BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Bmw 335d engine tuned
Reply
      08-21-2008, 05:06 PM   #1
iwant335i
iwant335i's Avatar
Drives: 550i
Exclamation Bmw 335d engine tuned
What are other tuning options for 335d except chiptuning and im talking about engine tuning to increase performance ?
      08-21-2008, 05:14 PM   #2
mikem
Drives: Z4M
Do you mean in place of the remapping or after its been optimized ?
      08-22-2008, 01:56 AM   #3
CD
gone ... but i will be back !
CD's Avatar
England
62
Drives: 335D Coupe
larger uprated intercooler ... expensive though and approx 20bhp gains.
E92 335D / QUAIFE LSD / EIBACH / DIMISA / REMAP / 19" HAMANN EDITION RACE REPS
... USUALLY WITH A HEALTHY SPLATTERING OF GOOD OLD YORKSHIRE MUD ...
      08-22-2008, 05:55 AM   #4
Serjames
Serjames's Avatar
United Kingdom
128
Drives: E93 335i M-sport
uprated exhaust sytem...
I.e. Free flowing - Performance Particulate filter etc VERY expensive I would think, but probably the biggest gains to be had.
Matched with a good open filament air intake I would imagine you could see at least 20 30 hp.
I doubt the intercooler would have THAT much of an effect, has it been tested ? Seems to me the stock jobbie is pretty good, given the low volumes of air the turbos are actually pushing and the relative CRAP-NESS of our cold air.
Even on the petrol model the intercooler is a bit of a doubtful mod, Eugen seems to have had good results... Let's see what Tony's does. Tone you gonne get dynos before the intercooler with the re-map so we can really get a good benchmark ? Remember you'll need to let the car adapt to the new map too, so we're talking at least 50 70 miles between remap, dyno etc
SJ
      08-22-2008, 05:59 AM   #5
E92Fan
Moderator
E92Fan's Avatar
United Kingdom
322
Drives: .
SJ
Yes matey - will be doing that. But the remap will be with intercooler, so we won't necessarily know the improvements the intercooler gives exactly.. unless we go the long way round of dyno standard, dyno mapped, then dyno with map and intercooler...
      08-22-2008, 06:24 AM   #6
Serjames
Serjames's Avatar
United Kingdom
128
ahh, that's what I thought...
To be honest it might seriously be worth doing it the long way around otherwise we've got no base line for the re-map on it's own..
And if there is a problem you won't know what is causing it. i.e. too many variables... trust me I speak from experience as a Huge Birds bill will testify. I'd change one thing get it right, test it, and then put the Intercooler on. It's not like they're far away for you eh ?
SJ
      08-22-2008, 07:20 AM   #7
MOB
MOB's Avatar
England
56
Drives: Alpine White M2 LCI
Best thing to do is visit Pistonheads forum and ask their advice on tuning the 335d..................
      08-22-2008, 09:13 AM   #8
CD
CD's Avatar
England
62
Drives: 335D Coupe
... carlos get on with it
      08-22-2008, 09:44 AM   #9
mikem
Drives: Z4M
PMSL.
      08-22-2008, 03:18 PM   #10
CrimsonRedE93
CrimsonRedE93's Avatar
United Kingdom
108
Drives: Le Mans Blue E93 330d+
      08-22-2008, 03:30 PM   #11
dxb335d
The Tarmac Terrorist
dxb335d's Avatar
England
949
Drives: 997.2 GT3
it wont give any gains unless the map is altered. The stock item is sufficient on a re-map.
997.2 GT3
      08-22-2008, 04:35 PM   #12
Budgie
Budgie's Avatar
England
30
Drives: X1 25D M sport
Might even ask them whats the fastest 320D too lol...im mates with Carsplosh ....does it mean ill get labelled too lol.
      08-23-2008, 04:18 AM   #13
Ant397
Ant397's Avatar
United Kingdom
45
Drives: X5 4.8is, Lambo Gallardo
Im afraid intercoolers on Diesels do make a difference mate. They lower the charge temperature of the air, thus making it denser and thus increasing power. Diesels love large Intercoolers, we have a double core item that we supply. The origonal design was made for our first 304bhp 330d back in 2004, but they fit even the 184bhp 330d and the current E90 330d...
      08-23-2008, 04:26 AM   #14
dxb335d
dxb335d's Avatar
England
949
Drives: 997.2 GT3
Oh right. so the stock intercooler is bang on its limit on a mapped 335d ant?
I thought a larger one would only been needed if the current one was not upto the job. If the stock item wasnt surely limp mode would be seen quite often on a hot day?
