BMW
X1 / X2
BMW X1 (F48) and X2 (F39) Forums General BMW X2 Forum (F39) Largest USB stick that will work in X2?
      03-10-2019, 03:30 AM   #1
satz
Australia
336
Drives: 2019 BMW X3 M40i
Hi all
I'm a fan of using lossless FLAC audio files which take up a lot of storage space, so was wondering what the largest capacity USB memory stick that will work in the X1/X2?
I don't want to try an SSD, as I don't need that much music on board!
Also, have people tried FLAC files to confirm they will play on X1/X2s?
And do album artwork images show up on screen?
cheers
2019 X3 M40i, Sophisto grey, H/K, pano
Previous: 2019 BMW X2 Msport, Mineral Grey, Adaptive Suspension, H/K
Previous: 2009 335i LCI, Bluewater
      03-10-2019, 09:02 AM   #2
dianebrat
Drives: 2019 orange x2 xDrive28i
I've run 128GB with no issues and as long as the files you're copying to it have proper art then it will show.
      03-11-2019, 02:48 AM   #3
satz
Australia
336
Thanks Dianebrat
And FLAC files do work in the X2?
cheers
      03-11-2019, 06:38 AM   #4
dianebrat
Got nothing for you, I run MP3 because in the noisy car environment it doesn't really matter that much IMNSHO.
      03-11-2019, 12:39 PM   #5
mDrive1
Drives: X1
Confirmed. Lossless (flac) files do play flawlessly on my 64Gb memory stick.
Thanks Dianebrat
cheers
      03-12-2019, 02:19 AM   #6
satz
Australia
336
Thanks MDrive! I thought I had tried FLAC files out on the demo vehicle but couldn't 100% recall.
Obviously I don't have my actual X2 yet, as it's making its way downunder and is currently approaching the Panama Canal! On a ship.
I optioned for the Harman Kardon speakers, so hopefully that'll sound good
      03-16-2019, 04:21 PM   #7
Wrawby X2
Drives: BMW X2
I use 128 stick in my X2 and I can confirm it works ok !.
      03-19-2019, 04:54 AM   #8
satz
Australia
336
Do you know if USB3 sticks will work? In fact..is the slot a USB3, or USB2?
And for cover images to appear on the display screen, do they have to be in the same folder as the music tracks?
cheers
      03-19-2019, 06:47 AM   #9
dianebrat
USB3 sticks work fine, the album art needs to either be in the same folder or embedded in the MP3s.
      03-30-2019, 11:04 AM   #10
satz
Australia
336
does the album art have to be 'encoded' with the FLACs
Hi again
just a few more questions about cover art:
To ensure it shows up on screen does it have to be a max size (or does the screen adjust automatically)?
and should it be called cover.jpg or will any .jpg file show up?
and does the image have to be encoded into the files, or can I just download an image off the net and save it into the folder of FLACs?
thank you
      03-31-2019, 04:07 AM   #11
satz
Australia
336
More google research showed this:
"If you already have the artwork files and they all have a consistent name such as "cover.jpg", then you can use Mp3tag. Load up your FLAC files into Mp3tag and highlight them. On the toolbar, click the "Actions (Quick)" button and select "Import cover from file". It's easiest when the artwork is in the same folder as the FLAC files, but not necessary as long as the artwork files are named in a consistent way that ties each artwork file to one set of FLAC files:
If artwork is in same folder as FLAC files, format string is simply cover.jpg (or whatever name you've given the artwork files)
If the artwork files are in another folder, then you have to structure a format string to reach them: e.g. C:\MUSIC\ARTWORK\%album%.jpg
You'll probably need to experiment with this to get it to work right or you can post back more detail on where your artwork files are located and how they are named.
If you don't already have the artwork and need to download it first, then you can try Media Art Aggregator."
So...I guess it's not as simple as just copying the cover image into the same folder as FLACs. Looks like you have to 'tag' them to the files, or is that only if you want a different image for each song?
      03-31-2019, 07:56 AM   #12
dianebrat
Actually in general it is, most player software does look in the album folder for the art, they're talking about referencing art in another separate folder, but honestly just use one of the bazillion art fixer tools and try to use images under 500x500 even if you need to shrink them and then keep note of the ones that don't work, you're overthinking this.
      04-01-2019, 03:35 AM   #13
satz
Australia
336
Thanks Diane... I'm in the strange situation where I'm trying to get all my FLAC folders sorted well before my actual car gets delivered. Reason being that I'm currently working where it's relatively easy to acquire FLACs, but where I normally live (and where my car will be), one cannot get them easily.
cheers
      04-03-2019, 05:51 PM   #14
tonywalk
1addict
tonywalk's Avatar
United Kingdom
Drives: F39 X20d MSportX
Apologies for only spotting this now - you might have the car and already know the answer.
I've got the HK system with the upgraded Nav package.
On mine, I've got a 256GB USB stick and play FLACs. They sound excellent in the X2 - it's a good setup.
Current: F39 X2 M Sport X Galvanic Gold, Automatic
Previous: F22 M235i Melbourne Red, Black Leather, Adaptive Suspension
Previous: F21 M135i Mineral Grey, Coral red leather, Manual, Adaptive suspension
Previous: E82 120d M Sport, Le Mans Blue, Black leather
      04-28-2019, 11:42 PM   #15
CanonEOS
Drives: 2023 330i
I play FLAC on a 32 GB drive, I will probably get a 128 GB drive soon once I upgrade my speakers
xbimmers
