04-21-2018, 07:01 PM | #1 |
Rep 41
Fabspeed Sport Cat Fitment Issue
So I posted about the label on my Fabspeed sport cat that said it was for the M2 (F87) even though I ordered it for an M235 (F22). Two people mentioned that theirs had the same label but it fit fine on their M235's. I just tried to install the new DP and I can't seem to get the bracket to line up. It's at least a half inch off and the angle seems to be a little off as well. I tried to show this in the picture but it's difficult to tell.
Am I doing something wrong on my end? Can you just manhandle this thing into place? A big problem is that I just don't have much room to move under my car so it's difficult to get my arms in place. Has anyone else had fitment issues with these? I currently have the stock cat off and the front of my car on jack stands in the garage. I'm not far from just putting the stock DP on and taking it to a shop as frustration is really kicking in. Any help will be greatly appreciated! EDIT: Alright, I'm pretty sure I just got a bad part... or the fitment for the M2 and M235 are different? I removed the O2 sensors so that I could move the Sport Cat around freely and try to align it, and it looks as though it is just not built to spec. First I aligned the mounting bracket (picture 2) and you can see when that is aligned, the large opening that connects to the turbo is significantly misaligned (picture 3). Then in pictures 3 and 4, you can see how the bracket is misaligned when I align the sport cat openings with the turbo and exhaust pipe. So I can't seem to align the sport cat with the openings and the bracket simultaneously. It seems as though if I were able to bend the welded bracket downwards it might line up, but I don't want to mangle it with pliers. Looks like I'll have to reach out to Fabspeed on Monday to see if I can exchange or something. Overall, with all of the amazing reviews for Fabspeed and specifically this sport cat, I have to say this was a very disappointing experience and wasted most of my Saturday. Last edited by stevemg9; 04-21-2018 at 07:43 PM.. Reason: More Pictures |
04-21-2018, 10:47 PM | #2 |
Luxury at the redline :)
9105
Rep 7,563
I was looking to get one also but reading the reviews, such as yours, got me wary.. check out the link below also...
CEL after Fabspeed sport cat install https://f87.bimmerpost.com/forums/sh....php?t=1487955 |
04-22-2018, 09:46 AM | #4 |
Rep 5,372
Looks like the angle of the FS DP bracket was welded incorrectly. I'd just bend it with two sets of channel locks and then report your displeasure to FS.
04-22-2018, 10:48 AM | #5 |
Rep 2,214
That DP definitely looks shorter than your OEM unit. I'm sure they'll get it sorted out for you.
04-22-2018, 11:31 AM | #6 | |||
Rep 41
http://www.2addicts.com/forums/showthread.php?t=1488475 Quote:
Something is definitely off. I just wish I didn’t have to spend hours under my car to realize it. But that’s the plan, I’ll report back once I get a hold of Fabspeed. |
04-22-2018, 11:39 AM | #7 |
Rep 5,577
Could it be, or it seems the fab cat is used in more then one models engine compartment configuration so there is some simple modifications that need to be made.
U probably need to heat the bracket a bit in order to reshape. But u know their should be directions indicating all these things if in fact this is the correct cat. Last edited by overcoil; 04-22-2018 at 07:00 PM.. |
04-22-2018, 12:52 PM | #8 |
Rep 41
Also I noticed that the mounting bracket on the stock DP has a nut welded to it while the Fabspeed DP does not. Can anyone who has installed this before chime in - did you just use the nut from the other stock mounting bracket that is not replicated on the fabspeed DP? I tried to show what I mean in the picture.
04-22-2018, 02:35 PM | #9 | |
Rep 304
Sorry to hear you're having issues with fitment. I would contact Fabspeed right away and wouldn't bother trying to force it if you can't. The DP is expensive as it is and shouldn't have any fitment issues for starters. CEL coming on will most likely involve improper installation. I know various people running it and have zero issues. |
04-23-2018, 04:51 PM | #10 |
1006
Rep 1,653
Phil from Fabspeed here.
