11-08-2018, 01:48 PM | #1 |
Rep 190,750
Injen B58 Intake ***NEW PRODUCT***
The Injen intake will be released very soon , stay tuned
11-08-2018, 09:05 PM | #2 | |
TXHornX3M340iGuy
129
Rep 258
11-09-2018, 11:58 PM | #4 |
Rep 503
Do you happen to know if it will be usable in California
11-10-2018, 09:36 AM | #5 | |
Rep 190,750
MarkDemma519.00 |
11-18-2018, 10:42 PM | #6 |
Rep 370
No it won't be "Legal for use" in CA. Pretty much nothing is these days.
Hell, even an oil catch can is deemed illegal because it is sold as a Competition Use Only item. http://www.burgertuning.com/emissions_info.html |
11-19-2018, 09:31 AM | #7 | |
Rep 503
11-19-2018, 11:59 PM | #8 | |
Rep 370
1) Have an out of state friend buy for you and then ship to you. Install at your own risk. 2) Remove and replace with stock equipment when you take the car in for smog. May also be a good idea if you take it in for warranty service if for no other reason that they don't deny your warranty issue because they try to tell you it was caused by an aftermarket part. Unless it can be shown that the failure was caused by the aftermarket part, they can't deny warranty, but they may still make life difficult for you. |
12-03-2018, 10:08 AM | #9 |
Rep 181
Drives: 2023 M340xi Portimao Blue
It sure isn't a looker... but more importantly is performance, price, and sound. More options is certainly better, however a little more eye candy would have been welcome.
12-03-2018, 03:36 PM | #10 | ||
Rep 3,496
12-03-2018, 03:46 PM | #11 | |
Rep 823
01-05-2019, 08:33 AM | #12 |
Rep 143
01-05-2019, 03:55 PM | #13 | |
Rep 3,496
What surprises me is that CARB hasn't declared all aftermarket parts to be unacceptable. Call me cynical, but perhaps that would shrink their bureaucracy.
01-06-2019, 03:17 PM | #14 | ||
Rep 503
01-06-2019, 11:41 PM | #15 | |
Rep 3,496
Quite a bit of progress had been made by the late 80s. At that time, CARB dictated that 10% of new cars sold in the state in 2000 would be EVs. They were ahead of their time, but that target should be met within a few years.
MarkDemma519.00 |
03-12-2019, 04:00 PM | #16 |
Rep 190,750
Injen B58 intake officially released
Injen EVOLUTION Cold Air Intake System Part No. EVO1105 2016-2019 BMW 340i/440i (F3X) L6-3.0L(t) B58 Take the ultimate driving experience of your 2016-2019 BMW 340i/440i (F3X) series with the B58 engine to the next level of excitement with Injens EVO1105 Evolution cold air intake system. This intake was designed using the most up-to-date engineering tools and techniques available to produce a top quality kit that has no parallel. The EVO1105 cold air intake system is truly on the next level. From the one-piece sealed housing that utilizes our patent pending Twist-Lock technology to securely attach a massive SuperNano-Web Dry air filter in place all the way down to premium hardware, Injen has put it all on the board to provide you, the consumer, the best intake possible! Roto-molded Housing: The one-piece sealed housing utilizes the all-new Injen Twist-Lock System to securely attach the SuperNano-Web Dry air filter in place which eliminates the use of unnecessary parts and provides one of the simplest installations available. The EVO1105 housing also sports the all-new Injen Clear-View badge for a cleaner more aggressive under hood appearance. Roto-molded Intake Tube: The EVO1105 Evolution Air Intake System uses a custom designed and dyno-tuned, intake tube to produce huge power gains while retaining an OE quality fit. SuperNano-Web Dry Air Filter: Thats massive! is all you will hear about this SuperNano-Web Dry air filter that is included with the EVO1105 cold air intake system. This filter has been uniquely designed to work with the Injen Twist-Lock System. Using our Twist-Lock technology has allowed our engineers to use the largest filter possible for this application, which increases the available air volume - resulting in added power while keeping the installation process quick and simple. Quality Hardware: From the Stainless Steel Band Clamps with an inner protective liner to the reinforced automotive grade silicone coupler, every aspect is covered for a perfect and secure fit. Hassel-Free Installation: Make it easy! The Injen Evolution Air intakes that use our Twist-Lock System have been strategically designed to use fewer parts to provide the end user with one of the quickest and simplest installations available on the market today. Dyno Proven: Clean and simple, NUMBERS talk! Injen has put in the time and diligence to stand behind our performance data. We put in the time to test and prove that we have developed a superior kit for your BMW. So after hours of designing and dyno testing, Injen is proud to say that the EVO1105 Evolution Air Intake system puts down numbers of up to 13 additional horsepower and 18 lb-Ft. of torque. KEY FEATURE Dyno Proven gains of up to 13 hp and 18 ft-lbs. of torque Designed to work with the stock calibration Aggressive intake growl under acceleration Durable Roto-Molded Polyethylene tube and housing Reinforced automotive grade silicone couplers Fully serviceable Injen SuperNano-Web dry air filter Stainless steel band clamps with inner protective liner Aggressive under hood appearance while maintaining an OE fit Our clear inspection badge allows you to quickly check the condition of your air filter while the red stripe enhances under hood appearances. Made in Pomona California, USA Injen Technology Limited Lifetime Warranty This product is not currently CARB exempt and is not available for purchase in California or for use on any vehicle registered with the California Department of Motor Vehicles. Direct Fit for
HP GAINS 13 HP TORQUE GAINS 18 Ft.-Lbs. of Torque BOX SIZE 28" x 17" X 13"
03-13-2019, 11:29 AM | #18 |
Rep 190,750
Im not allowed to post price or share links to my website, i will pm you the price
03-14-2019, 02:40 PM | #19 |
Rep 294
Drives: 2019 M240i Coupe RWD
+13 HP, not bad!
I've been wondering, with all the technology going into modern engines, how could a manufacturer leave 13 HP on the table of something as simple as a less restrictive intake? Either there is some compromise to the Injen intake (cost, serviceability, reliablity) or Injen is full of BS. Or, perhaps more likely, I need some education. Can someone enlighten me? Last edited by MassNerd; 03-14-2019 at 02:46 PM.. |
03-14-2019, 02:43 PM | #20 | |
Rep 190,750
I always wait for independent customer dyno but the logic you are using is invalid. Its like saying the claims made by tuners are BS or dangerous or else BMW would have done it themselves Manufacturers do not offer max performance because they are not building a race car. They are more concerned with cost and MPG
03-14-2019, 02:51 PM | #21 |
Rep 294
Hi Mike, I think my logic is sound and you may have confirmed it. If the intake costs too much and lowers the MPG, then those would be the compromises I was speaking of.
Those are compromises people who tune their cards are OK with. Compromise doesn't equal bad! Maybe I should have phrased my statement as "trade-offs". |
03-14-2019, 02:55 PM | #22 | |
Rep 190,750
