04-20-2018, 09:35 PM | #1 |
Rep 187
Minor Scratches or Scruffs on Rims
Hello,
It seems I have got a few small scratches/scruffs on my rims - they are not too deep (less than 1mm depth), what products/procedures has anyone used to remove these type of scratches? Any input is appreciated. Thanks. |
04-20-2018, 09:58 PM | #2 |
Rep 435
If it goes through the paint/finish nothing can restore/remove it. Some waxes can fill but none can erase. If Klasse AIO doesn't make it go away then you need to find something that can discreetly fill the scratch/gap. Good luck.
04-21-2018, 05:57 AM | #3 | |
Rep 2,067
I just sand the rash area down with wet/dry sandpaper generally starting with 150 grit and then moving up to 220 and finishing with 400 grit for a fairly smooth finish. Paint the sanded area with the right colour touch-up paint (I use the $9.99 Quiktouch B55 for mine - url below). Let dry and apply a layer of clear coat - and Bob's your uncle.. It may not be good enough for the ultra anal retentive amongst us, but it's good enough for me. http://www.quiktouch.com/eng/product...rey-ii&id=1234
2019 X2
04-21-2018, 08:49 AM | #5 |
Rep 7,012
Bavarian Autosport sells a wheel touch-up kit that contains the proper abrasives, filler putty, paint, and clearcoat. Or you can call one of the wheel-repair outfits that can perform the repair with the wheel still mounted.
04-21-2018, 11:49 AM | #7 | |
Rep 1,365
BarryJI427.50 |
04-21-2018, 06:45 PM | #8 |
Rep 980
I avoid kerb rash like the plague (the swiveling passenger-side mirror is very helpful with this when reversing to park). If you do get it, there are services with guys who will come to your car and fill and finish it, charging per wheel.
2015 BMW 228i M Sport w/Track Handling Package DAP | Lighting | Premium | Tech DINANTRONICS Performance Tuner Stage 1 | DINAN Shockware | DINAN Free Flow Exhaust | DINAN Performance Spring Set + Ride Quality and Handling Kit |
04-21-2018, 10:16 PM | #10 |
Rep 1,078
Wow can't believe there is such a thing lol
