I'm getting a hot and cold side charge pipes. Will it help my car run better on BM3 s |
08-08-2021, 02:14 PM | #1 |
Rep 93
Hey guys so i'm getting both hot and cold side upgraded charge pipes because my shop recommended them since the stock ones are horrible. I also have a VRSF 6.5" Competition Intercooler. With these upgrades, will it make my car run a little better when i run my BM3 E30 and BM3 Stage 2 maps?
Let me know! Thank you so much |
08-08-2021, 02:42 PM | #2 | ||
Rep 30
Adding the BM3 tune will make a very big difference. I also have an Active Autowerks catted downpipe and so can run BM3 stage 2 multimap. Compared to stock It pulls very hard indeed - smokes the tires in first and second, plus you get the anti-lag feature which is quite the thing, although I wish they'd set that up to use the 2nd position in cruise control (requires a light touch instead of simply pushing it). Definitely enjoying the change that it all makes but now trying to figure out running E30 fuel to see if I can get more power. Hope this helps!
Rowie.
08-08-2021, 04:16 PM | #3 | |||
Rep 93
08-09-2021, 09:18 AM | #4 |
Rep 191,163
Charge pipe and Boost pipe won't add any power regardless of which map you run.
The shop is asking that you upgrade them because it's a matter of time before they fail and start leaking causing a loss in power. if you car run better after the upgrade, that's a sign that the stock ones were leaking