Please do not force/bend/heat or change the sport cat in any way. We have sent hundreds of these out and not had an issue. Please give us a call we will figure this out and figure out how to get this on your vehicle. We have fixed the CEL from the other post and will have no problem helping you out. |
04-23-2018, 07:37 PM | #11 | |
Rep 151
04-23-2018, 08:56 PM | #12 | ||
Rep 41
04-26-2018, 02:30 PM | #13 |
Rep 62
04-26-2018, 05:19 PM | #14 |
Rep 190,807
05-08-2018, 12:49 PM | #15 |
Rep 41
-------------------Issue Resolution--------------------------
So I wanted to update this thread based on my experience. I reached out to FabSpeed, and after some back and fourth, I was advised to attempt the install again. I was told that the mounting bracket is welded on in such a way so that the Sport Cat is able to fit both the RWD/AWD and Coupe/Convertible variants. I was told by the guys at FabSpeed to clamp the DP in place at the turbo and exhaust and then try to bend the bracket into place. Now, in order to do this again, I knew for sure I was not going to attempt this in my garage on jack stands. Not enough room to work under the car, and you really need an extra set of hands. Plus, I knew that I was going to have to mess around with the Sport Cat just to get it to fit right. So after getting some ridiculous quotes from local shops for an install, I found a DIY garage that allows you to rent a bay with lift. They also have just about every tool you can imagine. For those of you that live in Southeast MI, check out My Mechanics Place in Livonia. The prices are super reasonable, the guys that work there are really nice and extremely helpful, and overall I had a great experience. So if you want to DIY and don't want to deal with crawling under your car, check this place out. Working under a lift makes life so much better. I was able to get the Sport Cat clamped on to the back of the turbo, and clamped on to the exhaust pipe at the other end. Just as I expected, the mounting bracket was about 1.5" from where it needed to be. Now, the first time, when I was laying under my car, I was frustrated and attempting to use the bracket to hold the Sport Cat in place while I tried to get the clamps tight - but the DP was not lining up when I put a bolt through the brackets. This is where the extra set of hands really helps. One of the guys that worked at the DIY garage came out and held the Sport Cat in place while I pinched the V-Channel Clamp with some channel locks. From here I was able to get the second clamp (DP->exhaust pipe) on pretty easily. The first three images show how the mounting bracket was misaligned. In these images, the Sport Cat is is clamped in place at both ends. Honestly with both of the clamps on, I was contemplating just not even trying to bolt the bracket on the DP to the bracket on the transmission. It seemed as though the clamps were holding it in place nicely. But then I figured I'd just try to bend it in place like the guys at Fabspeed said to do. This was a no-go. I could not bend that bracket even with huge pliers. My solution was to use a nut/bolt and impact wrench to squeeze them together. I found a 3 inch bolt and matching nut, slid the bolt through the holes on both mounting brackets, started the nut on one end then held it with pliers and cranked the hell out of the bolt with an impact wrench. It worked and bent both brackets together. Once the brackets were bent close enough, I removed the 3 inch bolt and replaced it with a more reasonably sized one. In the last two pictures you can see the final result. You can clearly see the bend in the bracket welded to the Sport Cat. The bracket attached to the transmission bent significantly as well. The only thing that worries me is that with both of those brackets bent, there is a lot of tension. Hopefully it won't cause an issue. Overall, I realized that this just would not have been possible for me to do without a lift and some air tools. The guys at Fabspeed were right, and the part did fit eventually. It was probably my lack of proper facilities and experience, but from what I read (everyone saying "It fit perfectly") and for $1200, I was expecting a direct-fit part, and this was more like direct-fit* *With some bending/manhandling required. So, my experience with FabSpeed was pretty good. They were helpful when I called, but it can be really tough to get a hold of the right person - I played a lot of phone tag. The Sport Cat itself, once it is on, is great. No CEL, noticeable boost in power and sound, improved throttle response. The install for me was a royal pain in the a**, but hey, it was a learning experience. Hopefully this will help others out there that run into issues with that bracket. |
05-08-2018, 01:42 PM | #17 |
Rep 5,372
That's going to break over time plus the gaskets are now under a lot of torque/tension which they weren't designed for. You shouldn't have to bend parts or compromise them to fit the car. Fabspeed should send you a new DP because the one you have wasn't built correctly in the jig. That's BS, IMO, especially for the what they charge and their claims of a high quality product.
05-08-2018, 02:13 PM | #18 | |
Rep 2,214
These have a lifetime quality guarantee, yea?
05-08-2018, 02:23 PM | #19 | ||
Rep 41
I will admit, that ever since I've put it on, I've been driving with the windows down constantly and it always puts a big smile on my face. It's enough of a difference for me to be excited about. I feel like once I get the MPE I'll have the sound I'm looking for. Sport Cat + MPE seems to be really popular around here. Quote:
But yeah, for the amount of money I paid, and general positive reviews for FabSpeed and specifically that Sport Cat - I was expecting a much smoother install. |
Dylan861330.00 |
05-09-2018, 10:20 AM | #20 |
1006
Rep 1,653
Hey Stevemg9,
Glad to see you got everything installed! We’re sorry you had issues with the install, but unfortunately there’s just too many variables for us to diagnose the issue through these pictures. This is one of our most popular items, we sell over 500 a year, and have never had a fitment issue come up that was not resolved with minor troubleshooting. I think it would be irresponsible to assign blame on anything – our bracket, the OEM bracket, the install process, the history of your vehicle, the fitment of other parts of your car – without having the car fully checked out by an experienced technician. The bottom-line is we stand by our products 100% and if it happens to break it would absolutely be covered by our Transferable Limited Lifetime Warranty. We have had multiple technicians look over all of the pictures you have provided and they don’t believe there is a cause for concern at this moment, but if anything should happen, just give us a call and we’ll take care of it. |
Dylan861330.00 |
05-09-2018, 11:16 AM | #21 | |
Rep 151
05-09-2018, 11:31 AM | #22 | |
Rep 5,372
The OEM downpipe fit all the brackets fine. He installed your downpipe and the bracket no longer fit. To claim his car is the issue is total BS. How exactly do you define "experienced technician"? Sounds again like a BS, pass it off on the customer, response. The downpipe setup is incredibly simple on these cars. The fact that the OEM downpipe didn't have this issue and there's clearly no damage or bending of the OEM engine to downpipe bracket is telling that your product is the problem. You should have sent him another one. The company you've subcontracted with to make these DPs has a QA/QC issue with the bracket angle. Simple as that. The fact that you sell hundreds of them is meaningless. I've read of others having fitment issues and they just make it work. For nearly $1,500, we should expect more.
stevemg925.00 nioh_lbbm21716.50 |
