| 05-17-2020, 02:03 PM | #1 |
![]() 166
Rep 181
0w20 Oil Concerns
I知 not looking to fire up another debate about oil but Im getting ready to do my first 5k oil change on my M240
My concern is that the recommended 0w20 is too thin. I have owned many BMWs over the last 20 years and have always used Castrol 0w40 oil with no problems. I live in a hot weather climate and I don稚 think that a thin oil will stand up. I知 thinking that BMW recommends this oil for increased fuel efficiency. But I知 not willing to have premature engine wear to achieve a 0.1 mpg increase. |
| 05-17-2020, 02:26 PM | #2 |
Rep 264
I changed our M240i to BMW
TwinPower Turbo 0w30 (gas version of course) at about 1200 miles because of my concern over the recommended factory fill 0w20. Still warranty friendly since 0w30 is listed as an acceptable alternative weight. |
| 05-17-2020, 02:32 PM | #3 | |
![]() 65
Rep 86
Always difficult to know
The other consideration, IIRC, the B58 has always been spec'd with 0W-20, so the size of the oil passages and pressures should have all that taken into account. (Now in an S54, for example, then you want a much higher top viscosity, but that's a 20 year-old unrelated design to your B58.) In reading up on the various BMW OE oils (which are made by Shell/Pennzoil), it looked to me that FE17+ was better than the FE14+ in that the 17 had lower residual ash (i.e., better for DFI motors.) Something like this: https://www.getbmwparts.com/p-b58-en...and-on-pkb58oc So yes, I understand your concern about the oil being too thin, but what's the evidence that the 20 is "too" thin? If it were me, I'd use a FE17+ change kit, and send in a sample of your used oil to see what a lab says. Then you'll know what was going on, and you can ask the lab questions about how well the original oil fared. HTH. |
| 05-17-2020, 02:38 PM | #4 | |
Rep 1,268
The conclusion I reached is simple: as long as I am under warranty I will let BMW stick to their recommendations and let the dealerships do the oil changes. I follow the 5000 mile change schedule and changed it at 1200 as well. However after going through BobTheOilGuy forums I am fine with 0w20. People say that shitty CAFE standards are the reason BMW shifted to the water like 0w20 but, really, they aren't in the business of being called unreliable. Trust their engineers and the tolerances they build in the engine, and the tolerances they account for, instead of letting your own intuition guide you. |
| 05-17-2020, 02:42 PM | #5 | |
![]() 4858
Rep 3,653
From my 2017 Owner's Manual ![]() BMW's current recommendations: https://www.newtis.info/tisv2/a/en/f...enance/1PSryV8 and https://www.newtis.info/tisv2/a/en/f...nce/1VncAYo9NI A note from FCP Euro on this page: https://www.fcpeuro.com/products/bmw...11428583898-lm "New BMW's fitted with BXX series engines "Require" 0W-20 LL14FE+ Rated oils. WE DO NOT RECOMMEND using this spec! The levels of protection LL14FE provides are much lower than LL01. The new formulation LL14FE is mainly designed with CAFE ratings, EPA requirements and fuel mileage in mind, NOT OVERALL PROTECTION."
2017 M240i: 26.5K, 28.9 mpg, MT, Sunroof Delete, 3,432#, EB, Leather, Driving Assistance Package, Heated Front Seats | Sold: E12 530i, E24 M635CSi, E39 520i, E30 325is, E36 M3 (2)
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9ス ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; Full PPF |
PeanuKeeyes378.50 BimBimM21482.50 |
| 05-17-2020, 07:08 PM | #6 |
Enthusiast
89
Rep 229
Ow-40 isn't going to hurt it. Use it if it makes you sleep better. I have been using it for years in n55's, both Castrol and mobil 1 varieties.
You are correct, it is all about MPG. I like the switch to the BMW 0w-30, it is designed for our more modern turbo charged engines. Keeps the approval rating etc. Seems like an ideal compromise to me. You will get all kinds of answers to this, so will have to cut thru the smoke and do what makes sense to you. Your car won't blow up with any of the choices.
_______________________________________
2018 M2 |
| 05-18-2020, 12:11 PM | #7 |
4934
Rep 4,340
Although the manual says that other grades of synthetic can be used besides 0w20 and 0w30, that is only for a maximum of 1 litre when the oil level is low.
