BMW 3-Series (E90 E92) Forum
Split armrest tragedy
10-14-2008, 08:06 AM | #1 |
Rep 2,811
Drives: Jaguar XE P250 HSE
OK a bit over the top but, spurred on by the DIY for replacing the centre armrest in an E90, I decided to go for it on my E92. You can see how it's done here and it is fairly straightforward.
But, when you take the back trim off the coupe, you cannot see, or get at, the pins directly so does anyone know how much dismantling has to be done? |
10-14-2008, 08:32 AM | #3 |
Rep 827
http://www.e90post.com/forums/showth...t=28555&page=6 have a look at post 113
10-14-2008, 08:50 AM | #5 |
Rep 2,811
No, it's cream beige.
mistry kind sir, |
10-14-2008, 08:53 AM | #6 |
Rep 2,032
Drives: Red Flyer
Beige with the flash on
edit: Doh! I got beat to it.
10-14-2008, 10:12 AM | #8 |
Rep 2,811
Biggest problem was the spring. As you can see in the first photo, the connecting bar between the springs is in a groove at the back which means it has to be bent away from you. With the two rods in place you can't bend it back over the lip at 6 o'clock (hour position). With the rods pulled out I nearly got the connecting bar in it's groove but this would have made sliding the rods in, darn near impossible. I noticed that on the E90 and E92 photos, there was no spring so I've ditched it. Seems to work O.K.
mistry, it cost me £179 from Park's. |
10-14-2008, 10:43 AM | #9 |
Rep 2,811
Having road tested it, the spring acts as a damper. The armrest stills locks in place vertically but gravity takes care of closing so it wouldn't hang by itself half open - but how often do you want it to anyway?
10-14-2008, 10:48 AM | #10 |
Rep 827
looks good, did you get the gear mechanism mentioned on that thread that lifts the rest slowly, or was that sacrificed by not using the spring?
did u see this http://www.e90post.com/forums/showpo...8&postcount=68 looks like you were practically there with the second photo. reads like you just needed to lift the armrest then push the spring onto it's clip. |
10-14-2008, 10:58 AM | #11 |
Rep 2,811
No and no. See last post. But I will give it a try next time I want to hurt my fingers. If the non damping cheeses me off enough I will definitely give it a try but you have to understand that, car fixing ability wise, I am a klutz so I feel quite pleased with myself fitting the armrest and the Logic 7 tweeters.
Since you have been so resourceful so far, do you - or anyone else, know how to take the back seat squab off a coupe. I want to get to the underside of it to cut off an inconspicuous piece of leather for my next upgrade? I already asked the dealer if they had samples but got blank stares for my trouble. |
10-14-2008, 11:30 AM | #12 |
Rep 827
sorry didn't mean to put you down, well done for getting it in. It was just that it looked quite easy from what he was saying. but what do I know I've not done it myself.
As for the leather, sorry can't help you. P.S. if you want a home for the springs I'll look after it for you (if it would fit with a standard armrest) |
10-14-2008, 11:42 AM | #13 |
Rep 2,811
You weren't putting me down at all - but rather being a great link finder for me
The armrest came with a set of springs and there is a set on the car so you can have them if you want - but there didn't appear to be a gearwheel on the original so I'll have to keep the new one. |
10-14-2008, 12:03 PM | #15 |
Rep 2,811
It surprisingly doesn't take a lot. Vacuum once a week and a quick blast of leather cleaner every month or so - seems to do the trick.
10-14-2008, 01:22 PM | #17 |
Rep 2,811
I've got TWO sets of springs, the set that was already on the car and the set that came with the new armrest. I only need one set.
10-15-2008, 02:07 AM | #18 | |
Rep 295
10-15-2008, 08:50 AM | #19 |
Rep 2,811
Thanks Kend.
10-15-2008, 09:45 AM | #20 |
Right Responsible
58
Rep 1,646
Sorry for the hijack, but what is the purpose of the sliding armrest over the normal one?
I thought it was just for people with short arms?????
Last: 330cd Sport - Silver Grey, 335d M Sport Coupe, F10 535d M Sport.
Current: AW F21 M135i, Coral Red, Pro Nav, Vis, HK, & Clunky Adaptive Suspension Current: F15 X5 XDrive 40d M Sport - Space Grey, lots of toys. |
10-15-2008, 09:53 AM | #21 |
Rep 2,811
I can't reach the steering wheel with my left hand whilst leaving my elbow on the standard arm-rest - it is common with most cars - it irritates me, now I can.
Males typically drive with one hand on the wheel when cruising along, this allows you to rest your left hand on the wheel instead of on the gear knob, on your leg, on her leg ( no complaint there) when one's better half is in the passenger seat and it's quite relaxing whilst wafting along on a motorway cruise. Also, it looks smarter in that it looks more padded (doesn't feel any different though), is slightly higher than the original and the leather finish doesn't look as rough as the rest of the leather. |
10-15-2008, 10:34 AM | #22 |
Right Responsible
58
Rep 1,646
That will make it a great upgrade for you then - Cool!!
Being a bit of a lazy bugger, I usually never put my left hand on the steering and only use it to change the auto-stick, so this option would be lost on me. Even the headlights auto dip
