BMW 3-Series (E90 E92) Forum
n55 exhaust manifold fit the n54?
03-31-2018, 07:56 PM | #1 |
Rep 125
Was tinkering the idea, what if you fit the n55 exhaust manifold, cut the bottom part and weld a t4 flange and there you go, cheap single turbo setup for the n54?
03-31-2018, 08:33 PM | #2 | |
Rep 1,185
This guy did it with the n54 manifolds. http://www.e90post.com/forums/showthread.php?t=1099289 |
feuer4277.00 |
04-02-2018, 08:32 AM | #4 |
Rep 1,571
Gasket style and spacing between cylinders is the same on the N54/N55 engines, however the bolt pattern is different. Also if you are going to go through all of this hassle and as buster said above, you'd be better off not using the OEM N55 manifold but rather the OEM N54 manifolds for better flow. On this note we have several OEM N54 manifolds cut off, if you are itching to do some fab work on your own kit let us know and we will get you a set of these manifolds for a great price to get started on it.
Rob |
feuer4277.00 |
