11-09-2018, 07:27 PM | #1 |
Kh Ng
18
Rep 39
Coolant hose exploded
Right after I filled up the gas on my 14 m235i I noticed some white smoke coming off from my front grilles. Popped the hood real quick and found out one of the coolant hoses exploded and there was coolant everywhere . Luckily I was driving it when the hose broke on me. Car has 76k miles. Has this happened to anyone before?
11-09-2018, 08:11 PM | #3 |
Rep 5,372
Yes, a very common failure. It should be high the list of things to replace every 5 years on these cars. Luckily it's only a $40 part and easily replaced in 10 minutes.
https://f30.bimmerpost.com/forums/sh....php?t=1547622
khoanguyen070518.00 Poochie9104.50 |
11-09-2018, 08:55 PM | #4 | |
Rep 218
Assuming it has not yet broken off and the coolant level is fine but you want to do the preventive maintenance. Thanks! |
11-11-2018, 12:31 AM | #5 |
Kh Ng
18
Rep 39
11-11-2018, 12:33 AM | #6 |
Kh Ng
18
Rep 39
I believe that we need to flush the coolant out before changing the hose.
11-14-2018, 09:33 AM | #7 |
Rep 1,931
mine busted last summer. Changed it side of the road, lucklily i was only a $9 uber from bmw parts dept.
www.nybmwcca.org
11-14-2018, 09:34 AM | #8 |
Rep 1,931
no.
www.nybmwcca.org
11-15-2018, 06:28 PM | #9 | |
Rep 823
I pulled these from realoem.com and wonding which one is the problem hose: 03 Coolant hose 17127596831 +core 07 Coolant hose 17127624676 |
11-15-2018, 11:58 PM | #10 |
Kh Ng
18
Rep 39
Part # 17128570061. Local shop called it expansion hose.
11-16-2018, 12:45 AM | #11 | |
Rep 45
11-16-2018, 07:54 AM | #12 |
Rep 1,931
thinking about it, i was probably right around 30-35k miles when it blew cracked right at the connection.
www.nybmwcca.org
11-18-2018, 08:19 PM | #13 | |
Thaumaturge
181
Rep 211
Took 10 minutes start to finish and at $35 from FPCEuro, I won't ever have to buy one again. ///Rich |
11-19-2018, 08:53 AM | #14 |
Rep 1,931
here was mine
www.nybmwcca.org
11-21-2018, 11:25 AM | #16 |
Rep 1,931
yea its simple.
there is a clip on each end you lift up, pull the hose off, put new one on and push down on the clips. Done. Might need a lil flat head to get under it.
www.nybmwcca.org
11-24-2018, 11:07 AM | #17 |
Rep 5,372
These things no doubt will break over time as they become brittle. I do have to wonder about those that have mods like intake and charge pipes that had these break at low mileage on the radiator side. The connection is right in the line of fire when doing these mods and if you're not careful, you could easily compromise the connection when working in the area.
11-25-2018, 09:45 AM | #18 | |
Rep 780
01-17-2019, 06:07 PM | #19 |
Rep 780
12-20-2019, 04:59 PM | #21 |
Rep 533
Sorry for resurrecting an old thread, but my car just had the same hose failure. 2015 m235i, 35K miles.
I swapped in the new hose myself, but I haven't done a coolant flush/bleed. Do I need to? I took it to a couple local independent mechanics to see if they'd flush/bleed it, but neither of them wanted the job. I know that there was air in the line, of course, and after driving it a little yesterday I could hear the air bubbling up in the coolant tank and was still getting low coolant alerts. I let it cool down overnight and added some coolant. I drove it a bit today... no warnings, no bubbling. Am I good to go? Or should I try to find someone who can flush/bleed it? (I don't know how to do that myself}. |
