 10:48 AM | #11 |
Rep 116,110
05-24-2023, 09:37 AM | #12 |
Rep 116,110
09-27-2023, 11:07 AM | #13 |
Rep 116,110
