Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > E91 - Tweeter Upgrade Part Number Help
Reply
      10-16-2008, 06:33 AM   #1
misterS3
Drives: X70 on the way
Just called up to order the L7 Tweeter upgrade to my 09/2007 335D Touring
I was given the price for the DSP Tweeter £90.45+VAT and he reckoned that was the full kit including the grilles (?)
Is the DSP tweeter the L7 tweeter? i.e i'd like to fit the best tweeter, as i understand the price difference is negligible and i'll be upgrading the amp at some point.
The part number given to me was
65136944462
I've looked on Reoloem
http://www.realoem.com/bmw/showparts...30&hg=65&fg=20
And i can't see that this is correct.
Sorry for being a pain, but can someone with an E91 confirm what part numbers i need for the L7 Tweeter upgrade to basic hifi system (i.e the one without a tweeter) in an E91
Thanks in advance.
      10-16-2008, 07:49 AM   #2
quattrogmbh
Drives: BMW
I believe its 65136964013
      10-16-2008, 08:41 AM   #3
AlanQS
AlanQS's Avatar
Scotland
244
Drives: Jaguar XE P250 HSE
If it's the same as the E92, you have to buy replacement covers at the mirror which come with a built in grille, the tweeters are sold individually but you should be able to get each one for about £40 including VAT.
You need a new foam seal for the covers as it has a recess in it to take the tweeter and an extra cut-out on the edge for the cable but, as gIzzE has said, just use the original foam inserts and cut out the holes required - that will save you about £12. You can see my experiences here from post # 55 onwards.
HTH
      10-16-2008, 09:30 AM   #4
gIzzE
gIzzE's Avatar
363
Drives: F11 + 911 C4
Alpins speakers now available too...
http://www.realoem.com/bmw/showparts...94&hg=65&fg=95
Have a look there for the part numbers for the new trim/grilles.
      10-16-2008, 09:48 AM   #5
AlanQS
AlanQS's Avatar
Scotland
244
gIzzE, does that kit include the tweeters and the 2nd set of rear speakers to bring it up to the equivalent of the Hi-Fi option?
      10-16-2008, 10:32 AM   #6
gIzzE
gIzzE's Avatar
363
Don't buy any upgfrades for the rear speakers, when set up properly you will cut the rear high level out anyway.
That Alpine upgrade is and amp and front speakers, not sure if you can buy the speakers without the amp though???
      10-16-2008, 10:58 AM   #7
Carrera RSR
England
75
Drives: BMW
HTH
My plastic 'corners' in my E91 extend from the corner over the door/window frame and down the door shuts unlike the E92 which are just 'corners'. This may explain an increase in price for E90/91 over E92 for these plastic parts if being quoted with speakers from BMW.
      10-16-2008, 12:24 PM   #8
gr4z
gr4z's Avatar
United Kingdom
1135
Drives: i4 e40
Looking at the pictures on this site they supply the amp, tweeter and front speakers plus the grilles. Is this correct?
      10-16-2008, 02:10 PM   #9
misterS3
Once again, thanks for answering (good way of getting the grilles part numbers)
But.....as usual...more....
What model/specs of amp is that? i.e is it a good substitute for the 555 and will it drive SWS-8's under the front seats?
I had planned on doing it the Blaupunkt way that you did and wrote up so well, but if you think this is as good, suits me.
Thanks
      10-16-2008, 02:13 PM   #10
gIzzE
gIzzE's Avatar
363
It is a 4 channel so won't do the subs.
      10-16-2008, 02:14 PM   #11
gIzzE
gIzzE's Avatar
363
The grilles are for the saloon/touring and they are the seperate part numbers listed at the bottom.
      10-16-2008, 02:18 PM   #12
misterS3
Ta
555 is the way forward!
      10-17-2008, 09:18 AM   #13
misterS3
Just ordered the following at a cost of £102.
02 TOP-HIFI LOUDSPEAKER TWEETER 2 65136964013 $77.28
01 COVER, WINDOW FRAME, DOOR FRONT LEFT 1 51337171201 $32.64
01 COVER, WINDOW FRAME, DOOR FRONT RIGHT1 51337171202 $32.64
02 SEAL, INNER LEFT MIRROR TRIANGLE 1 51337120659 $10.71
02 SEAL, INNER RIGHT MIRROR TRIANGLE 1 51337120660 $10.71
No mention of spring clips.
Should arrive middle/end of next week.
      10-17-2008, 09:26 AM   #14
gIzzE
gIzzE's Avatar
363
The foam that people are ordering is already in your car, you just need to pull out enough to pop the tweeter in, saves £20 and you only end up throwing one lot out.
      10-17-2008, 09:27 AM   #15
misterS3
Ah okay!! Quick phone call coming up!!
EDIT: Cancelled the seals. And ordered a 2nd speaker - i guess that helps Different guy on the phone noticed that only one had been ordered! Will update final price when i go pick them up.
G - THANK YOU ONCE AGAIN
      10-17-2008, 09:38 AM   #16
AlanQS
AlanQS's Avatar
Scotland
244
misterS3, where did you order the parts from? Note that you'll have to cut out a circular recess in the existing foam and a small slit at the bottom for the wires.
Would it have been Park because they only ordered one tweeter for me because the description on their system says "tweeter - set" which is a bit ambiguous.
      10-17-2008, 09:44 AM   #17
misterS3
Cool - ta for the heads up. Should be a doddle
Yeh it was Parks and i'm guessing you're the "very clued up guy with the E92 who even hard part numbers" who ordered last week
      10-17-2008, 09:53 AM   #18
AlanQS
AlanQS's Avatar
Scotland
244
      10-17-2008, 12:27 PM   #19
misterS3
Just had a look close at my car and the plastic bit on the inside of the car, which is opposite the mirrors i.e where the tweeter goes, appears to be attached all the way around the window frame too?
I'd assumed it was just the triangle in the corner. Confused.com!
      10-17-2008, 12:33 PM   #20
AlanQS
AlanQS's Avatar
Scotland
244
gIzzE is the man to tell you about this as he did it to his E91
      10-17-2008, 12:39 PM   #21
misterS3
I take it on the coupe it's just the triangle of plastic?
Maybe i should go take another look.
      10-17-2008, 01:59 PM   #22
gIzzE
gIzzE's Avatar
363
No you get the whole lot, comes in 2 parts, the trim and a grille, however in that Alpina upgrade I presume that part number includes both bits.
Reply
Tags
e91 tweeter speaker
