M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Lug bolt torque now 140 Nm
      04-27-2019, 03:56 PM   #1
paradocs98
paradocs98's Avatar
Drives: M2C
Thanks to forum member Tag who posted the online version of the M2C manual, I’ve been dong some reading while waiting for my car to arrive in a couple of months. I noticed that BMW’s recommended wheel lug bolt torque is now 140 Nm (101 lbs-ft). For as long as I can remember, BMW’s recommended lug torque setting has been 120 Nm (88.5 lbs-ft). Not sure when BMW changed this value, but I’m glad I noticed it. Heads up for anyone who’s had past BMWs like me and assumed 120 Nm was still correct.
Past: E46 330Ci, E60 545i, E60 M5, E90 M3
Present: 2020 M2 Competition, 2022 GT3
2PUTT513.50
      04-28-2019, 11:04 AM   #2
wanofakind01
Drives: '17 BMW M2 6MT, '16 BMW X1
Yeh changed a couple years back, had the same reaction as you
      04-30-2019, 08:09 AM   #3
dcmac
dcmac's Avatar
444
Drives: '18 LCI M2
So is this just for the M2C?
I run Apex and OEM rims for my OG M2 and always torque to 88... on the advice of many people more experienced than me!
      04-30-2019, 09:00 AM   #4
nioh_lbbm2
nioh_lbbm2's Avatar
1717
Drives: M2
RTFM guys
      04-30-2019, 09:43 AM   #5
CosmosMpower
CosmosMpower's Avatar
2052
Drives: F87c, GT3, MK7 GTI
I've been doing 100 for years
      04-30-2019, 12:13 PM   #6
eeyang92
Drives: LBB M2 LCI 6MT
Nope, 101 lb-ft.
      04-30-2019, 01:20 PM   #7
tux2005
Drives: 2017 M2
My understanding was that when BMW switched to M14x1.25mm threaded lugs that the torque spec changed. With my 2014 228i the spec was 103lbs/ft (unfortunately not printed in the manual, I think it was in service manuals), my 2017 M2 states 101lbs/ft in the manual. I think all F-series use the M14x1.25mm thread while E-series use M12x1.5mm (exception apparently being E70 X5, they use M14x1.25mm).
The M12x1.5mm has a lower spec, I've worked on a 2000 E39 which is 88lbs/ft and a 1998 E36 which specifies 74 lbs/ft (!!! this seems really low to me so I have usually gone a little higher at 78lbs/ft).
The proper torque spec is going to depend on the thread and materials, with the M14x1.25mm I think you probably want to stay in the 100-105lbs/ft range while M12x1.5mm is 80-90lbs/ft.
      05-03-2019, 01:39 AM   #8
KevM2
KevM2's Avatar
No_Country
725
Drives: 2019 F87 M2C, 2023 G87 M2
BMW M2 Competition  [0.00]
  [0.00]
I've never torqued a lug nut in my life! Always gone by feel. Why is a number different by a few Nm so important?
      05-04-2019, 02:46 AM   #9
chris719
Drives: '08 M Roadster
Judging by the number of shops that tighten them to 9999 ft-lb with an impact gun, I’d say you’re fine exceeding 100 as long as you can get them off and you’ve tightened them in a star pattern and equally. I tighten mine 10% over the spec because my wrench is cheap and rather be a little over than under.
They probably won’t fall off at 80 either, who knows why they changed the spec slightly.
      05-04-2019, 12:50 PM   #10
paradocs98
paradocs98's Avatar
Drives: M2C
This is really interesting--good info; makes sense.
This drives me nuts. I trust shops to know more than I do when it comes to this stuff. It's what they do. I pay them to be the experts and do the right thing. And yet they routinely overtighten or undertighten lugs after doing wheel or brake service. Dealers and independent shops included. I've come home from the dealer with four bolts on one wheel impacted down way too tight, and the fifth bolt on that wheel not even finger tight to the hub. I would try not to worry about it, but lug torque values are set for a reason--if they're too loose, they will move more and more over time and eventually allow wheel movement on the hub, potentially causing a wheel to come off at speed. If they're way too tight, they will stretch the threads, also leading to failure.
