02-21-2021, 11:54 AM | #1 |
Rep 318
Stock vs Bms intake
So i have the bms intake and i reverted back to stock for now i felt like the car lost low end power and throttle. It may be Because the ecu adjusting the air flow, i also have the bms tube after the intake. Anyone had an experience like this ?
02-22-2021, 02:59 AM | #2 |
Rep 455
Generally speaking, most modern intake systems in performance cars are pretty well optimized from the factory. The OEMs have way more time and computational power at their disposal to get the best balance of cost, volumetric flow across the rev range, temps across a range of use durations, sound, longevity, etc.
Aftermarket intakes tend to trade low-end power/torque and filtration efficiency for slight power/torque gains at the top of the rpm range, or can make a few hero pulls on a dyno with great gains before heat soaking and performing worse in the real world, or cost a ton of money for relatively minor gains, or only work well in tandem with other specific tuning changes. I don't have the data to back it up...but you're probably right and should trust your gut. The stock intake is fine, and the aftermarket intakes will offer some tradeoffs, but go ahead and do it you like the look or the noise, or if the specific performance claims the aftermarket manufacturer is advertising appeal to you.
02-22-2021, 07:51 AM | #3 |
Rep 736
Drives: Lexus RC F
My car didn't like the BMS intake either; always had rough cold starts and my IATs were slightly higher. Went back to stock airbox and K&N drop in and the car has been happy since.
Estoril Blue E36M3
02-22-2021, 08:08 AM | #4 |
Rep 318
Hey Everyone thanks, yup i reverted back to stock with the K&N but kept the BMS silicone pipe going down to the turbo. Car feels 100 time better, the BMS intake was great for the turbo noise and blow off but was getting throttle delay, low end torque was on and off. The stock box is actually a good design and the box is cool to touch after driving around. I will the the air scoop and install it just to get some extra air routed into the box.
02-23-2021, 10:02 AM | #5 |
Rep 194,556
That's surprising to hear, the B58 is one of the rare engines which benefits from an open intake.
Per BMS, their intake adds 10 whp on the B58, I also worked with VM on their B58 build and they got the same exact results (+ 10 whp)
02-23-2021, 10:52 AM | #6 |
Rep 318
Exactly, don't know if it's because im not tuned but i will hold onto it until i get the JB4 and try again. i think those dyno results are with the maps on the jb4. the Stock box restored all of the low end toque and throttle response, i wonder if the 21 ECU are tuned different with the maf sensor.
02-23-2021, 11:23 AM | #7 | |
Rep 194,556
02-23-2021, 12:17 PM | #8 | ||
Rep 318
02-23-2021, 04:05 PM | #9 |
Rep 194,556
LOL sorry
02-24-2021, 12:18 AM | #10 |
Rep 748
The HAI (hot air intake) mod works, and doesn't...
Bottom line though is that for such small change(s), you perceived change is most likely placebo induced. You aren't really going to "feel" a 10hp difference. You could get that effect from just changing gas supplier (E content). As for the ECU adjust... I had a conversation with a well established BMW guru, modder, racer at my dealership. We discussed some mods and programming changes, etc. as I've tuned some of my older cars. He assured me, that will most of the physical mods, these ecu's will adjust. Like for the added air with an open cone AND downpipe, or added midpipe / exhaust. This surprised me honestly... My knowledge is that ecu's don't, as they're expecting a certain VE from stock parts. Changes to Air, Fuel, or Spark requires an accommodation in those others to keep the balance and best performance. But hey... I'm old school. Again, you aren't going to feel 10hp difference... Maybe just maybe of you had 2 identical cars sitting side by side and drove one, immediately got out and in the other and drove right away... You might, and that's a huge maybe! The Burger open cone really is just that, but don't buy into the Manufacturer spends a lot of $ designing the BEST for every single component... It's not true. Air intake otherwise would ALL be from scoups on the front of the hood and not underneath it from a small pickup tube wedged into the side of the heat exchanger/radiator... Sorry! So yeah, you might get a different result from another brand. That's the thing with modding, it's a lot of trial and error to get what YOU want. Sell the one you have, take a 50% hit, it's ok, and buy another lol Good luck! |
02-24-2021, 09:37 PM | #11 | |
Rep 490
Most aftermarket intake utilizes black metal which is a bad idea because it attracts heat. |
02-25-2021, 11:02 AM | #12 | |
Rep 194,556
The owner called me surprised at the numbers and ran the test numerous times back to back getting the same result every time.
