BMW 3-Series (E90 E92) Forum
Stumbling on hard acceleration and black smoke
05-01-2018, 02:06 PM | #1 |
Rep 103
2011 e90 with 95k miles - several times recently when accelerating hard the car "stumbles", rpms drop and I see a cloud of black smoke in my rear view mirror. This has happened 3 or 4 times. This typically happens when the engine is up to normal temperature for awhile, parked for 15-30 minutes with the engine off (going into a store for instance), restarted and out on the road. Upon restart and getting back on the road the stumble/smoke happens. Any help would be greatly appreciated.
05-01-2018, 02:07 PM | #2 | |
Rep 3,884
Drives: 330i, 135i
05-01-2018, 02:11 PM | #3 | |
Rep 103
No codes either...just checked. 7E8: Engine and 7EC which I believe are just part of the "reading". Last edited by Arby1028; 05-01-2018 at 02:19 PM.. |
05-01-2018, 04:28 PM | #4 |
Rep 26
N54? with that mileage, has it ever had the intake valves walnut blasted? Injectors/plugs/coils changed? Does it have a tuner? A lot of things could be happening here. A little black smoke at the start of some spirited driving isn't really abnormal, but if it hesitates then you might have a fuel delivery issue (like HPFP), need a bit of maintenance (plugs, coils, maybe injectors, maybe a walnut blast). Mine did something similar a little while after the JB4. I replaced the spark plugs, pulled the injectors and wound up replacing all 6, and did a walnut blast; it wound up feeling like an entirely different car.
Edit - thought about it some more - maybe you have an injector leaking while the car is sitting that is resulting in fuel accumulation in the cylinder - excess is burned off when you crank and presented as your black smoke. Same malfunctioning injector(s) might be causing the "stumbling" you describe but the misfire might not be a long enough duration to throw a CEL. Last edited by robprater; 05-01-2018 at 04:34 PM.. |
05-02-2018, 06:45 AM | #5 |
Rep 952
Sounds like a leaking or bad injector. Black smoke is always a fuel air ratio that has too much fuel. Way too much fuel.
bone stock
GoRomeo984.50 Big Mexican Women101.50 |
05-05-2018, 07:28 AM | #6 | |
Rep 103
Thank you - I'll check the injectors and HPFP. |
05-05-2018, 09:09 AM | #7 |
Rep 26
Mine threw codes as well after I installed the JB4, especially when driving rather aggressively. Any weakness in the fuel or ignition are readily identified when you push it a little harder - that's the exact reason I did the injectors and the walnut blast. Typically if your hpfp is weak, injectors/coils/plugs need to be addressed, etc... the tuner will bring them to light (at least it did for me). Addressing the plugs and injectors on my car solved the issue of the CEL with the tuner on. I'm willing to bet it's something similar.
05-05-2018, 09:16 PM | #8 | |
Rep 103
05-06-2018, 02:23 AM | #9 |
Rep 59
check for vacuum leaks boost solenoid to wastgate accutator. only time i have seen black smoke out of my car was couple years ago when i changed all vacuum hose and left one disconnected..
05-06-2018, 06:27 AM | #10 |
Rep 103
Thanks - I haven't touched any vacuum hoses but that doesn't mean one hasn't come loose or is leaking.
05-06-2018, 08:21 AM | #11 | |
Rep 26
There are some good DIY's posted if you are like me and prefer to read about everything in triplicate before diving in.
--2007 e90 335i sedan, BMS DCI, JB4, Stuffs. Sloooooooow
06-11-2018, 06:05 AM | #12 | |
Rep 103
(Still having the stumble/black smoke issue) |
06-11-2018, 06:56 AM | #13 |
Rep 343
06-11-2018, 11:14 AM | #14 |
Rep 103
07-08-2018, 03:49 AM | #15 |
Rep 103
Took it to the dealer several weeks ago and they did a full diagnostic. Injectors not leaking, no vacuum leaks, etc. Basically they couldn't find anything except I needed a total of 8 software/firmware updates. I had asked my regular service adviser multiple times (definitely more than 4) when in for other maintenance/oil changes if I had the latest software. Each and every time he said "yes". I very politely complained about this and they waived the diagnostic visit charges (shocker I know!).
On Friday, July 6th I took it in for the software/firmware updates. I haven't driven it very hard since then but plan to this week and will report results. |
07-10-2018, 06:28 AM | #16 | |
Rep 2,203
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
