BMW
X1 / X2
BMW X1 (F48) and X2 (F39) Forums General BMW X2 Forum (F39) X2 tow hook license plate mount
      07-29-2018, 09:14 AM   #1
JermieX6
Drives: 2009 X6 50i, 2011 550xi
Just picked up my X2!! Does anyone know which tow hook mount I can use?
      07-31-2018, 06:59 AM   #2
E90 87ss
E90 87ss's Avatar
37
Drives: !
US mill works has one. I didn't bother this time, because the dealer already drilled my bumper.
Had a tough time removing it for lease turn in though. You tighten the license plate bracket to the tow hook piece, so you can then tighten the tow hook piece. When removing the setup, the frame wouldn't grip the tow hook section leading me to tighten and strip the allen key bolts, but it still did not grip. A flat section on tow hook piece would have been great.
Anyway, I had to use channel locks to get a grip and remove the tow hook piece (no rust) section, also I had to use witchcraft to remove the stripped allen key bolts.
In other words if its permanent its fine, never moved in three years.
      08-13-2018, 04:56 PM   #3
E90 87ss
E90 87ss's Avatar
37
Drives: !
So I ended just buying a P12S bolt from US Mill Works and using my old 235i setup...
      08-13-2018, 05:48 PM   #4
bimmerdriver2
bimmerdriver2's Avatar
180
Drives: 2020 M2C DCT
Your license plate bracket looks like a provocation for someone to back into and bend.
xbimmers
