2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB chirping noise when accelerating
      08-31-2021, 02:54 AM   #1
Awn
Newbie
Awn's Avatar
Saudi Arabia
Drives: BMW M235i
recently i started hearing this "birds chirping" noise coming from the right passenger area.
Noise goes off when accelerating (pressing on the throttle) and goes away when i release the throttle, no noise present when car is rolling without throttle even at speed.
The noise is not present when car at stationary and revving, the noise is highly present first 20mins of driving and gets lower after 20-30 mins driving or when driving hard, it could be sounding lower because im getting used to it.
took it to a professional mechanic $$ and changed the belt tensioner and belt but failed to fix, then the mechanic recommended to change front brake discs which are not due yet, however, i can not be convinced that they are the brake because no brake squeal or what so ever when breaking, and i can't be trusting the mechanic anymore for fixing major parts $$$ without even him lifting the car to inspect undercarriage or go to more deeper inspections.
For now im living with it, here are couple of videos i recorded, the noise is better heard with headphones.
Estoril Blue - Coral Red
      04-02-2023, 10:39 AM   #2
glacierburst
Drives: 2004 545i SMGS HUD SPORT
Did you ever figure out that noise issue? Have f10 535 doing the exact issue under light acceleration. Thank you
      07-10-2023, 11:03 PM   #3
tpros11
tpros11's Avatar
Drives: 2008 BMW 128i
I just recently started having that same problem too, I drive a 2008 128i, were you able to figure out the problem??
      07-11-2023, 07:12 AM   #4
freakystyly
Drives: F22 B58 6MT
Is your HVAC fan running? It could be a squeaky fan.
Does it happen with someone in the passenger seat? Could be a squeaky seat.
      07-12-2023, 10:21 PM   #5
tpros11
tpros11's Avatar
it happens when I have someone in the passenger seat and when I'm by myself and it is every time I lightly press the gas and when I push down past a certain point it goes away. My fan is loud but it's a different noise than this. I don't believe its the belt either because it's still tight
      01-15-2025, 01:18 PM   #6
Jerome10
Drives:
Long shot here, back from the dead.... actually have a new Lexus LS500 (replaced a BMW) that is doing this and your videos are extremely similar to my car. Same noise under light acceleration. Dealer has looked 3-4 times, master mechanic flown in. Cannot determine cause.
If you happen to come across this post again and you were able to solve it, I'd be forever grateful.
      05-24-2025, 07:55 PM   #7
overcoil
Drives: M235i 6spd
pretty sure that chirp is that the emergency brake cable clip snapped.
Remove trans to axle shaft to reach up and repair.