Using a 0w40 oil will likely not cause a problem, but engineering wise the engine was designed for 0w20, so 0w40 when hot will have lower flow rates and hence less cooling of areas with tight tolerances than the thinner 0w20. Bearing areas and oil passages are also sized for the thinner oil, so there is unlikely to be any risk of metal-to-metal contact. Also bear in mind that standard ATF fluid has a lower viscocity than 0w20 oil and in vehicles under high towing stress will reach temperatures equivalent to engine oil under hard use. The contact point between gear teeth is a smaller area than in the big and small ends in the engine with the oil under much higher pressure between the teeth and no issues with wear. |
dradernh4857.50 |
| 05-19-2020, 07:29 AM | #8 |
![]() 633
Rep 1,292
Drives: 2015 M235ix
I will never cease to be amazed by folks who think that the manufacturer, particularly BMW, got it wrong, especially when it comes to motor oil. The name of the company is Bavarian Motor Works. They have depended on their reputation for building great engines for almost a century. Why on earth would a single individual, presumably one who does not design internal combustion engines for a living, decide to second guess BMW's recommendation for the viscosity of the oil in their engine?
And then there is the conspiracy/compromise aspect of the argument: they design the engine to run 50,000 miles, because after that it is the owner's problem. Being totally unprovable, it is exactly the sort of thing that conspiracists love. If anyone needs any hydroxychloroquine, I will sell it to you at the right price, along with a large supply of masks that I don't need any more. |
Xi-Xi39.00 |
| 05-19-2020, 07:51 AM | #9 | |
Rep 1,268
| 05-19-2020, 12:11 PM | #10 |
Rep 2,212
I personally wouldn't put 0w20, 5w20, 0w30 in these cars. Thinnest should be 0w40, next to 5w30. BMW did revise these at some point to 0w30, but I'm not running winter temps so I stick with what came with the car. 5w30 LM and no concerns.
| 05-19-2020, 01:29 PM | #11 |
![]() ![]() ![]() 173
Rep 400
I run BMW 0w20 in winter and castrol 0w40 in summer.
As an engineer, I should trust their spec but I know sometimes (or many times) engineers pushed by upper management to prioritize wrong things. I am wondering what S58 engine uses. |
| 05-19-2020, 02:17 PM | #12 |
![]() 166
Rep 181
I’ve done a little research and found that the US is the only country that 0w20 oil is recommended. All other countries run regular viscosities. Seems to be driven by CAFE standards and fuel efficiency
Comes down to engine protection vs fuel efficiency |
| 05-19-2020, 03:14 PM | #13 |
![]() 633
Rep 1,292
Drives: 2015 M235ix
Intriguing that only US requires this viscosity.
Do all other markets have a single recommendation or does it vary further? Just curious. |
| 05-19-2020, 03:31 PM | #14 | |
Rep 422
| 05-19-2020, 03:35 PM | #15 |
![]() 166
Rep 181
| 05-19-2020, 03:43 PM | #16 | |
![]() 4858
Rep 3,653
| 05-19-2020, 04:05 PM | #17 |
4934
Rep 4,340
Standard UK, Canada and EU market oil for the B58 engine available from BMW dealers is 0w30 Twin Power Turbo Gold LL-12FE, but the owner's manual lists 0w30 LL-12FE or 0w20 LL-14FE as the correct oil for a complete fill. LL-01 rated synthetics in 0w30, 5w30, 0w40 and 5w40 are stated as suitable for up to 1 litre top-up between oil changes.
| 05-19-2020, 04:27 PM | #18 | |
Rep 1,268
| 05-19-2020, 04:42 PM | #19 |
Rep 204
Just brought my car in for its last oil change included in the initial maintenance program. The SA recommended 0W20 especially since I only have 15.5K on the car. He said moving up to 0W30 in Northern CA wouldn't make much of a difference. Until the car gets 40K on it or you move to a desert, 0W20 should be just fine. If it became a track car, then that's an entirely different discussion. Seems to be consistent with what we have been saying on this thread.
| Bookmarks |
| Thread Tools | |
