2Addicts | BMW 2-Series forum Technical Topics Tracking / Autocrossing N55s have oil sump/ rod bearing issues + bonus Watkins Glen Footage
      10-04-2020, 10:33 PM   #1
K8_M235i
K8_M235i's Avatar
Drives: CM E36
As many of you know, my m235i sees a decent amount of track miles. I have heard stories from a few different sources that m235s can oil starve during long fast corners while running sticky tires. I have always run "slow" tires for this reason. Even slow tires didn't save my rod bearings.
A month ago my car spun a rod bearing at Watkins Glen. It was the second session of the second day. While accelerating out of the boot (uphill long right) I felt my car buck pretty hard, I came off throttle and heard a very distinct rattling and knew exactly what that meant.
My car does have 75k on it, but it's always been maintained properly and had new oil for the Glen. Watkins Glen just seems to be a very tough track on cars and has multiple areas that are a recipe for oil starvation.
I think for the most part, m235s should be fine at most tracks with most drivers. I definitely drive my car to almost all of its potential, and at a track like WGI that means it was working very hard.
Enjoy this very sloppy, but quick lap from the end of the first session. My tires were at about 42psi, but the bearing spun the next session, so this is all I got.
I do plan on adding f8x sump and pan before it sees track miles again.
2015 F80 M3 DCT, Carbon Roof
1998 S54 E36 M3 BMWCCA Club Racing #532 CM
1995 E36 M3 Sunbelt S52
msendit418.00
dradernh4347.50
shadowfax1289.00
      10-06-2020, 12:20 PM   #2
kthor703
Drives: 2021 M2 Competition
How many track events (or sessions) roughly? Did you always keep your oil level at max or a little over? Any oil analysis to suggest accelerated wear?
I would say I'm definitely getting a lot out of the car from a driver's perspective and I'm getting more nervous the more oil starve cases pop up. Ran re71r last year and planning Hankook RS4 next year, for cost, better wear and reducing risk of oil starve potentially. What do you consider as a slow tire?
      10-06-2020, 12:24 PM   #3
K8_M235i
K8_M235i's Avatar
Drives: CM E36
My car saw about 10 events this summer and I've had it for 3 summers.
My oil was always at "max". I never did oil analysis because my car was under warranty. If it came back indicating excessive wear I'm not sure what I would've done as I don't think the dealer would value that as a reason to do anything for me.
I was running Falken rt615ks. It has been my tire of choice for awhile because they are cheap and last forever.
      10-06-2020, 01:29 PM   #4
Pray for Mojo
Drives: 2014 M235i & 2018 X3 M40i
The F8X pan, pump, and oil pickup are a must for anyone tracking the car. Sorry for your loss, thanks for sharing.
K8_M235i476.50
      10-06-2020, 02:15 PM   #5
kthor703
Gotcha. Thanks for sharing. I've only done about 4 events so far. I'll be keeping an eye out and taking precautions for sure.
K8_M235i476.50
      10-15-2020, 08:07 PM   #6
hmulf
Drives: M240i
New member here, I'm just getting ready to order a M240i coupe. I intend to eventually do some autocross and HPDE track events and I'm wondering if the B58 engine has any history of similar oil starvation issues as reported with the N55 engine? Thanks.
      10-15-2020, 08:10 PM   #7
K8_M235i
K8_M235i's Avatar
Drives: CM E36
Based on all info I'm aware of b58s don't have any issues. I'm pretty sure m240ir don't have a different oil sump from the street car, but that would be a good thing to know.
      10-15-2020, 08:16 PM   #8
msendit
msendit's Avatar
418
Drives: M240i
For maximum confusion, the m240ir is just the m235ir rebadged (BMW Motorsports quite literally sent out a badge kit, plus a few other small tweaks). It still has an N55 with the upgraded S55 oil sump.
But yes, as far as I know, the B58 in the street car doesn't have starvation problems.
https://www.bimmerworld.com/Engine/B...137854463.html
      10-15-2020, 08:18 PM   #9
K8_M235i
K8_M235i's Avatar
Drives: CM E36
Wait really!?! I never knew that. Bmw can really be weird sometimes
      10-15-2020, 09:41 PM   #10
hmulf
Drives: M240i
Thx guys, interesting info...
      11-03-2020, 08:24 PM   #11
pmcmtnbkr
pmcmtnbkr's Avatar
106
Drives: BMW M235I
one of my favorite tracks. I spent most of my childhood in the infield and pits while my father raced Datsun 510s in the 70s and formula fords in the 80s what a great track.
      11-04-2020, 08:54 PM   #12
K8_M235i
K8_M235i's Avatar
Drives: CM E36
It is one of my favorites too. The town is awesome. I have 2 dollar bills from the Seneca all over the place in my car haha.
      12-02-2020, 11:47 AM   #13
Maynard
Drives: 228iX & M2C
Do you know if this issue also affect the first-gen M2 motors, or do they use the improved parts noted above?
      12-03-2020, 11:09 AM   #14
nioh_lbbm2
nioh_lbbm2's Avatar
1717
Drives: M2
All M2s have the upgraded oil system
Maynard3833.00
      12-03-2020, 09:31 PM   #15
K8_M235i
K8_M235i's Avatar
Drives: CM E36
Yes Maynard, they essentially use all s55 parts in the pan.
Maynard3833.00
      12-05-2020, 09:09 AM   #16
overcoil
Drives: M235i 6spd
Does the 10 degrees of banking present itself as a cause ?
      12-08-2020, 11:37 AM   #17
K8_M235i
K8_M235i's Avatar
Drives: CM E36
I believe the point of ultimate failure was braking+acceleration out of the boot. That is a hard braking section and then there is a ton of load accelerating up the hill.
N55s are known to lose the most oil pressure under braking.
overcoil3073.50
      12-08-2020, 07:06 PM   #18
dradernh
dradernh's Avatar
4348
Drives: 2017 M240i
You're thinking it was going into and out of the Toe where it occurred – or was it the Heel / T8?
FWIW, in terms of g-forces the braking zone into the Toe was the hardest-braking zone in my race car. I've never gone back to take a really hard look at max g-force data in the turns at the Glen, except to notice that it could move up and down quite in a tenth of a second and tapping a steep curb could create a value that had no meaning.
I was surprised the first time I looked at the data and saw that max longitudinal g-forces occurred braking for the Toe, because the braking and turn-in were helped so much by the steepness of the Toe that the transition wasn't much of an event. After thinking about it, I came to the conclusion that it was the steepness of the straight between T6 and the Toe that created the maximal g-forces.
Without any hard data available, the Carousel was my principal concern with my B58 – both for certain fuel starvation below ½-tank and for possible oil starvation.
      12-08-2020, 07:11 PM   #19
K8_M235i
K8_M235i's Avatar
Drives: CM E36
You're thinking it was going into and out of the Toe where it occurred?
FWIW, in terms of g-forces the braking zone into the Toe was the hardest-braking zone in my race car. I've never gone back to take a really hard look at max g-force data in the turns at the Glen, except to notice that it's moving up and down quite a bit by the tenth of a second and tapping a steep curb will send it sky-high.
Yes, I said boot, but as typed it I was picturing the toe in my head. The car bucked right as a got to the top of the hill out of the toe.
dradernh4347.50
