BMW 3-Series (E90 E92) Forum
Using n52 parts on n51
05-11-2021, 04:30 AM | #1 |
Rep 23
I’ve looked every for a thread similar to this & found nothing. I’m currently changing the valve cover gasket & noticed the ccv breather hose tore apart in half. I wanna replace the ccv valve while I’m at it but can’t find a n51, I can only the fine the breather hose. Prob a silly question but you can use n52 on a n51 ?
05-11-2021, 06:57 AM | #2 |
Rep 1,579
All of that may be covered under the N51 SULEV warranty in NY. Check this thread. https://www.e90post.com/forums/showt...&highlight=n51
05-11-2021, 02:00 PM | #3 | |
Rep 23
05-11-2021, 02:45 PM | #4 |
Hoonigan
6884
Rep 3,000
Drives: '09 328i, '98 Wrangler
The N51 and N52K should be the same, both with the ccv built into the plastic valve cover, with the breather hose separate. To replace the valve you basically need to replace the cover. If the cover isn't leaking and only the hose is damaged I would just replace the hose.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
