01-08-2019, 01:26 PM | #1 |
Rep 961
Drives: OG M2
LCI Adaptive LED Coding-off Sidemarkers
Anyone know the coding to turn off the sidemarkers on the Adaptive LCI LED headlights? Bimmercode isn't working (it thinks that I have normal bulbs installed in their position; even though I have LEDs). Thanks!
01-22-2019, 12:03 PM | #2 |
Rep 961
Drives: OG M2
Bump - anybody know how to do this?
01-22-2019, 04:20 PM | #3 |
Rep 278
In Bimmercode-
Front Electronic Module- Lighting- Sidemarkers-Not Active Also to choose your bulb type and warm/cold monitoring Front Electronic Module- Voltage Monitoring- Sidemarkers Hope this helps |
01-22-2019, 11:29 PM | #4 |
Rep 961
Drives: OG M2
01-23-2019, 07:48 AM | #5 |
Rep 278
I'm no expert but the adaptive LEDs are headlights and have nothing to do with the sidemarkers.
01-23-2019, 02:03 PM | #6 | |
Rep 961
Drives: OG M2
OG M2 with the OEM M mirror retrofit
01-23-2019, 04:16 PM | #7 |
Rep 278
[QUOTE=samsamdar;24280593]Did that coding work for you? Do you have the LCI adaptive lights?
The coding worked for me. The are always off except when using the turn signal. My car is 2018 230i standard LED lights not the adaptive. |
01-23-2019, 04:50 PM | #8 |
Rep 961
Drives: OG M2
[QUOTE=Climate Changer;24281263]I will try the coding tonight - are your side markers separate from your turn signals?
01-23-2019, 05:25 PM | #9 |
Rep 278
I'm getting confused. you mentioned headlights and I thought you were referring to the parking lights to stay off. Which is the turn signal as well.
01-23-2019, 07:53 PM | #10 |
Rep 961
Drives: OG M2
This is the sidemarker for the LCI Adaptive lights - I think your sidemarkers are the same lights as your blinkers.
01-24-2019, 08:10 AM | #11 |
Rep 278
Gotcha. I Thought you were referring to the parking light.
Sorry I did not code that off. You should code the parking lights off. It makes the front look cleaner, no amber. I do have the sidemarker lights as well just BMW LED not adaptive. I didn't know that light strip was the sidemarker |
05-23-2019, 05:43 PM | #12 |
Rep 41
Hello everyone, I recently turned my side markers off and was wondering why my angel lights turn off once I switch the lighting. Anyone know how to enable them back? Thank you it's for a 2013 Activehybrid 3
Lex G
08-15-2023, 03:54 AM | #13 |
Rep 961
Drives: OG M2
Just updating this old thread cuz I finally figured out how to do it in protool lol
In both FLE modules (right and left) change the following: LM_ID_LT04: change from value 02 to value 01 LM04_Name: change from value 02 to value 01 Front sidemarkers are now turned off for the adaptive LED headlights!
