07-24-2020, 08:24 PM | #1 |
Rep 140
Key fob locked in trunk.
I know this has been discussed here before, but I have a different solution that might work for someone else.
The setup: 2014 228i. Parked in an airport garage a solid hour from home. My keys were in my bag as I went to my car. When I got close to the trunk, I was able to open it without taking my keys out. Then I threw my bag in the trunk, closed the trunk, and walked to the driver's door. That is when I discovered my mistake. In case you aren't aware, the car can not or does not sense the key fob when it is in the trunk. At least on my car. I've read that some newer cars have measures to prevent this from happening. At Boston Logan airport, MassPort has tow trucks that will come by and pop the door open for you at no charge. They were quick and nice and didn't damage anything. Call the Mass State Police barracks at Logan for that service. So, I was able to get into the cabin of my car, but the trunk release button would not work without the key fob being "seen" by the car. No fob = no power to the system. I tried every way I could think of to get the trunk to release, but no joy. Google and Youtube and even this forum had a couple of ideas, but they didn't work. Nor did BMW roadside assistance or the local dealers. No one had a solution other that to try to get into the trunk somehow. My rear seats are 60/40 split fold down, but there is no center armrest or pass through, so I couldn't reach the release lever, which is in the trunk, to get them to fold down. I couldn't go through the rear speaker holes because there is some structure underneath them that prevented me from reaching into the trunk area. I tried using a straightened coat hanger pushed through the gap between the seats to grab the emergency trunk release, but that was not working. The release is secured to the top rear of the trunk lid with a small tab and the handle lays flat against the trunk. When I was sitting there trying to decide my next steps, I saw a flashing light under the driver's side of the dash. I had forgotton I had a bluetooth OBDII adapter there that talks to my Torque and BimmerCode apps. I connected to the bluetooth, launched BimmerCode and about 2 minutes later my ignition turned on giving me power to pop the trunk. Success! So, if you don't want to hide a spare key on your car and you already have one of the OBDII adapters, just leave that in your car as the backup "key." I was able to start the car with the key still in the trunk; I checked just to see if it would work. That would have gotten me home or to a dealer or wherever if I had lost my key. I also checked to see if I could stand outside the car and get a connection. It didn't work, but I need to try a couple of other things to see if I can make it work. It looks like the OBDII port is not powered while the car is just sitting there. |
07-24-2020, 09:23 PM | #2 |
Rep 776
I never would have even thought of the possibility of the key getting stuck in the trunk. Wow.
It's always really frustrating standing there with the key literally inside the cup holder but the trunk absolutely will not open from the trunk handle. Not sure why BMW chose to do it that way.
M240i | Mineral White | Coral Red
07-24-2020, 11:16 PM | #3 |
Rep 251
Could Connected Drive (assuming you have it) have helped? Genuine question as I've only used it to see how much fuel I have left in the tank when I'm away from the car. I guess it would be of no help if you accidentally had your phone with the keys in the trunk!
If all else fails, every movie I've seen has showed me that if I just pull down on a panel under the steering wheel, the wires to hotwire the car are perfectly spliced and I just need to put two random wires together to get the car started. Give that a try. |
07-25-2020, 07:17 AM | #4 | |
Rep 140
For anyone who has been putting off getting a spare key, like me, go ahead and bite the bullet and do it. Yeah, it is expensive, but it could save you in the long run. |
07-25-2020, 08:33 AM | #5 |
Rep 744
Interesting. I've placed my golf bag in my trunk and closed it, only to have it pop open immediately. Was confused for about half a second, then extremely grateful when I realized my key was still in my golf bag!
How did you start your car with BimmerCode? It's been a while since I've used it, but from what I recall, I had to hit the start button in order for the OBDII adapter to work.
