BMW 3-Series (E90 E92) Forum
Active Steering or no Active steering
04-10-2005, 11:45 PM | #1 |
Rep 200
Hi all...I was wonder whether or not to get active steering.....from what I know...it assist you in turns and chages turning rate at different speeds to have better control.....is it a good option and is it worth it???
04-10-2005, 11:53 PM | #2 |
Rep 27
From what I've read around the forums, I think most people will say no. I think it's a good technology and it comes down to whether the driver is willing to re-learn how to steer a little bit. I just recently read a review of active steering on the new 5 series (E60), here's what the review from automobile mag had to say:
"Active Steering is perhaps the most significant new technical achievement. This system, part of the optional Sport package, electromechanically adds a positive or negative steering angle to the setting chosen by the driver, via a planetary gearset integrated into the steering column. This reduces steering motion at low speeds (say, while parking) and when negotiating tight turns on curvy roads, requiring only two turns lock-to-lock rather than three. It also makes the steering much more direct at high speeds. Driving two 5-series-one equipped with Active Steering and one without-back-to-back on an autocross course, we found the car equipped with Active Steering allowed us to hustle through much more quickly and with far less understeer than the car with BMW's conventional, but still excellent, rack-and-pinion setup. (The 540i's recirculating-ball steering is history.) On twisty seaside roads, it takes a little getting used to, because you're expecting to have to cross your arms a lot more than is actually necessary, but the results are noteworthy. Philip Köhn, Active Steering project manager, maintains that the system "is such a huge leap in technology, it's comparable to the introduction of ABS." What does everyone else think? Has anyone actually driven a car with this technology (i.e. E60)?
!!!! BMW 330Cic 2008 edition !!!!
04-10-2005, 11:59 PM | #3 |
Rep 200
Thanks jpv-USC, I appreciate the review, but I am afraid of driving on a windy road with active stearing, for fear of not knowing the new steering and overturing....what is your personal opinion??
04-11-2005, 12:52 AM | #4 |
Rep 37
IMHO, you won't miss a lot if you're not taking it... I would even say that you'll be less isolated from the road as you'll be able to feel it much more with a 'conventional' system... that is one of the best.
The way I understand it is the following one, conventional system means that the car reaction is easily predictable, active steering means you have to adapt yourself to the car settings permanently which could be felt as disturbing... So no active steering for me! |
04-11-2005, 02:29 AM | #5 |
Rep 200
Good...I didn't order it in my car, I didn't want to be so used to my car that I can't drive other cars the same way. Thanks for your opinions fellas...I really appreciate it.
04-11-2005, 09:04 AM | #6 |
Rep 242
I think it's one of those things where if you don't have it you won't even miss it because steering will be just like any other car. Of course if you have it for a while and get used to it then you may miss it when driving another car. I say don't get it at all and avoid all this hassle
04-11-2005, 01:21 PM | #8 |
Sport Geezer
28
Rep 116
The latest Roundel reports that the newest version of Active Steering - found on the E90 - is an improvement over the older systems that started on the new 5 Series cars. I would pass on the option.
04-11-2005, 04:09 PM | #9 |
Rep 19
There are some things that technology just shouldn't touch, and steering is one of them. The car manufacturers are starting to get a little too techno-happy.
04-15-2005, 01:48 AM | #10 |
Rep 1
I have a 2003 Z4 3.0 in argentina with active steering , an i love it, i the best for drifting and fast driving.an i have a 330i SPO Manual transmittion without active steering , and is more easy to drive. i woud recomend active steering for advanced drivers or people who drive the car real fast and without traccion control.
04-15-2005, 11:44 AM | #12 | |
Administrator
6731
Rep 4,201
I think active steering is one of the best new ideas out for cars in a long time. in my mind its really a big leap forward and cant wait to try a car with it!! this is not a case of techno happy, this is putting modern technology into the driveline, this is as big a move forward as the Z link rear suspension was. |
04-16-2005, 09:43 AM | #13 | |
Rep 53
04-20-2005, 06:12 AM | #15 |
Administrator
40924
Rep 21,240
For those not yet familiar with Active Steering technology, here's an overview from BMW.
Active Steering Active Steering gives drivers more precise handling and tracking: this ensures that their automobiles are more mobile and agile even on twisting roads. A planetary gear is integrated with the steering column; depending on the situation, the feature varies the angle of steering determined by the user at the wheel (superimposed steering). It increases the steering angle at lower and mid-range speeds; by contrast, at higher speeds (e.g. on motorways), the steering angle is reduced. When parking, the active steering feature makes it easier to manoeuvre by amplifying the movements of the steering wheel. |
04-21-2005, 05:45 AM | #17 |
Rep 260
Nor me. i think it's just a fancy, expensive, unecessary option.
04-21-2005, 06:35 AM | #19 |
Rep 1,128
I have Active Steering on my 545 with sport package. It works as stated by BMW. It is a luxury feature. In my opinion it has no business on a 3 series or any car driven by a hardcore enthusiast. It is expensive and unnecessary. On the other hand it is not as bad as some claim. It is quite subjective and best offered as a stand alone option.
04-21-2005, 10:02 AM | #20 | |
Rep 44
04-22-2005, 04:41 AM | #21 | |
Rep 1,128