997.2 GT3
      08-23-2008, 04:40 AM   #15
Dave_3
Dave_3's Avatar
Scotland
652
Drives: G22 M440D
Limp home mode will not activate because the air intake temparture is slightly warmer. Not even you could get you car to limp home based purely on a stifling hot and humid day compared to a crisp winter's day.
Having slightly hotter air (by a few degrees) is not going to overheat any of your engine components, which may run in a relatively much, much higher temperature range by default anyway.
It will reduce the efficieny of the burn cycle, reducing power slightly.
D.
Escort Mk1 RS2000 (2.1 2x44IDFS, BVH, Kent FR32, 5spd, 180 BHP) : M440D ¦ Previously : F32 435D : F32 430D M Sport sDrive, 335D E92 2006
      08-23-2008, 04:53 AM   #16
mikem
Drives: Z4M
Surely if its too cold `tho it will also reduce efficiency ? Isn`t this why diesel consumption goes up slightly in the colder months ? With an air to air intercooler if you increase the size of the intercooler, surely the boost pressure will drop in relation to the increase in volume of air ?
      08-23-2008, 05:28 AM   #17
roofer
roofer's Avatar
United Kingdom
21
Drives: 335D M Saloon
Cold air has more oxygen.....always helps.
Once the intercooler is 'full' the pressure is unaffected? Or am i having a thick moment?
      08-23-2008, 05:36 AM   #18
Dave_3
Dave_3's Avatar
Scotland
652
Drives: G22 M440D
I'm not familiar with the relative change of denisty of air due to temperature (while since I dabbled with Boyle's law), but it is also worth considering the density of air entering - as even if the volume remains constant the actual density will increase at lower temperatures = more potential energy.
I suppose it will also depend on your air intake velocity, but with the venturi arrangements a lot of intakes have I'm not sure the effect of lessening backpressure if your intake diameter (due to larger bores internally) would have a big effect on actual intake velocity. As long as your air meets the intake at roughly the same velocity, but cooler then it is worthwhile.
All back of the envelope assumptions - I don't have direct experience with Diesels and intercoolers.
D.
      08-23-2008, 05:45 AM   #19
mikem
Drives: Z4M
Not really sure. Boyles law states that Pressure x Volume remains a constant but that assumes the temperature is unchanged.
      08-23-2008, 05:53 AM   #20
ChrisMWard
United Kingdom
14
Drives: E93 320d M Sport, E81 116d SE
2006 120d SE  [0.00]
2007 335d A M Sport  [0.00]
1998 M3 Evo  [0.00]
2002 330d Sport  [0.00]
2004 330d Sport  [0.00]
Most people do not understand the diferent properties of petrol and diesel fuels and try to use petrol tuning techniques on diesel engines. Think of a petrol engine as a pump, the more air it can consume the more power it will make. You can make it consume more air by either increasing the capacity or increasing its volumetric efficiency. Don't worry about the fuel, it's easy to squirt in as much petrol as required. A diesel engine however is fundamentally different in that although you can increase the amount of air in the cylinder, simply squirting in more fuel only does so much as it is inhibited by its speed of burn and in the worst case the piston will reach the bottom of the stroke with unburnt fuel in the cylinder. This is the reason why diesel engines do not rev as highly as their petrol counterparts.
Combustion chamber design and injection improvements have made the diesel what it is today and have raised the rpms of modern engines, but there will always be the problem of trying to get the fuel to burn quickly enough.
Regards
Chris
Previously: 2007 335D MSport E90 Le Mans Blue, 2004 330D A Sport Silver Grey, 2002 330D A Sport Saphire Black, 2001 320D SE Touring Titanium Silver, 1998 M3 Evo Techno Violet, 1996 328i Sport Montreal Blue, 1994 325i Coupe Red, 1989 325i Sport 2 door Dolphin Grey,1986 325i SE 4 door Lachs
      08-23-2008, 06:09 AM   #21
Dave_3
Dave_3's Avatar
Scotland
652
Drives: G22 M440D
Exactly, if your intake volume is constant, but you vary the temperature you vary the density (which means more mass of oxygen per volume). More oxygen helps the combustion phase, releasing more energy. This is, as I assumed above, if the intake pressure is pretty constant.
In the olden days , I used to skim my cylinder heads to increase the compression to take advantage of this rule. But you hit a limit due to the properties of the fuel (and the drastic reduction in lead in the mid-80s) which meant it was always a balance between ignition advance/pre-detonation (pinking) and more power. The holy grail of the most efficient combustion cycle.
Similary, though conversely with forced compression engines running relatively low compression ratios.
D.
      08-23-2008, 08:12 AM   #22
dxb335d
dxb335d's Avatar
England
949
Drives: 997.2 GT3
So will fitting a larger intercooler to a stock 335d increase BHP? Without altering the map?
997.2 GT3
Reply
