01-03-2021, 07:12 PM | #1 |
Rep 19
Rear suspension problems
Hey guys, anyone have problems holding power after upgrades? I have FBO, MHD stage 2+ tune, dinan springs and a 235/265 MPS4S setup. The cars feels amazing except when really punching it. The back end gets squirrelly under load, the wheels don’t spin out but it doesn’t feel planted at all. Actually feels dangerous but still kinda fun lol. I’ve ordered powerflex rear diff and subframe bushing inserts to see if that helps, if it does I’ll eventually change out the bushings to stiffen everything even more. I’ve checked my tire pressures and they were all good. Has anyone else had this problem? Thanks!
01-04-2021, 10:18 AM | #2 |
Rep 3,507
Do you have a limited slip differential installed?
01-04-2021, 02:08 PM | #3 |
Rep 19
01-04-2021, 02:39 PM | #4 | |
Rep 3,507
My solid Al subframe bushings have had no discernable downsides over the last 9K miles of street driving. I considered them and the LSD as a pair to be installed at the same time, and that's what I did. I'm in the 'burbs outside Cincinnati, and the roads here are so-so. They're better than where I used to live in New England. Still, between raised manhole covers and things like surface imperfections and the rare minor pothole, I do get the chance to see how the coilovers, front swaybar, and rear subframe bushings react to less-than-perfect roadways. The difference I perceive is that the front's a little noisier than stock, and that's pretty much it. I'm getting nothing from the rear to tell me that I made a change, much less that it was a change for the worse. FWIW, I had the LSD and rear subframe bushings installed at 2K, and those miles were pretty much all highway miles at 65-70 MPH; so, not much to compare to. What I will say is that the rear of this car hooks-up very well. I might not be able to say that if I only used the car on the street (where I don't drive particularly aggressively), but it was true on the track as well, where a lot more was asked of the car when exiting corners. Cost aside, I recommend stiffer bushings to go with an LSD.
WolfGTI717.50 |
01-05-2021, 01:45 PM | #5 | |
Rep 19
dradernh4486.50 |
01-24-2021, 09:05 PM | #6 | |
Supreme Allied Commander
3893
Rep 54,605
Drives: F80 M3
02-10-2021, 11:42 AM | #7 |
Rep 19
Thanks for the response! Installed power flex bushing and it did make a noticeable difference. Much more planted on the rear and can smoothly put the power down
02-10-2021, 12:15 PM | #8 |
3893
Rep 54,605
Drives: F80 M3
Tags |
diff, subframe, subframe bushings |
