BMW 3-Series (E90 E92) Forum
E92 N52 turbo
10-29-2020, 04:39 AM | #1 |
Rep 6
E92 N52 turbo
It seems like I have one of the only e92s with the n52 engine, but I'm looking to turbocharge it. I haven't been able to find any turbo kits for the n52 engine, so if anyone knows of one or where I can find one, could you please let me know?? Thank you.
10-29-2020, 05:42 AM | #2 |
Rep 1,667
I think you’re probably the first person to come up with this. But just to make sure you should try the search function...
Good luck! |
relative4612.00 |
10-29-2020, 05:54 AM | #3 |
Rep 316
Drives: e92 320d sport plus edition
To state the obvious, sell the 328i & buy a 335i with the N55 engine? Will likely be a lot cheaper & the engine is built for it from the factory.
I can't imagine dealing with valvetronic programming + an aftermarket turbo will be easy. |
10-29-2020, 06:43 AM | #4 |
Rep 818
Its possible and think one or two have done it but.. The issue is not necessarily the hardware.. Its the software which there is no plug and play options which is why you won't find a kit or to much info on the subject..
The best option would to get a 335i.. If you did do a 328I I wouldn't see much retail valve since there is no testing on longevity. So whatever you put in it to do the turbo don't expect that back and except to lose a couple grand off the book value |
10-29-2020, 08:55 AM | #5 |
Rep 2,738
Let’s take the best N/A I6 motor BMW ever built and make it into the worst Turbo motor BMW never built. Perfect!
10-29-2020, 12:21 PM | #6 |
Rep 946
Sell it and buy a 335i it will be cheaper and more reliable in the long run. N52 was not made for boost a N54/55 was and they can make very good power with just a tune and a couple bolt ons.
07 E92 335i 6MT, MMP inlets, DCI, VRSF 7.5 competition intercooler, VRSF catless downpipes, VRSF chargepipe, 335is clutch, Vader Solutions stage 2 LPFP, MHD stage 2+, Hawk HPS 5.0 pads, R1 Concepts drilled slotted rotors, TSW Nurburgring 19x8 19x9.5
10-29-2020, 01:12 PM | #7 |
Rep 2,139
Here's a kit:
https://www.ebay.com/itm/BMW-2011-20...oAAOSwb5ZeRjd0 It comes with a free engine attached to it. |
Buug95917721.50 |
10-30-2020, 12:56 AM | #8 |
Rep 1,458
E92William1998.00 |
10-30-2020, 08:55 AM | #9 |
Art Collector
2427
Rep 3,450
A supercharger kit exists for this engine. I don’t know if it’s still in production, but that would be a FAR easier route if you’re looking for FI.
Edit: It’s still in production. https://esstuning.com/ess-n52-g1-sup...-system-gen-3/ Not cheap, but I’d think doing a turbo wouldn’t be either. Maybe not the power gains you’re looking for tho?
When I'm dead, just throw me in the trash.
10-30-2020, 09:45 AM | #10 |
Rep 45
10-30-2020, 12:17 PM | #11 | |
Rep 946
There is just no justifiable reason to boost a N52 when the 335i exists
10-30-2020, 01:18 PM | #12 | |
Art Collector
2427
Rep 3,450
I can *sorta* understand wanting to boost an N52 if you're in it for the novelty and the challenge (and money or value for money are not factors), but from a purely practical POV I don't think it makes any sense at all...
10-30-2020, 04:40 PM | #14 |
Rep 733
The N52 will take boost just fine, hardware is up to the task. Seems the real roadblock is getting a street able, refined, and oem feeling tune for it. In terms of refinement, the n54/55 will probably always be better on that front.
