BMW M2 Forum > Regional Forums > UK > How can I avoid dazzling on-coming drivers in France?
      02-11-2020, 09:47 AM   #1
LondonM2
Drives: M2C
I have just taken my M2C to France for the first time and I appear to be dazzling on-coming drivers at night. My car has Adaptive LEDs and there is nothing in the handbook about adjusting the beam pattern for driving on the right. I have had a good look on this website and elsewhere but have found nothing conclusive. The dip cut-off is definitely higher on the left side, both with the master switch to automatic and set to ordinary headlights. About 1 car in 5 is flashing me on single carriageway roads, which is way too much for comfort. I haven't asked the dealer as I recently had to threaten court action to get a refund for unscheduled work.
Des anyone have a solution for this? Many thanks.
      02-13-2020, 10:24 AM   #2
verysideways
Lateral grip estimator
verysideways's Avatar
957
Drives: i4, M2
Handbook shows this... not amazingly helpful!
'20 BMW M2
'23 BWM i4 Mora
'10 Porsche 997
'02 Morgan Aero 8
http://petrolhead.tours
      02-13-2020, 12:15 PM   #3
LondonM2
Drives: M2C
Thanks for the reply. As I understand it, the Adaptive LEDs just swivel the lights left and right; the beam pattern is unchanged. I did a test last night and the 'normal' headlights on switch position has both lights pointing straight ahead. When you change to the 'A' position, the lights diverge, with the left light turning left to illuminate a UK kerb. When you go round corners, the lights follow the steering so you can see where you want to go.
The problem with this is that the dip cut off is not flat - it is higher on the left - so even in 'normal' position, I am irritating oncoming drivers. It looks like there is no easy fix. Bummer.
      02-13-2020, 02:08 PM   #4
widetyres
United Kingdom
279
Drives: M3 E92 DCT, 2012
There's the old fashioned way! - a sticker on the left side light.
      02-20-2020, 01:11 PM   #5
too hot
too hot's Avatar
Scotland
113
Drives: None
Even older fashioned stay home
RS4
m2
