TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Anyone tried 255 tires in front?
Reply
      09-17-2008, 01:56 AM   #1
scheherazade
Drives: 09 GTR (& 93' accord!)
Just wondering if anyone has mounted 255's in front.
I know 245's fit... so maybe 255's would too.
(( I ask because there is a deal ($) on 4 255's. ))
-scheherazade
      09-17-2008, 10:16 AM   #2
UdubBadger
No_Country
633
Drives: '04 330i ZHP
2004 BMW 330i ZHP  [9.50]
2011 135i  [7.46]
2008 328xi  [8.76]
not sure but i KNOW 265 will rub... stupid tire shop put one of my rear staggered wheels in front when i got my 19's installed.
maybe you can still buy um and just sell 2 as rears?
      09-23-2008, 01:15 AM   #3
battlehawk1025
battlehawk1025
battlehawk1025's Avatar
Drives: 2007 335XI 6mt, SL 65 , M6
i'm wondering the same thing, where talking about the stock sport package 18 inch rims right
      09-23-2008, 03:35 PM   #4
scheherazade
More or less.
Or V3's set at default height.
-scheherazade
      10-16-2013, 01:36 PM   #5
Tom Martin
Drives: 2012 BMW 335xi and 2011 Z4 Sdr
255 tires
I'm running Bridgestone Pole Positions on my 2012 335i Xdrive all the way around and they fit just fine!
      10-16-2013, 02:37 PM   #6
jpjp
Drives: BMW 3
I'm running 255/18 Kumho Ecsta on all 4 corners on 4 OEM rear wheels. The fronts are close but don't touch.
2008 335xi Sport
JP
      10-18-2013, 02:45 PM   #7
NeoNz
335 Newbie
NeoNz's Avatar
Drives: 2011 335i xDrive
Anyone lowered run 255? I have 275 out back on my 19s and they rub, have to get my fenders rolled soon!
2011 BMW 335i xDrive, 12.2 @ 111 (e90 N55 XDrive Record)- Sold
Stage 2, Map 7/e85 mix, JB Intake, Vishnu Catted DP, ETS FMIC, CPe Chargepipe
1994 Toyota Supra, Baltic Blue, 6-speed, mods... FOR SALE
1200rwhp/875rwtq, 3.4L Stroker
      10-18-2013, 03:36 PM   #8
Carl Morris
Drives: 2008 335xi 6MT
2008 335xi Sport
JP
How do they look? Do you run a spacer in the front? I've thought about going square with 8.5" 162s, and running spacers on the rear only if it looked right.
      10-20-2013, 05:43 PM   #9
Yvette
Drives: M
255 on stock definitely fit
      10-29-2013, 09:12 PM   #10
jpjp
Drives: BMW 3
2008 335xi Sport
JP
The front looks better then the rear because it comes closer to the outer fender. I'm running without spacers but I may try a 5mm. The rear needs a bit more to get the wheel to fill the wheels well.
I've always run a square setup with 255 F/R. Did it on my E46 330 for 5 years. I like the look, the ability to rotate, and the handling change.
I just mounted my rears up front to check fitment before I ordered rims and tires.
JP
      10-30-2013, 05:16 AM   #11
ajsalida
ajsalida's Avatar
226
Drives: 95 M3, 02 R1150GSA, 09 335xi
Pics? I might go with this on stock 189's if I can find a rear pair cheap.
      10-30-2013, 06:18 AM   #12
ashmostro
Drives: 2020 M4cs | 2022 M550i
if lowered, they need some camber - and it depends on the actual section width of the tire as that varies from brand to brand.
but they *can* fit. no guarantees without testing though.
      10-30-2013, 07:54 AM   #13
jeffblue
Drives: 2008 BMW 335xi
255 will fit up front depending on wheel offset. Too low and you'll rub on the fender and too high and you'll rub on the strut. assuming you are running an 8.5 or 9 with anything close to the stock offset or 10-15mm lower, you should have no problems. I am going to be running a square setup this spring of 18x8.5 313 18" wheels with 255/35/18 PSS with a 10-12mm spacer. based on my calculations it will work with plenty of room and i am lowered on kw v3.
I hope you're putting these on an 8.5+ wheel up front. 255 is too wide for an 8" stock wheel.
