10-31-2019, 02:09 AM | #1 |
Rep 187
LSD with FD change
I'm going to get the M perf LSD around next April and I'm thinking of additionally swapping in a 3.46 final drive from the M2
What I gather is that the LSD is sealed and you cannot swap out the 3.077 final gear. So my only options are to buy from Diffsonline, Quaife or get a wavetrac LSD and add the 3.46 FD?? Last edited by goodNIGHT; 10-31-2019 at 04:39 PM.. |
11-02-2019, 07:56 PM | #2 |
Rep 5,374
Theoretically you could swap in a different gear, but it would be far cheaper to buy from Diffsonline.
I too considered the 3.46 gear, but keep in mind that the overall diameter of the 19 inch tires used on the M2 are nearly 1" taller than the M235 18" tires. That means the M2 gearing is more like a 3.23 on the M235, all things considered. Meaning, running a 3.46 on an M235 with the stock height 18s would be like running nearly a 3.7 gear. To me, it sounded like fun and would make the car really responsive. However, these cars make a lot of torque, especially tuned, thus aren't remotely as dependent on torque multiplication like an a high revving NA motor. I ended up going with the MPerformance LSD (3.08 FD). I like the longer gearing as I find it more tractable with a tune. Plus, I saved about $1200 going with the MP LSD over something from Diifsonline. |
11-03-2019, 03:01 AM | #3 |
Rep 130
I like the 3.46 FD in my Wavetrack a lot! Not because of torque multiplication although its nice too. The 3.46 allows you to move through the rpm range, hear the terrific engine and high rpm sound. All while commuting. I like it best when the summer tires were almost worn. And least with winter tires at 245/40. Means I could probably go higher than 3.46.
Speeds are so slow in the US that the drive ratio change is no problem. If I were on the autobahn I wouldn’t do it . What I would like is a seventh gear. Or change the ratio just of the last, sixth gear in the manual gearbox. This would help a lot for long stretches of highway driving. Must be very costly or near impossible. Anybody come across it?
[FONT="Arial"] M235i 6 speed, MGM. Wavetrac LSD with altered final drive ratio, MPE, MPK Airbox, side skirts, diffuser, Dinan springs, LCAs.
goodNIGHT106.50 |
11-03-2019, 11:45 AM | #4 |
Rep 187
So i had to look at some other cars and compare.
I listed the FD and looked up the drive wheel tire diameters, then standardized the FD ratio to tire size. So the M235i is still set up to be a daily cruiser than sports coupe. Last two columns are the Hp/Tq FD multipliers. * sorry i wrongly swapped the hp and tq columns* Really illustrating how our FD does not exploit our power. Our cars lag greatly behind the other sports cars. A 3.46 ratio would bump us up to 1107/1141 hp/tq. But we'd still be behind the other cars in this group. And yeah exactly - I don't think its so much about torque multiplication anyway, as so much as staying in the power band and especially increasing throttle response. I can see both of your points - The M LSD is cheaper, is clutch type and it wont negatively affect resale. But the lockups % and less aggressive make it limited. The Wavetrac is reliable and offers more aggressive gearing. But it is more expensive and I wonder who will buy this car with a 3rd party LSD??? |
11-03-2019, 01:48 PM | #5 |
Rep 5,374
Just keep in mind the power curve. NA motors and high strung 4 banger turbos rely heavily on torque multiplication to get into and stay in the powerband. An N55, especially a tuned one, had a very broad torque curve which means the torque compensates for the lack of gearing and it allows for less shifting in a track situation.
On a drag strip, I doubt a deeper gear set will make much of a difference. It will certainly feel faster by the seat of the pants. I think the 6MT N55 M2's gearing feels perfect and it's effectively a 3.2x compared to my M235's 3.08. I just couldn't justify the cost over the MP LSD. Plus a clutch based LSD, especially the one built by Drexler for BMW, is so damn good for the street and light track duty. Lockup percentages are perfect. They are more aggressive than you'd think. Totally changed the car. |
11-03-2019, 02:14 PM | #6 |
Rep 187
In the above clip I'm on buttonwillow here in SoCal. I'm behind a CTR, mustang GT and 991.1 Porsche. On the first right hander you can see how much they pull out from me. It frustrating bc I just can't do anything about it. They must be pulling at least 1 second just in that one turn. That turn is taken in the low 30mph range. I was hoping to dig out of there with a quicker FD. There's one more turn on track that's complete LSD dependent. |
jondagger90.00 |
11-03-2019, 02:17 PM | #7 | |
Rep 187
So many limitations on this car 😩 |
11-03-2019, 10:53 PM | #8 |
Rep 130
Its not a giant change with the M compared to my wavetrac. I am sure you will be happy. My other BMW spins to 14600k and I just changed the final drive ratio - I guess I like high rpms
For me this is all about fun versus cost. Compared to costly carbon pieces you get a lot of improved fun for street driving. Just saying. Its a manual, those are desired and a non M LSD is probably not a big issue for selling. Tuning the engine is more of a concern for me if I would get a used M235i. Just my thoughts.
11-04-2019, 11:19 AM | #9 | |
Rep 5,374
jondagger90.00 |
11-05-2019, 08:34 AM | #10 |
Rep 373
is it at all possible to fit an m2 diff to the 235/135? i have seen one at a breakers yard for sale
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
11-05-2019, 12:33 PM | #11 |
Rep 187
11-05-2019, 12:50 PM | #12 | |
Rep 187
Ill be running a final baseline run at the end of january at Buttonwillow. Then install the LSD and compare lap times, sector times, and feeling impressions in March While I've conceded to getting the MP LSD, i know Id get better performance from the more aggressively geared Wavetrac. There is a reason why the Mustang PP1 is given a 3.77 FD and 275/35 rear tires over the standard GT. Regardless, im guestimating about 2 seconds in lap time reduction with the LSD. I really hope |
03-23-2020, 11:48 PM | #15 |
Rep 187
04-02-2020, 04:12 AM | #16 | |
Rep 3
Still waiting!!! Last edited by smithclarkson02; 04-03-2020 at 04:47 AM.. |
11-11-2020, 01:36 PM | #18 |
Rep 1
Does anyone know if the F30/F32 MP LSD will fit our cars? They are on crazy deep sale right now and I'd love to get one if they will fit. Also, are there major differences between 6MT and ZF8 other than gear ratio? If the housing, input shaft, and output shafts are all the same this should theoretically work with the M235i/M240i. jiofi login forpc
11-11-2020, 03:07 PM | #19 | |
Rep 5,374
