BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > How to get better handling? Using non-staggered setup?
Reply
      06-15-2008, 11:55 AM   #1
jgalaxy
Gearing
jgalaxy's Avatar
Drives: E46 M3, F22 M240
I've been horsing around trying to get a more neutral feel to the cars handling. It plows into corners, barely holding the road going into the turn and then with little gas the rear would break loose.
I have 19" rims. 9" up front and 10.5" at the rear on Goodyear F1s on KWv3s. Does anyone have a sense if going to non-staggered would bring the car back some neutral handling characteristics?
If at first you don't succeed ...
      06-19-2008, 12:55 AM   #2
kwakr738
e21 respect
kwakr738's Avatar
Drives: 2008 335xi Coupe
2008 335xi  [0.00]
I know that Dinan in the past has used not-staggered set up to create more neutral handling cars. I am unsure the physics behind it, but the theory is the larger the rear, the more it will push the front tires.
      06-19-2008, 06:35 AM   #3
Lassaxi
Lassaxi's Avatar
Drives: April ED - E90 328xi
Non-staggered rims should help with the initial understeer.
May 3, '07European Delivery, Redelivered on 6/11/07 - Monaco Blue/Beige, Steptronic, ZPP, ZCW, PDC, iDrive/Navi with RTTI, Logic 7, Xenons, HD Radio
      06-19-2008, 01:37 PM   #4
Nikolas
Drives: 996 TT
A larger front sway bar would help with understeer. Also adding some additional negative camber in your front end would help. Some might tell you that the rear sway bar needs to be larger, but that actually does not have as big an effect as the front. Increasing the FSB helps maintain the dynamic camber on the front axle allowing for a more solid contact patch on the tire through the turn.
I don't know of any aftermarket bars though.
Reply
