BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Newbie question - tires and wheels
Reply
      06-28-2008, 03:38 PM   #1
que2k
Drives: 335xi Sedan
I havent taken delivery of my E90 yet but I am already shopping for winter tires and wheels.
I have ordered a 335xi with sport kit and on tirerack it tells me that I can use 17" wheels with 225/17/40
My question is what is all the talk about offsets and staggering?? and is tire-rack correct?
Thanks
"Her name is Naomi, that's I moan backwards"
      06-28-2008, 03:51 PM   #2
R12ax7
R12ax7's Avatar
120
Drives: 2021 340xi
2011 328i  [0.00]
I'm sure someone will follow up with far more info than I can give you, but generally, I think the staggering issue is really only relevant for 18" or 19" wheel options. If you have the sport package with the 18" wheels they are a staggered set-up (the rear wheels and tires are wider than the fronts).
For 17"s the set-up is usually non-staggered, or the same width front and back. So with 17" wheels there is no issue, you just put them on, and can rotate them freely.
The offset issue is when people are playing with different widths front and back, particularly with 19" wheels. Depending on what kind of staggered set up you go with you may need to use a spacer (between the mounting point and the actual wheel) in order to maintain the proper track.
The other issue is rolling diameter, which I am fuzzy on myself. Apparantly different width tires (say 265 vs. 275) as well as different manufacturers have different sidewalls so you need to take this into account in order to maintain the overall size of the wheel, otherwise your spedo will be out of whack.
Not sure if that answers your questions but again, none of this is really an issue for selecting 17" winter tires for a non staggered set-up.
(and yes, tirerack is correct)
      06-28-2008, 06:31 PM   #3
Nikolas
Drives: 996 TT
You can stagger 17's also. The setup would be 225/45/17 front and 255/40/17 in the back.
225/45/17's are what my 335xi came with stock. 225/40/17 is the wrong size.
      06-28-2008, 10:14 PM   #4
Kev
Critical Care Anesthesiologist
Kev's Avatar
Hong Kong
481
Drives: SMB F83
Normally, you don't want to go for a staggered setup in the winter. You want to run as narrow tires as possible. In this case, 225/45R17 would be the way to go. As for offsets of the wheels, you also need to consider the width of the wheel that you are buying as well. Gary @ Tirerack would be able to help you choose the best setup for your car.
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist"
      06-28-2008, 10:45 PM   #5
UdubBadger
No_Country
633
Drives: '04 330i ZHP
2004 BMW 330i ZHP  [9.50]
2011 135i  [7.46]
2008 328xi  [8.76]
im one of those idiots using a staggered winter set up.
you have awd... you'll be fine either way.
i would suggest the 225/45's size for winters sidewall is a good thing to have in the snow.
      06-29-2008, 12:52 AM   #6
que2k
Drives: 335xi Sedan
Thanks guys, also I copied down the tirerack information incorrectly. It was 225/45/17
      06-29-2008, 09:43 AM   #7
Kev
Kev's Avatar
Hong Kong
481
Drives: SMB F83
Hey, you are not alone. I'm looking forward to running M6 reps or Style 230 in the winter as well......
      06-29-2008, 10:00 AM   #8
UdubBadger
No_Country
633
2011 135i  [7.46]
2008 328xi  [8.76]
hahaha you're crazy dude
at least mine are only 17's
      06-29-2008, 11:01 AM   #9
Kev
Kev's Avatar
Hong Kong
481
Drives: SMB F83
Need to clear BBK, so not much choice out there. 18s will be really tight.
      06-29-2008, 11:27 AM   #10
jimmy330xi
jimmy330xi's Avatar
Puerto Rico
57
Drives: '06 330xI, '04 YZF R1
Is it possible to find a good winter tire that will fit the style 162 wheel?