BM235iW97.00 |
07-25-2020, 08:40 AM | #6 | |
Rep 140
When I connected my phone to the OBD adapter and started BimmerCode it took a minute or two for the car to turn on. It turned on to the ignition position, not the accessory position, so all I had to do was hit the start button one time to start the car. I'm surprised it worked, but happy it did. |
07-25-2020, 08:45 AM | #7 |
Rep 246
I had a 1969 BMW 1600/2. It was impossible to lock the key in the trunk or cab. I thought that was pretty clever. Wish cars were like that now.
Jack |
07-25-2020, 10:01 AM | #8 | |
Rep 1,371
07-25-2020, 11:21 AM | #9 | |
Rep 204
07-25-2020, 08:01 PM | #10 |
Lucky13
212
Rep 1,762
Locked my fob in my trunk after running and throwing my wet gear back in the trunk without unlocking the doors. I was SOL but only lived 2.5 miles away and got an extra run in. Biggest issue is or was my phone was in my car.
1995 325i, 1996 328ci, 1997 528i, 1997 Z3 2.8, 2000 528i, 2001 X5 3.0, 2001 330i Convertible, 2002 M3 Convertible, 2003 M3 Coupe, 2004 M3 Coupe, 2004 Z4 3.0, 2004 X3 3.0, 2007 X3 3.0, 2007 335i Convertible, 2013 X1 28 sdrive, 2014 M235 manual, 2020 X3 30i Xdrive
07-27-2020, 10:54 AM | #11 |
Rep 278
I will share a simmalar story in case this also happens to anyone.
I had to disconnect the battery in the truck for a reboot. I by accident closed the truck. I had the fob which became useless without the car battery. The only thing that worked for me was to jump start the car with a power pack. It took a few tries but the car finally had some juice to open the trunk and reconnect the battery. why no manual trunk release or using the key in the fob to open. |
MLJR235116.50 |
07-27-2020, 04:21 PM | #12 |
Rep 1,219
Drives: 2015 M235ix
Did this happen with a 2018? My impression was that cars from 2015 on would not lock with the key inside, including the trunk. Or is is maybe having comfort access?
07-27-2020, 05:01 PM | #13 |
Rep 1,602
Jeez. I almost never use my rear seats. I think i might just roll around with them upright but unlatched so I can just yank em down from the front whenever i might need to access the trunk.
07-29-2020, 06:15 PM | #14 | |
Rep 86
Current: 228i M Sport
Former: E85 Z4 3.0, E89 Z4 35is, 28 others.... |
makrop151.00 |
07-30-2020, 11:28 AM | #15 |
Rep 278
I have tested locking the fob in the trunk with mixed results. 2018 F23.
if the fob is in a bag or a coat. sometimes it senses it. depending how deep it's in there. Dropping the fob in the trunk and closing it works. |
07-30-2020, 05:07 PM | #16 |
Luxury at the redline :)
9105
Rep 7,563
Only if you vehicle has Comfort Access does the vehicle detect a key fob is left in the trunk, its not specific to the model year, as they are all the same.
07-30-2020, 06:18 PM | #17 |
Rep 140
My car has comfort access, but it didn't help me. I'll have to try dropping just the keys in there and see if it works.
07-30-2020, 08:47 PM | #18 | |
9105
Rep 7,563
I figure that was the MO of Comfort Access, to prevent situations such as this.. Pahaps, the battery in the key fob might be low or just missed the communication.. |
08-02-2020, 08:00 PM | #19 |
Rep 12
I did the same in my 2016 F23 Convertible. The convertible trunk is pretty tight... I called BMW Connect and - get this - my dealer never changed the owner info with BMW NA. So I was SOL. At least I was at a Wegmans food store. So I got the sales manager to switch ownership info (it is a CPO). So the approved locksmith comes out. He opens the door with a slim Jim setup but can't pick the trunk lock. I get another guy he recommends to come out. He has a universal key programmer and universal OBDII hacker and pops the trunk by simulating a key command. I bet anybody with one of those can drive away no problem!
