Adjustable Front Caster Rod Monoball Bushings BMW F2X/F3X |
07-18-2020, 01:50 PM | #1 |
Supreme Allied Commander
3856
Rep 54,414
Drives: F80 M3
For those with F8x M lower control arms for added negative camber with wheel pushed back and loss of caster, this SPL adjustable monoball is a good option to the F8x M tension arm. No need for spacers/washer.
Bushing deflection is also reduced resulting in better suspension geometry under load and improved stability under braking. Caster is adjustable +/-4 degrees. More info here: https://www.2addicts.com/forums/show...8#post26454258 Last edited by HP Autosport; 07-18-2020 at 01:58 PM.. |