'06 330Xi, '04 CBR600RR, '04 YZF-R1, '06CBR600RR, '10 S1000RR
M-tech, Injen, Hamann, Remus, KW, Breyton
      06-29-2008, 11:50 AM   #11
UdubBadger
No_Country
633
2011 135i  [7.46]
2008 328xi  [8.76]
check out Bridgestone Blizzak LM-25's for your 162's Jimmy... they are dedicated winters.
If you want good all seasons for winter (since you've got an xi) you can look at Goodyear Eagle F1 A/S which seem to do well in the snow.
I'm personally going to run staggered Conti Extreme Contacts on 17's. I don't know if they make them for 18's though.
      06-29-2008, 02:41 PM   #12
Kev
Kev's Avatar
Hong Kong
481
Drives: SMB F83
Bridgestone Blizzak LM-25, Dunlop Wintersport M3 / 3D, Conti, Pirelli all make winter tires that would fit your 162s
      06-29-2008, 02:44 PM   #13
jimmy330xi
jimmy330xi's Avatar
Puerto Rico
57
^ Thank you guys. I found them, I was very unfamiliar with winter tires.
      06-29-2008, 03:10 PM   #14
Kev
Kev's Avatar
Hong Kong
481
Drives: SMB F83
No problem. We all have to start some where, right? I started about 10 years ago when I moved my ass from Hong Kong to Wisconsin, quickly learned the essentials of winter tires.
      06-29-2008, 06:41 PM   #15
Nikolas
Drives: 996 TT
The whole narrow tire concept for snow only applies to driving in fresh snow. If you live in snow country, most of the time you are driving on packed snow. For packed snow you do want as much traction as possible. A wider snow tire in that case will work better than a narrow one. The concept in fresh snow is a narrow tire will not plow and build-up snow in front of the tire. So don't worrow about running a staggered set in the winter. You will be fine.
      06-29-2008, 07:25 PM   #16
UdubBadger
No_Country
633
2011 135i  [7.46]
2008 328xi  [8.76]
cool... i'm sure i'll be fine anyway, xi works like a dream
      06-29-2008, 09:41 PM   #17
halB
halB's Avatar
Drives: W211 E350 4M MkV GTI 987.2 S
Don't run a staggered set in an Xi unless you can make the F/R tire circumference within 1% of each other. Failing that you risk burning out your transfer case clutch pack becasue of the F/R axle speed difference.
07 E93 335i - Returned at lease end
09 W211 E350 4Matic Avant Garde - Blk/Blk, AMG pkg w/18". Sport Susp. F1 Asym. Debadged.
09 MkV GTI w/Leather & 18" Huffs. F1 Asym
10 987.2 S w/Leather sport seat, Sport Chrono, 19" Carrera S II wheels
      06-29-2008, 09:54 PM   #18
UdubBadger
No_Country
633
2011 135i  [7.46]
2008 328xi  [8.76]
winters are the 17" sport package wheels so if BMW uses them, i'm sure its fine.
however, the 19's im running for summer are staggered too so... that might be more than 1%
      06-29-2008, 10:01 PM   #19
UdubBadger
No_Country
633
2011 135i  [7.46]
2008 328xi  [8.76]
just figured it out... 19's difference is .86% so im good with the 235/35/19/ 265/30/19 setup
      06-29-2008, 10:36 PM   #20
Nikolas
Drives: 996 TT
That is why I went with 275/30 in the back. It is the identical diameter to the front at 235/35. Similar to the 17" set I quoted earlier - 225/45/17 front and 255/40/17 rear.
      06-29-2008, 10:44 PM   #21
UdubBadger
No_Country
633
2011 135i  [7.46]
2008 328xi  [8.76]
ahhhh i see
      06-30-2008, 03:10 AM   #22
jimmy330xi
jimmy330xi's Avatar
Puerto Rico
57
The snow tires that I want are for my OEM 162 wheels. I am getting the same sizes as the summer OEM RFT's. I don't think I will have any issues
Reply
