2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications [Mini-HowTo] LED reverse lights (F22, F23, F87)
      12-29-2018, 07:29 AM   #1
///M Houbi
///M Houbi's Avatar
Switzerland
1672
Drives: M2 Competition
Lightbulb
Hello folks
It bugged me that the entire car is using LED lights but the reverse lights are not LED. So I ordered some T20 W21W LED bulbs. Installation is super easy and done in 10 to 15 minutes. I have not found any videos or fotos showing it (probably because it is so easy ) so i thought I make these here for you:
1. Open the plastic covers and unscrew the nuts.
2. Pull the tail light in the direction of the arrow.
3. Remove the plug and take note of the little thing on the bottom. Once you re-install the tail light this white little plugs belongs into a whole on the bottom of the tail light.
4. Remove the original light bulb and replace with the new LED one
5. Test if everything works and the reassemble tail lights in reverse order
For comparison, left is the new LED bulb and right is the original one. Unfortunately the mobile phone has no chance to capture how this looks in real life. It looks much clearer in real life (no glare) and its very nice white.
LED bulb
Original bulb
Rear view (it is not that intense in reality!)
I did not code anything and let them shine for around 10 minutes, i had no errors thrown and also no problems with flickering rear view camera or similar.
Since it only takes a few seconds to code i still did it, change the "Rückfahrscheinwerfer" from Glühbirne to LED to do so.
I used these bulbs:
You can get them here: https://www.aliexpress.com/item/2pcs...3-c8a69f446fa5
Appreciate 11
M2COMP520.50
nioh_lbbm21721.50
AlpsRider2878.50
ggggbmw485.50
m20e30871208.00
WillOs7.00
haagm58821.00
Jcon157319.00
Stylin.M2307.50
      12-29-2018, 07:44 AM   #2
M2COMP
Drives: 2011 X5, 2013 550xi, M2C
Originally Posted by ///M Houbi View Post
Hello folks
It bugged me that the entire car is using LED lights but the reverse lights are not LED. So I ordered some T20 W21W LED bulbs. Installation is super easy and done in 10 to 15 minutes. I have not found any videos or fotos showing it so i thought I make these here for you:
Comparions, left is the new LED bulb and right is the original one. Unfortunately the mobile phone has no chance to capture how this looks in real life. It looks much clearer in real life (no glare) and its very nice white.
New LED bulb
Original bulb
I used these bulbs:
Thanks for taking your time to write this all up.
The pictures from coding are before or after.
Poochie9131.00
      12-29-2018, 07:47 AM   #3
///M Houbi
///M Houbi's Avatar
Switzerland
1672
the pictures from BimmerCode are "after"
M2COMP520.50
      12-31-2018, 02:49 AM   #4
doughboy
doughboy's Avatar
1578
Drives: 2018 M2 Comp 6MT
I never noticed they were not LED... That will bug me now!
      12-31-2018, 04:30 AM   #5
///M Houbi
///M Houbi's Avatar
Switzerland
1672
Then you have something to do now
All the best for 2019!
      01-03-2019, 12:11 PM   #6
MPBK
Everyday I'm shuffling
Drives: '12 SG 135i DCT; '18 MG M2 DCT
Hello folks
Thanks for the DIY.
Do you notice any improvement in brightness when looking through the camera when backing up at night?
      01-03-2019, 12:49 PM   #7
///M Houbi
///M Houbi's Avatar
Switzerland
1672
Hello folks
Thanks for the DIY.
You are welcome!
Yes indeed, it is a very noticeable difference in brightness and clarity. This alone is worth doing it.
      01-04-2019, 11:50 AM   #8
hwntime
hwntime's Avatar
279
Drives: F22 Raptor
Do you happen to know the bulb socket size?
      01-04-2019, 02:13 PM   #9
doughboy
doughboy's Avatar
1578
T20 W21W is the socket type and original wattage.
      01-04-2019, 03:10 PM   #10
hwntime
hwntime's Avatar
279
Drives: F22 Raptor
Thank you, Sir!
      01-04-2019, 03:20 PM   #11
///M Houbi
///M Houbi's Avatar
Switzerland
1672
I have written that in the first sentence of my initial posting. Do i miss something?
      01-04-2019, 03:54 PM   #12
hwntime
hwntime's Avatar
279
Drives: F22 Raptor
Haha I guess I missed it. I went straight to the pics and descriptions.
///M Houbi1672.00
      01-07-2019, 12:55 AM   #13
Rahstyles.Com
Drives: E93 M sport
Is the bulb size only for the competition model or also for the m235?
      01-07-2019, 01:28 AM   #14
///M Houbi
///M Houbi's Avatar
Switzerland
1672
It's for all the zweiers
      01-08-2019, 08:54 PM   #15
Rahstyles.Com
Drives: E93 M sport
What in the world is "zweiers"? Im assuming you mean the size fits all series 2
      01-09-2019, 01:32 AM   #16
doughboy
doughboy's Avatar
1578
If my rusty German serves me, zwei = two, zweiers = twos...
I recall in a lot of EU the BMW models are not called "2 series" they are called 2er, 3er, 4er etc...
Thus 'zweier' (i think)
///M Houbi1672.00
      01-09-2019, 03:12 AM   #17
///M Houbi
///M Houbi's Avatar
Switzerland
1672
exactly this!
      01-11-2019, 12:32 PM   #18
MPBK
I did this upgrade.
It's a big improvement in the looks dept, but I will never see it from the back. And I don't care what others will see during my backups.
I was looking for a functional improvement (backup camera at night). It's a small improvement, but noticeable. This is because of the ridiculously small backup lens that BMW put there. The bulb is pretty bright.
It was easy to do and only $19 from Amazon.
      01-11-2019, 01:06 PM   #19
///M Houbi
///M Houbi's Avatar
Switzerland
1672
I did this upgrade.
Did you use exaclty the same bulb or another one?
I find it a pretty obvious and well worth difference when I back up.
      01-18-2019, 12:56 PM   #20
hwntime
hwntime's Avatar
279
Drives: F22 Raptor
Quick question for those who have done this. I did a quick dry run and tried removing the tail light housing before ordering the bulbs. Both nuts came out and I started wedging it loose but just how hard do you have to tug it to get it out? I was pulling pretty hard from all different angles to no avail.
      01-18-2019, 01:40 PM   #21
MPBK
Not a matter of brute force.
Need to pry it from the top corner of the light (see picture) with a plastic stick or a wrapped screwdriver (to not scratch the paint).
Crap - picture not uploading. You'll figure it out.
hwntime278.50
      01-18-2019, 01:44 PM   #22
hwntime
hwntime's Avatar
279
Drives: F22 Raptor
Need to pry it from the top corner of the light (the corner with the sharpest angle) with a plastic stick or a wrapped screwdriver (to not scratch the paint).
Ok thanks, I'll give it a try this weekend. So there's retaining clips like the interior trim pieces or just a single pry point?
Tags
led reverse light f87 f22 f23
Search this Thread:
