Any 6MT owners going to mod their clutch slave cylinder to remove the CDV? |
05-14-2018, 12:32 PM | #1 |
Rep 5,372
It looks no one has seen this yet. The 3/4 series crowd has found the clutch delay valve (CDV) in the clutch slave cylinder and they have started modifying it. Basically they're just drilling out the CDV orifice to improve flow/reduce the delay. Looks simple. I'm probably going to buy a new slave ($70) and modify it.
http://f30.bimmerpost.com/forums/sho....php?t=1486773
05-14-2018, 01:48 PM | #2 |
Rep 2,214
Interested on the outcome, might be a worthwhile mod. I can say without a doubt, though, that the diff bushings have made a significant improvement to the MT clutch engagement and disengagement. I don't have any gripes about how the clutch releases, anymore. I feel like the drivetrain movement was most of the "lag" that I was feeling before. Could be a placebo since I feel a lot more of everything, now, but if this turns out to work, for the price I might as well try it, too.
05-14-2018, 05:10 PM | #4 | |
NewFinishColumbia/detailer
604
Rep 2,096
05-15-2018, 01:23 PM | #5 |
Rep 2,214
SteveInfante604.00 |
05-15-2018, 03:10 PM | #6 |
604
Rep 2,096
Thanks.
Dylan861330.00 |
08-12-2018, 02:13 PM | #7 |
Rep 18
Sorry to revive an old thread, but I did the mod yesterday. Getting air out of the line gave me the most issues even with reverse filling and vacuuming from the top.
The results however are well worth it, makes this gear box much more enjoyable especially in the lower gears. For some reason I thought the brake system was separate from the clutch and just shared the same reservoir, but somehow I got air in the brake line so the pedal felt lousy for a bit then came back. Im a bit confused by this. |
08-12-2018, 05:57 PM | #8 | |
Rep 5,372
08-14-2018, 04:00 AM | #10 |
Rep 105
Yes please! More details would be great!
2015 M235i 6MT | Alpine White/Black Dakota | MPerformance Body Kit | 19" M-Sport 359s w/Pilot Sport 4S (r:255/30 f:225/35)
BMS JB4 w/Bluetooth| Wagner Competition IC | Wagner DP | Evolution Raceworks IC Pipes | Dynan CAI | BMS Catch-Can | Active Autowerks Axle-Back | ECS 2-Piece Rotors/Hawk HPS 5.0 Pads | Full MP Carbon/Alcantara Trim | M-Performance Alcantara/LED Steering Wheel |
01-26-2019, 08:07 AM | #12 | |
Rep 130
Thanks.
[FONT="Arial"] M235i 6 speed, MGM. Wavetrac LSD with altered final drive ratio, MPE, MPK Airbox, side skirts, diffuser, Dinan springs, LCAs.
01-26-2019, 08:25 AM | #13 |
Rep 187
I did the CDV mod in both of my Z3's. It certainly made a positive difference. The CDV valve is just a restriction and doing the mod just means drilling the hole bigger, or replacing the valve with a length of "not restricted" tube. In my case I ordered a modified DCV (drilled) and swapped it with the original. The user control of the clutch engagement is much enhanced for fast shifting. If you're shifting slowly there's no particular effect. The purpose of the CDV to just to protect the system from someone who is shifting "too fast" and not coordinating the clutch/throttle properly by enforcing "slow" due to the restricted opening. In other words, avoiding warranty repairs from inexperienced manual transmission users by not letting them hurt the tranny at the expense of reduced control for those who DO know how to shift.
01-27-2019, 08:55 PM | #14 | |
Rep 66
Drives: 2018 M240i
01-27-2019, 09:28 PM | #15 |
Rep 187
I can't believe it, but I remembered the name: https://www.zeckhausen.com/catalog/index.php?cPath=6562
01-27-2019, 10:24 PM | #16 | |
3626
Rep 3,594
01-28-2019, 06:27 AM | #17 | |
Rep 3,497
01-31-2019, 07:42 AM | #18 | |
Rep 130
Many improvements were mentioned in the forums doing the CDV delete. I like all of them. Just wonder how many make a noticeable difference. If it is only affecting fast shifting it wouldn't be so interesting to me. Quotes from the f30 thread: - You can feel a difference in driving immediately, i used to hate the 1st to 2nd shift, but it transitions so smoothly now. - Clutch pedel feels less resistance towards the end of its travel. - Grabs harder and downshifts are more precise too. - Understand that the CDV delays clutch engagement by limited the flow of fluid. Without it you now have complete control of the clutch. - Thank you! For figuring this out. Made an account just to say so. The clutch was just about my only gripe with my f32. Now it is worlds better. The car will lug around in low gears and when on the highway will over take quicker. First gear takes off like a Normal car without the hesitation of the clutch delay.To those debating the outcomes. If you intended to drive the car with any type of gusto(like you should be) then do it. Don't let this pedal instill bad habits. Downshifts are now possible and she kicks out better than ever. - Hell yea! Glad you did the mod. I love my car a lot better now. It also makes for a much easier driving experience. - This really is different .. downshifts in particular have been amazing, every time. Can't even feel it. This is a nice gearbox all of a sudden. - Along with a perfectly responsive clutch pedal and no more unnecessary slippage, you get a lot more feedback through the clutch pedal. I also have the clutch pedal return spring removed from my car so the pedal is very firm and I can feel everything that's going on. I think I finally understand why the CDV is there, it does improve smoothness by filtering out some of what the fluid could be telling you through your foot but I am much, much happier this way. If you like your clutch pedal to be as soft and smooth as possible, you'll probably be happier with the CDV left alone. - For sure the best thing I've done to the car. I notice the downshifts are super quick and smooth, less noticeable change on the upshifts for me, but for sure improved. Not positive: - Ok, I only asked because people talked about it being a must mod on the e46 m3 and I did it on mine after about a year of driving it with the cdv in tact and noticed like no difference whatsoever. I think sometimes with this stuff people sort of hype it up like it is something super noticeable when it really isn't and just get the ol placebo effect.
Dylan861330.00 |
01-31-2019, 10:02 AM | #19 |
3626
Rep 3,594
With the F22 the CDV isn't very aggressive, I haven't had the clutch pedal not follow my foot in a fast shift yet (although I don't depress the clutch all the way down in most shifts, just enough for the gear lever to move easily through the gate).
On our 2016 Golf R the CDV was much more aggressive than on any of the BMWs I have owned (removed the CDV on E46 and E85). With a fast shift on the Golf the pedal would lag and come up and hit my foot on release, accompanied by the smell of burning clutch if I fed in throttle too fast. Here is a picture of how small the approximately 1mm diameter orifice was before I removed the restrictor plate on that car: |
04-07-2019, 09:45 PM | #20 |
Rep 2,387
Hi, I'm one of the people who modified the CDV referred to in the F30 thread linked above (2016 340xi). I actually went back in later and completely removed the restrictor and rubber bushing inside the slave cylinder. I should have done it from the get go. The restrictor is not needed and even if you enlarge the hole in it, there's still material in the way of the fluid. There was an even better clutch response after I removed the parts. That's the way to go.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
06-16-2019, 07:44 PM | #21 |
Rep 28
Hi all, I just did a write-up on removing the CDV from my M2:
https://f87.bimmerpost.com/forums/sh....php?t=1625114 This was one of the threads I referenced before diving in, so hopefully I'm returning the favor for someone. Last edited by wellvrsd; 06-16-2019 at 07:55 PM.. Reason: Better Link |
Dylan861330.00 |