03-02-2021, 10:01 AM | #13 |
Rep 54
Few things, gonna go a little backwards but should be able to follow.
Black intakes - factory intake is black. The hood is not clear so sunlight does not hit it therefore it does not exactly absorb heat, misconception there. Even if it did, it would be minimal unless it sat in direct sunlight without moving. ECU adjustments - the guru cooolone2 mentioned is correct, especially when it comes to intakes. However, you have to give the car some time to adjust to these changes as the values are learned over time, look into short term vs long term fuel trims if you're inclined to learn more about it. The short of it is, there are 1000's of variables and the smart engineers and programmers at BMW know that, so they know that there will be some variation to the values that the ECU sees and it is equipped to handle that. As previously mentioned, you won't necessarily feel the ~10hp difference. What you might feel is the slight loss of torque as shown by the dyno graph but even that would most likely be a placebo effect. The major difference is before 3k RPMs, after that it's pretty close. However, this comes back to those 1000's of variables so your best bet would be to dyno your car on the stock intake, put the aftermarket on, drive it around for a bit, making sure to let the engine learn the entire rpm band, and get back on the dyno with as close to the same conditions as the first time...so good luck lol I may include a TL;DR summary once I get another coffee lol |
03-02-2021, 11:10 AM | #14 |
Rep 318
so far the car is running great back with the stock box, kn filter and the burger silicone sleeve after the maf sensor. i ordered the JB4 once i get it will put back on this bmw intake and see the outcome.
03-02-2021, 03:54 PM | #15 | |
Rep 3,611
Along with the fact that Dinan doesn't exaggerate its results, this is the data that caused me to choose their CAI:
03-04-2021, 01:28 PM | #16 |
Rep 54
Well with Dinan you do pay for the R&D as well, but the graph shows it.
Most aftermarket companies just go "ok, we make tube bigger, slap filter, powah" forgetting that the air velocity is also a big contributing factor, whereas Dinan clearly took it into consideration as seen by the difference in the low end |
03-05-2021, 02:27 PM | #17 |
Rep 452
I would argue that if you're chasing performance gain from an intake, then its worth paying for the Dinan one.
I highly doubt others test as much as they do..and this is coming from someone who's no longer buying anything from the brand. My poor experiences with them have been well documented on this forum. Regardless, if you're chasing performance improvements, dollar for dollar the net return on an intake is negligible. Anyone buying these is doing so for sound and the cool factor. |
ZHP to B5876.50 |
04-02-2021, 10:32 AM | #18 |
Rep 547
I dont know about cool factor, but Im definitely looking for the sound only and I will be satisfied with no performance lost.
Are dinan and bms intake our only options? Do they void warranty? |
04-02-2021, 10:35 AM | #19 |
Rep 194,556
your warranty does not get voided if you add an intake. The dealership might refuse to do a certain job for free if its related to your aftermarket mod that's all
04-02-2021, 04:10 PM | #20 |
Rep 164
Drives: '21 EB 240, G87 M2 (preodered)
If you've got a ton of disposable money to light on fire you can get an Eventuri CAI as well. It looks and sounds absolutely fantastic
2021 EB M240 6MT: TC Kline Camber Plates & Coilovers, Eventuri CAI, AA Catted DP, Remus Non-Res Catback, FTP CP; M Front Lip, Rockers, Mirrors, Spoiler, Interior
04-02-2021, 07:23 PM | #21 | |
Rep 547
Anyone have any experience with MST? |
04-05-2021, 09:12 AM | #22 |
Rep 318
So i got an update, After installing my JB4 on Map5 and running E30 I decided to slap back on the intake an see what will happen. So no more bogging down or lag the car actually sucking more air and turbo is spooling up faster. I guess the car needed a tune in place for this intake to run well, every car is different depending the are you live in. the IAT temp was 85 before while driving with the stock intake, with the BMS its around 88 to 90 driving around.
