03-04-2021, 11:33 AM | #1 |
Rep 345
The quest for 245/40-18 square: success
Car:17 M240ix
After much research here (thanks too all who posted their various tire/rims sizes with offset!!) IMO the perfect offset to center a tire (to mount the widest tire possible) in the front is 38 to 40mm. Every brand/model tire is slightly a different width even at the same numbers, so you can push the envelope but one tire may tire and the next one in the same size suddenly will be wider and not fit. I bought a 245/40-18 Mich PS4S and any other tire might be slightly wider at the same size so you need to watch for that. I drove 2 days on 245/40-18 with 40 offset on 18x8.5 with no rubbing. Put the tire on the opposite side and two more days of driving and no signs of rubbing. I think you could get away with 42offset but will be very close to the suspension, and probably around 35offset and stick out a little but not enough to hit the fender. If someone really wanted a 255, it would work on the suspension side at 35 to 38mm (pick a narrow model) but who knows about rubbing on the fender. I bet it would work. My rims are 45offset, and the tire was only about 2mm from the suspension at 45mm. It might be ok but was too close for my blood so I put on 5mm spacers and now I have about 6mm of room which I'm comfortable with. Pic WITHOUT spacer (45mm offset): Pic WITH 5MM spacer (40mm offset): |
03-04-2021, 07:11 PM | #2 |
Rep 599
I run 245/40r18 square as well. My wheels are 18x8.5+40, but I need at least a 5mm spacer on the front to clear the strut.
I am RWD. I wonder if there is a small difference with the strut/knuckle with xdrive that pushes the wheel further away from the strut. I run a 10mm spacer front because I'm running -2.5* front and rear camber. I also run a set of 17x9 +42 with a 10mm spacer front and 255/40r17.
2015 F80 M3 DCT, Carbon Roof
1998 S54 E36 M3 BMWCCA Club Racing #532 CM 1995 E36 M3 Sunbelt S52 |
03-13-2021, 01:50 AM | #3 |
Rep 22
These pics and numbers are amazing thank you! Fitting my 18x8.5 ET35 setup in a few weeks and I have some PS4S in both 225 and 245 and I can't decide which to mount with the new wheels. You said 35 offset would probably stick out a little but not enough to hit the fender, how much clearance do you have currently to the fender with your +40 effective offset?
03-15-2021, 12:09 PM | #4 |
Rep 345
With my front PS4S 245/40-18 +45 wheels and the car jacked up the tire is almost touching the strut I'd say a mm or two away. I can easily see it rubbing with aggressive driving, possibly even with the car off the floor jack. With the 5mm spacer (so now I'm at 40 offset) its about 6mm away.
With your 35 offset wheels you should have about 10mm of space from your suspension, more than enough. Mine are not rubbing the fender at 40mm, but your 35mm will be 5 mm closer to the fender than me. You might have a problem there. I've driving over some bumps and done some high speed turns and saw/heard no signs of rubbing. You might. Also, if you have 245/35-18 (diameter slightly less than mine) you will get an extra 2mm or so on both sides. |
03-15-2021, 01:27 PM | #5 |
Rep 3,472
It's my understanding that tires move away from the struts when driving aggressively.
2017 M240i: 23.6K, MT, Sunroof Delete, 3,432#, EB, Leather, Driving Assistance Package, Heated Front Seats | Sold: E12 530i, E24 M635CSi, E39 520i, E30 325is, E36 M3 (2)
03-15-2021, 04:19 PM | #6 | |
3578
Rep 3,555
dradernh4177.50 |