      11-01-2013, 12:07 PM   #14
IN54NITY
Major nutz
IN54NITY's Avatar
Drives: '09 n54 e92xi, 6mt, kw v3
2009 335xi  [8.89]
Front rubbing depends on camber. I run 265/35/18 at all 4 with Yoko AD08s and track it extensively with no rub. 2.8d camber affords me no rubbing whatsoever up front. I get some rubbing with >200 lbs in back seat (so I can't put the in-laws back there when I track), though I think it would go away with a fender roll.
http://www.apexraceparts.com/EC-7-18...e-2_p_159.html
Wheels specs: 18x9" ET31, 5x120mm, 72.6mm cb
Tire spec:
http://www.tirerack.com/tires/tires....D08R&tab=Sizes
Hoosier in 255 is same width as AD08s in 265 so that is as wide as you can go with the purple crack (I love the purple crack):
http://www.tirerack.com/tires/tires....R8R6&tab=Sizes
Here's a recent pic with the 265 AD08s being "driven" by an unknown man on a dynamoter during an emissions test we all have to suffer on the Colorado front range.
KWs - Vorshlags - APEX EC-7s - "My garage" has suspension install pictures.
_____________________
      11-01-2013, 12:19 PM   #15
ajsalida
ajsalida's Avatar
226
Tire spec:
Cool. I looked at your garage pics, what are the sizes on the tires in the pics on the street. Those look like OEM 19's? Also what is the front camber in those pics. That stance looks fantastic.
Any issues with excessive wear @ -2.8? How about harshness on the street with the Vorschlags?
      11-01-2013, 12:33 PM   #16
IN54NITY
Major nutz
IN54NITY's Avatar
2009 335xi  [8.89]
Thanks! Yea, those are a set of 19" BMW style 230s (offered as OEM at one point) that I bought used. (Also bought the brakes used.) You know the only thing going for those wheels though are looks, they are heavy and don't ride nearly as nice as 18s. I have to be careful driving around the street with those. Pic was taken with -2.8d up front, -2d back.
AJ, "excessive" and "acceptable" are subjective I guess. I have 1/8 toe in, maybe even a little less, so I believe I get acceptable wear. I have more wear on the outside shoulder from, um, turning "spiritidly" and I can also rotate all four. So I even drive winter at -2.8d. I only drive maybe 500 miles all winter, so that probably has an affect on "acceptable". Vorshlags do make some noise and add some discomfort. My car sounds like a truck from inside too because I removed the head cover and the "tray" (for heat evacuation and because I got lazy - I change my brake fluid a lot). As long as it's acceptable to my wife, it's acceptable to me.
      11-01-2013, 12:53 PM   #17
ajsalida
ajsalida's Avatar
226
Thanks for the comments and quick reply. Really like the looks of that, same color as my car though I have black interior. I live in Pagosa Springs on a dirt road, even the paved roads out here are terrible. I would need back surgery with your set up in a week.
I wish I lived near a track like you guys do but I would not like the front range craziness.
What kind of brakes are those anyway, at first glance I thought you just painted the calipers.
      11-01-2013, 01:07 PM   #18
IN54NITY
Major nutz
IN54NITY's Avatar
2009 335xi  [8.89]
I bought these very ones. http://www.e90post.com/forums/showthread.php?t=618154 They took care of my "smelting" problem. If I ever go to Monarch/CB to ski/bike etc, I may look you up. You can drive the car. (Just not on your WWI driveway.)
      11-01-2013, 02:09 PM   #19
ashmostro
I have bbk envy!
      11-01-2013, 02:30 PM   #20
ajsalida
ajsalida's Avatar
226
Those are shweet!
      11-01-2013, 05:31 PM   #21
ajsalida
ajsalida's Avatar
226
Definitely do that, I'd love to drive your car. Probably make me get an MT. I am closer to Wolf Creek though, Monarch and CB are quite a drive away from Pagosa esp in winter.
      11-01-2013, 05:57 PM   #22
IN54NITY
Major nutz
IN54NITY's Avatar
2009 335xi  [8.89]
Ooops, I just noticed you are in Pagosa, I thought you were in Salida. I hear Wolf Creek gets snow every once in a while (tongue in cheek), I am attracted to that like a moth to a light. I did go to this this year: http://drive4corners.com/index.php/about-the-meet/. Pretty cool, I got to drive the Orange 2000 touring... I swapped cars with that owner with the drive up to Wolf Creek. http://drive4corners.com/index.php/2...ent-in-review/ My first Bimmer was a 2002. I don't know if I can make next year, kiddo on the way.
Last edited by IN54NITY; 11-01-2013 at 06:20 PM.. Reason: Correction: 2000 Touring, not 2002 Touring
Reply
