10-14-2020, 04:54 PM | #23 |
Rep 175
A solution
10-14-2020, 07:42 PM | #24 | |
Rep 2,873
10-15-2020, 01:49 AM | #25 | |
Rep 132
6mm PFR5-427: Both: Powerflex seem to acknowledge the issue by stating the following: "PFR5-427 is designed to adjust known ride height issues found on right-hand vehicles by increasing the thickness of the original part to 11.4mm or can be used on each side to increase overall ride height" |
10-15-2020, 04:52 AM | #26 |
msej449
514
Rep 717
Are the photos' taken with you in the car? Or is the car empty? I just wondered if there was a difference: it may be better with the driver inside, or worse obvs. If there isn't a difference (or not much) with a driver inside then you might not be worried and might be changing the suspension unnecessarily. Or if it's worse with a driver inside, then you may need to do something more radical.....
10-15-2020, 09:45 AM | #27 |
3626
Rep 3,594
BMW have a ride height tolerance measurement for a ballasted car, from memory (difficult to look up now NewTIS is offline) it is about 5mm difference side to side and doesn't vary for LHD or RHD cars. Again from memory, ballast is 75kg in the driver seat, 75kg in the passenger seat and 40kg in the boot.
There shouldn't be a RHD or LHD difference due to the ballast requirements for alignment being in both front seats, not just the driver's seat. There is something not straight or adjusted incorrectly somewhere that is preventing the car from not being within the ride height tolerance. Has a full alignment and ride height measurement been done to confirm which measurements are within the BMW spec and which are not? |
10-15-2020, 09:52 AM | #28 |
Rep 736
Drives: Lexus RC F
I just had brand new tires installed and an alignment, there are still minor differences in tire-to-fender gap.
No big deal, has never affected ride quality or tires.
Estoril Blue E36M3
Mineral Grey M235ix/12.02 @ 115 Ultra White Lexus RC F Last edited by KennyFSU; 10-15-2020 at 10:18 AM.. |
10-15-2020, 10:02 AM | #29 |
Rep 5,372
I'm getting the sense that there are some seriously OCD people on these forums.
My 2016 M235 with stock springs in the front and Dinan springs in the rear with lift spacers has a difference almost a 1/4" gap difference on the front axle and right at a 1/4" on the rear axle. My wife's brand new 2020 4runner with stock everything and no weight in it is nearly even in the front and nearly a 3/8" gap difference on the rear axle (it has a coil spring rear axle). My son's 2015 Outback 3.6R has a difference of 1/4" on the front and rear axles. If you've got aftermarket springs or coilovers, the difference could be more severe, especially with coilovers. I've dialed in a number of coilovers over the years have learned this. LOTS of aftermarket coilovers (and springs) can experience pretty significant setting in the first 30 days and that settling can be HIGHLY variable, spring to spring.
Poochie9104.50 |
10-15-2020, 10:57 AM | #30 |
3626
Rep 3,594
Here are all the specs and definitions on how to measure the alignment and ride height with the correct ballast. If any one measurement is out, it is a likely pointer to the source of the problem, but all should be in spec if there isn't anything bent, worn or out of adjustment:
10-20-2020, 05:59 PM | #31 | |
Rep 3,497
Nevertheless, when I step into my garage and approach from the rear I'm still looking at a car that's 3/4" lower in the left. It's enough that for me it's a "What's wrong with the car?" look. Sooner rather than later, I'll do what's necessary to make the look go away. FWIW, this situation arose sometime last year; I first noticed it at the track last October, seeing something that I hadn't seen before.
10-20-2020, 08:12 PM | #32 | |
Rep 74
LOL
2016 M235i xDrive
Dinan Stage 4 Tune (Big turbo, exhaust, intercooler, etc) Dinan lowering springs, bump stops, front and rear sway bars. |
01-25-2022, 09:57 PM | #33 |
Rep 348
Any updates to this?
