BMW
X1 / X2
BMW X1 (F48) and X2 (F39) Forums General BMW X2 Forum (F39) Exhaust pipe diameter
      07-07-2019, 04:00 PM   #1
Boba1214
Drives: M2 Competition
Hello, does anyone have the exhaust pipe diameter of the X2, both inner and outer.
Thank you
      07-07-2019, 04:18 PM   #2
billnchristy
Drives: 2022 M440xi GC
https://www.realoem.com
Will tell you
      07-07-2019, 05:02 PM   #3
Boba1214
Originally Posted by billnchristy View Post
Thanks for this. I narrowed it down to the pipe but it doesn't say the diameter...
https://www.realoem.com/bmw/enUS/showparts?id=YJ53-USA-06-2018-F39-BMW-X2_28iX&diagId=18_1171
      07-07-2019, 06:09 PM   #4
billnchristy
Which model?
      07-07-2019, 09:03 PM   #5
Boba1214
Which model?
2018 BMW x2 28i.
Looking to remove resonators that's before the mufflers and wanted to see what size pipe to get to replace it.
      07-07-2019, 09:18 PM   #6
billnchristy
https://www.realoem.com/bmw/enUS/sho...diagId=18_1333
Shows clamp from cat and resonator at 70mm and the other side clamp at 75mm
      07-07-2019, 09:26 PM   #7
Boba1214
I see that too but I'm not sure if that's the inner diameter or outer diameter ?
Doesn't seem like 2.75" exhaust pipe is as common as 3" or 2.5" ..
      07-08-2019, 01:47 AM   #8
strripedz
Drives: X2 F39
Hey, I measured the exhaust tip of mine, it measures 90mm outer diameter and 66.7mm inlet.
Not sure if that is what are you looking for.
Im thinking to do either res or muffler delete as well, please keep us posted..
      07-08-2019, 05:11 AM   #9
billnchristy
Clamps should be od.
Remember the pipe will be metric as well so what we are used to doesn’t matter.
I’d be wary of the 75 though, The m35i says 70 all the way.
      07-10-2019, 10:51 AM   #10
xcelir8bmw
xcelir8bmw's Avatar
Drives: 2022 BMW M240ix
http://www.bmwusanews.com/newsrelease.do?id=3302&mid=
xbimmers