Same with tire pressures. I brought my OEM Audi S3 wheels to Mavis Tire the other day to have the winter tires switched back to the stock PZeros in preparation for lease end. When I got home I confirmed pressures before sticking them in the garage. Three tires were at 40ish psi (fine) and one was at 75 psi. You can't make this stuff up.
      05-05-2019, 10:56 AM   #11
Franzino
Franzino's Avatar
Belgium
861
Drives: M2 MY17 / Alpine A110 MY19
On my Z4M and my other BMW's I used 120Nm. On my M2 they advised me to use 130Nm....been using this for two year, 6 trackdays and total of 60.000km driving. Never heard about 140Nm.
      05-05-2019, 04:51 PM   #12
Tano
Tano's Avatar
Hungary
376
Drives: BMW M2
See for yourself in the factory instructions.
      05-05-2019, 05:11 PM   #13
Franzino
Franzino's Avatar
Belgium
861
Thanks
      10-28-2019, 01:33 PM   #14
NEfan508
NEfan508's Avatar
No_Country
2660
Drives: 2019 M2C
Sun Motors in PA recommended 120 nm, they just did this last week on another M2C with the same winter wheel setup 641m staggered setup
They disregard the 140?!?
Maybe the 140 is for the stock wheels?
Confusing
      10-28-2019, 03:54 PM   #15
nioh_lbbm2
nioh_lbbm2's Avatar
1717
Drives: M2
Confusing
More likely they made a mistake. Take into account they have to support lots of different BMW models from many different generations. Mistakes can happen. Can't refute solid text in a manual
      10-28-2019, 05:37 PM   #16
NEfan508
NEfan508's Avatar
No_Country
2660
Drives: 2019 M2C
Confusing
Just called another bmw store, they confirm 140 nm
another store "what ever you want man" lol, seems not to matter much AND these are Bmw service advisor(s) tight'ish is fine ?!?
Btw, never had any vehicle that I needed the lugs torqued to spec until now
or ever cared to confirm the spec on
Edit: simple answer I'm going with 140 nm on my 19 m2
      10-28-2019, 06:01 PM   #17
Caduceus
Australia
342
Drives: 2008 135 (sold), 2017 M2
Several of you have noted it already but it's to do with the diameter of the wheel bolts. Bigger diameter = more torque required. Hence the change from M12 to M14 bolts has lead BMW to a revise their torque specification from 120Nm to 140Nm.
140Nm is actually on the conservative side for what a grade 10.9, M14 bolt is designed to handle. As usual, all this stuff can be found with a quick web search.
[IMG][/IMG]
Realistically, the correct answer is "tight enough not to come undone but not too tight to strip the threads". But being German, they like specifics. Therefore 140Nm it is.
      10-28-2019, 08:11 PM   #18
nioh_lbbm2
nioh_lbbm2's Avatar
1717
Drives: M2
Being German, the correct torque value is actually Gutentight
Conissah1576.00
      10-28-2019, 11:10 PM   #19
nearwater4me
Drives: '22 G82 Base
Those with wheel locks from the dealer, check them if they’re torqued properly.
I noticed all 4 of mine were hand-tightened at best.
Came loose with minimal amount of force.
I re-torqued every bolts to 101 lbs/ft
      10-29-2019, 01:31 PM   #20
CTSean
Drives: LCI BSM MT M2
It's an incredibly picky thing, but 140Nm = 103 ft-lb
https://www.metric-conversions.org/e...oot-pounds.htm
      10-29-2019, 02:04 PM   #21
nearwater4me
Thanks for the correction.
I’m not too worried about it as I tend to go slightly more after the ‘click’
      10-30-2019, 08:45 PM   #22
paradocs98
paradocs98's Avatar
Drives: M2C
[IMG][/IMG]
This is great. Thanks for posting.
m2