An N54 with all issues sorted would probably be cheaper to operate over 60,000 miles or so, but I'd be willing to bet that if tuned properly and not boosted to oblivion, a good N52 turbo setup would he equal, if not cheaper to operate than another particular engine, over the long run. I agree with the above however, there's a lot to enjoy from this engine NA with the 3IM, and 330 tune. |
10-31-2020, 02:20 PM | #15 | |
Rep 946
None of the other systems in the engine were designed to handle the additional power and heat from turbos either. So those would likely need to be replaced or upgraded more frequently. I dont believe a N52 comes with an oil cooler so rising oil temps would definitely be an issue. Obviously the fuel pump isnt up to the job. Injectors need upgraded. Ect...then you gotta run the plumbing. Deal with additional heat under the hood which depending on where the turbo is mounted could result in more frequent valve cover gaskets and possibly valve cover. Assuming you want atleast 400hp (otherwise why not get a N55 and leave it alone) you’ll be putting lots of strain on the conrods, block and pistons those wont last 60k+ I would not be so fast to assume that your N52 is so much superior in reliability as you guys always claim them to be
10-31-2020, 04:43 PM | #16 |
Rep 1,272
Don't listen to these guys. Grab a pair of N54 turbos and an outlet pipe, weld the wastegates shut, and run a hose to your throttle body. You'll get plenty o boost.
Bimmer_Engineer1043.50 Torgus3781.50 |
10-31-2020, 08:58 PM | #17 | |
Rep 733
I'm a bit weary of the early n55, although it seems they're pretty well sorted by the end of their production. In terms of what the n52 can take boosted, I mean in the 300-350hp range, which it should handle easily- a few have proven what it takes to pop one of these, and magnesium or not, it's still overbuilt like every other BMW engine...the part that fails isn't even magnesium. However, as someone said above, there's plenty of enjoyment to get from it naturally aspirated Financially, it's not a cheap task to buy a new car, whether it's the cost of the actual vehicle, loss on selling the old one, or whatever else may come up. In cases like this, I'd say if you absolutely must have 300-350hp and aren't particularly interested in selling your car, turbo-ing an N52 is an option IF you're willing to take power over refinement, something a n54/n55 will likely always have the edge in over a turbo N52. In terms of reliability, yeah, an N52 will always be cheaper to run over a long enough time, but that's not to say that all N52s are trouble free, and all N54s are a pain. There are pain in the ass N52s, and nothing but preventative maintenance required N54s. One is not better than the other, both are capable of making enough power to satisfy most people. The N54 and N55 are incredible engines, I am in no way attempting to shame them, it's just that the N54/55 is not always the answer. |
11-01-2020, 01:39 AM | #18 | |
Rep 946
The magnesium block may handle the power but longterm it will suffer. The N54 is so strong because it was overbuilt to handle the boost. I absolutely agree there is plenty of reason to keep and enjoy a N52 i just dont think anyone should get in one and be trying to chase power in one. Enjoy it for what it is. I disagree especially since you mention financially. You’ll end up spending alot more money and have alot more headaches trying to boost a N52 and if the tuning is wrong have to buy another engine and start over. VS accepting that the engine isnt worth putting the money and effort into and selling it spending a couple thousand more that you would already be spending trying to put a turbo on it. Not only will you save yourself the headaches but you’ll end up getting a better transmission, brakes made to handle the extra power, depending on the 328i’s options xenon headlights are standard on a 335i and a few other upgrades that are standard to the 335i. Like i mentioned before there is nothing wrong with a N52 it just isnt a smart choice if power is your goal. Youre better off taking that initial loss and getting the car designed for it
Biginboca3763.50 |
11-16-2020, 07:19 AM | #19 |
Rep 2,139
Well, if you want to dive in the never-ending chase of issues on a modified engine, here's your chance: https://www.e90post.com/forums/showthread.php?t=1770812
11-16-2020, 11:28 AM | #21 |
Slow.
3782
Rep 7,151
Drives: Single Turbo N54 on Meth!
Is the OP a troll?
Obviously the n54 is the better solution. No way does turboing an n52 make sense even if you can build the manifold yourself. Leave it NA it is a fine NA non M motor.
11-16-2020, 11:44 AM | #22 | |
Hoonigan
6884
Rep 3,000
Drives: '09 328i, '98 Wrangler
The reason you never see turbo'd N52's is that they already make the N54. There is no comparison. I'm not here to tell anyone the N54 is reliable, but think of all the problems that engine has and now imagine how many it would have if it was built by billy-bob in his garage. All the time, money, and effort could be put into making an N54 somewhat reliable and still put down more power. |
Smgs1992721.00 |
