2Addicts | BMW 2-Series forum BIMMERPOST Universal Forums Off-Topic Discussions Board Does anyone here make their own cold brew coffee?
      02-27-2021, 12:45 PM   #1
TiMSport
Ukraine
12793
Drives: '21 M340i xDrive, '17 Audi S3
I just started recently and wish I had done so sooner. Saving myself some money as I used to buy a lot of premade stuff.
      02-27-2021, 12:46 PM   #2
Mosaud1998
Mosaud1998's Avatar
Drives: 2019 BMW 540
2019 BMW 540  [0.00]
I hardly even drink coffee anymore.
I used to drink it a lot when I worked at the Kia Dealership.
Now with covid and being back in school, I hardly drink it.
      02-27-2021, 02:52 PM   #3
4130
4130's Avatar
66
Drives: 2011 E90 M3 LeMans Blue
I've been doing it for a couple of years. I do it the relatively quick way with a Cuisinart. I don't have time to do it any other way thanks to work and kids.
      02-27-2021, 06:06 PM   #4
TiMSport
Ukraine
12793
Please elaborate on the Cuisinart. Are you referring to the automatic cold brew coffeemaker?
In my case I got a simple one like this. Works amazingly well.
      02-27-2021, 06:35 PM   #5
M-technik-3
Drives: E30 M3, E36 M3, 328iT, 335i
1995 M3  [9.00]
2007 E91  [7.25]
1988 M3  [9.50]
Can't you just use a french press?
      02-27-2021, 07:15 PM   #6
TiMSport
Ukraine
12793
I don't think it's the same thing though admittedly I've never tried to make cold brew with one. You need to have a very fine filter inside to hold the ground coffee which doesn't exist in a French press so you'd end up with coffee particles floating around in it which would not be good.
The product I'm using is 64oz in size and very durable, yet light weight. After it's done brewing I simply store it in the fridge.
      02-28-2021, 03:58 PM   #7
4130
4130's Avatar
66
Yes, the automatic one. It's pretty good. I've had better, but it's quite good for quick work. I grind beans, brew, put into fridge overnight.
TiMSport12792.50
      02-28-2021, 06:57 PM   #8
Fly320s
Drives: Car
2020 BMW M2C  [5.50]
All you need is a pitcher and a filter.
Grind the coffee fine, add water, let it sit for a few hours. Filter it and enjoy.
It aint rocket surgery.
      02-28-2021, 07:25 PM   #9
TiMSport
Ukraine
12793
True, but making a good tasting one takes some experimenting. A few hours isn't enough for me. Mine brew closer to 24 hours and serves as a nice wake-up.
      02-28-2021, 07:39 PM   #10
TiMSport
Ukraine
12793
Maybe this would make a good brew
      02-28-2021, 08:30 PM   #11
Nothing
Roll Tide
Nothing's Avatar
Drives: White/red M3
I just use a glass cold brew jug off Amazon like posted above. Once that is brewed I move it to a used store bought cold brew jug and start another batch in the first container. This way I can drink one and know more is always being made for the next batch.
AW/SO - ED delivery 6/20/16
PCD - 9/1/16
TiMSport12792.50
      02-28-2021, 09:11 PM   #12
TiMSport
Ukraine
12793
Yeah that's pretty much what I do as well.
      03-01-2021, 09:49 AM   #13
jmack
jmack's Avatar
549
Drives: OG M2, E70 X5M
The Kyoto tower method is more of a show piece to display than to deliver any discernible flavor differences. I have my tower displayed on a bar cart and very rarely use it. It's a pain to clean and like I said, doesn't really give you anything that a simple submersion cold brew doesn't.
For small batch, just use a french press, add 1 part coarse grind coffee to with 5 parts water (up to 8 parts water if you don't want it super concentrated). Set the top on and press it down so the grounds are just barely submerged and let it steep for 16 to 24 hours. After steeping, press it, then I run it through a filter after because the french press tends to let some grounds through the mesh.
For large batch, I use a large pitcher (I think it's 1 gallon) and put the coarse ground in a nut milk bag. Submerge the grounds with the same ratio above and let it sit for the same time. This doesn't need to be filtered, just remove the bag, wring it out and serve.
TiMSport12792.50
      03-01-2021, 11:50 AM   #14
TiMSport
Ukraine
12793
Originally Posted by FoxMan32 View Post
it sounds strange but my favorite coffee is the simplest one. The black
Nothing strange about that at all. To be clear, cold brew coffee is black
      03-03-2021, 04:16 PM   #15
TiMSport
Ukraine
12793
I've come to the conclusion my 24 hour brew is the trick for a quick pick-me-up.
      03-10-2021, 04:05 PM   #16
TiMSport
Ukraine
12793
When you forget you're brewing some and discover it 27 hours later. It works as a nice pick-me-up to be sure.
      03-13-2021, 08:35 PM   #17
TiMSport
Ukraine
12793
For me, cold brew is good all year round
I do drink hot coffee as well. For a quick pick-me-up a small glass of cold brew does the trick though.
Search this Thread:
