01-05-2021, 05:39 PM | #1 |
Leave the gun. Take the Canoli.
9052
Rep 7,621
Why is the park button low on the shifter?
I think it's been this way for awhile now on other cars, but it's been a some years since I've driven a regular auto BMW. The only experience I have driving the cars with the newer shifter was at M Track Days. It seems to me that the park button is in kind of an awkward spot. You have to contort your thumb down a bit to get to it. I suppose this keeps you from accidentally pressing it, but I can't say it's ever a problem I had in the past. Anyone know about the design? I suppose you just get used to it.
This location seemed find to me. Now it's here:
Current: 2023 Santorini Blue ///M8 ||| 2023 X3 M40
Retired: 2021 Enzian Blue ///M4 ||| 2018 ///M4 ||| 2017 ///M4 ||| 2014 435i ||| 2009 335i Coupe ||| 2007 335i Coupe |
01-05-2021, 06:43 PM | #2 |
Rep 444
It's deactivated while in motion anyways. I think it's just for design.
2018 F87 LCI gone but not forgotten
2021 G80 6MT BSM |
01-05-2021, 07:30 PM | #3 |
Rep 2,007
Drives: 2022 i4 M50
It is sort of an after thought, but it's also not really needed assuming it works the same way as it does in the M8. I could just turn off the car in gear, and it automatically goes into park similar to what you had to do in the DCT. There's just the added benefit that I could park the car while running without leaving it in neutral or shutting it off now.
Current: 2022 i4 M50 | 2022 G07 X7
Gone: 2020 F92 M8 | 2020 G07 X7 | 2018 F80 M3 | 2017 F15 X5 | 2016 F16 X6 | 2015 F36 4 series GC |
AndroidRobot4331.50 |
01-05-2021, 08:42 PM | #4 |
Rep 1,902
I like the new position from a design standpoint but I never had issues with the old design on my F30 (top pic).
2022 G80 M3 Comp M xDrive |
01-05-2021, 09:05 PM | #5 |
9052
Rep 7,621
What do you like about the new design? And yes, the old placement seemed to work fine.
01-05-2021, 09:39 PM | #6 |
Rep 1,902
It just looks cleaner and more sporty
01-06-2021, 08:00 AM | #7 |
Rep 2,956
You get used to it to the point when I drive a loaner with the regular shifter it feels weird. Another part I really like about the M shifters is moving Reverse to the left and up of Neutral kind of like engaging reverse in a manual transmission.
DAC17170.50 |
01-06-2021, 09:32 AM | #8 |
Rep 6,121
Drives: 2022 Porsche Boxster GTS
I've used the actual park button maybe 5x in 2 years. I always turn my car off in gear because auto hold keeps it there and putting the car in park isn't necessary. I like how it's out of the way because we don't need to use 99% of the time
2022 Porsche Boxster GTS Gentian Blue
2023 Porsche Spyder Python Green (on order) 2022 BMW M3 Comp AWD IOMG/Kyalami Orange (SOLD) 2018 BMW M2 Mineral Grey(SOLD) 2019 BMW X5 50i Carbon Black/Tartufo (SOLD) |
01-06-2021, 06:14 PM | #9 |
9052
Rep 7,621
OK, didn't know that about it. If it works sort of like the DCT where it auto parks when you turn the car off then I agree, you don't need to actually press it very often and it's otherwise out of the way. Does it put it into park though or just leaves it in gear?
01-07-2021, 09:18 PM | #10 | |
Rep 6,121
snareman9051.50 |
01-09-2021, 07:56 PM | #12 |
9052
Rep 7,621
CoG. That's probably it. I didn't think of that. That's why you have 21k posts and I have 2k
01-09-2021, 09:58 PM | #13 |
Rep 2,858
Here is cross post photo snareman of the F95 M shifter as it's the same for the upcoming G80/82/83. Coming over from the previous F83 and F85, the new M shifter the past 2 days been an adjustment- as I loved the rounded short previous shifter.
2022 G83 PCD & 2024 G05 S68 PCD
Retired:2021 F95 ZCP PCD,2018 F85 PCD,2018 F83 ZCP- ED/PCD, 2015 X5 50i PCD, 2015 435 vert ED, 2011 X3 PCD, 2011 335is vert ED/PCD, 2007 X3is PCD, 2007 335i vert PCD, 2004 328i vert PCD |
01-09-2021, 11:18 PM | #14 |
9052
Rep 7,621
Did they throw in the mugs with your delivery? Are you pressing the park button each time you park it?
01-10-2021, 02:03 AM | #15 | |
General
17489
Rep 25,115
For my use case though, the P button in a BMW auto is barely used. Well if that was my fun answer here's my real answer. The world was already burning with a move from DCT to ZF gearbox. The DCT shifter as I'm sure you know is bereft of a P button. Thus the P button on the new ZF shifters was 'minimised ' to lesser highlight the change. As per my use case above it's also less used so has been kept, just, but is put out of the way. I actually think that's highly likely.
My car made front page of Bimmerpost
01-10-2021, 03:02 PM | #16 | |
9052
Rep 7,621
01-10-2021, 03:07 PM | #17 | ||
General
17489
Rep 25,115
Even better if it was pushed over to the left and in the manual mode Up/Down track, and you stop, it still goes into Park and pops back over to the right.
01-10-2021, 06:30 PM | #18 | |
Rep 2,858
snareman9051.50 |
01-11-2021, 12:01 AM | #19 |
Rep 1,241
Our X7 has the park button there, and I really dislike it. It's a very unnatural way to bend the thumb. I'm always needing to put the car in park while the engine is still running, and it bothers me every time. With everything these cars offer in terms of luxury, comfort, ergonomics, etc., I really think this is an obvious pain point that they should address. I feel like they should put it on the left of the gear selector where the unlock button currently is, and then move the unlock button behind it i.e. on the side closest to the dash. My Nissan Armada had the mechanical unlock button/lever there, and it was fantastic to operate in a hurry.
CP911
01-11-2021, 09:36 PM | #20 | |
9052
Rep 7,621
01-18-2021, 05:05 PM | #21 |
587
Rep 898
My X3M has a similar if not the same arrangement, I like it. Makes it feel less so of a regular auto box, and more of a DCT.
BM3, MHD, ECUTek Calibrator | N55/S58 specialist | 2023 X5 45e Frozen Marina Bay Blue
