BMW 3-Series (E90 E92) Forum
Flutter under acceleration w/ 30FF
03-04-2018, 08:56 PM | #1 |
Rep 12
So I don't think that this is a vacuum leak, and I don't have any logs of this but here is my issue -
-30FF code -Under moderate acceleration, especially after shifting (auto trans), it sounds like there is a flutter, almost like my BOV will let off boost for 1/4 of a second, stop, then do it again. This sound doesn't occur at WOT. -Only able to make about 6lbs of boost at WOT. Boost spikes to 9lbs when shifting, but then gradually falls back down to 6lbs Car has JB4, and this issue seems like it doesn't matter what map I am on. Car is just as fast (or slow in this case) whether I am on map 5, 4, 1, or 0. I have checked all the vacuum lines and they seem fine. When I pull the lines off the vacuum canisters there is a significant woosh. The wastegates have some play but it is not much. It doesn't appear like they are binding when operated by hand, so as of now they do not appear to be the issue. Where should I start for diagnosing this issue? Mods list - JB4 ECS Tuning charge pipe ECS Tuning BOV with original spring that came with it DCIs (issue persists when running w no filter for a test run) Muffler delete Alpina TCU flash |
03-04-2018, 10:55 PM | #2 |
Rep 12
Update - got some logs.
I have absolutely no idea how to analyze these other that it seems like my WGDC is going wild. The first pull was map 5 and includes shifts to show what I was talking about under part throttle, second wone is a WOT 3rd gear pull in map 4. |
03-04-2018, 11:44 PM | #3 |
Rep 906
Drives: 2008 535xi / 2011 Z4 35Is
Whst size vacuum line you have to the BOV?
03-04-2018, 11:57 PM | #4 |
Rep 12
03-05-2018, 03:49 AM | #6 |
Rep 779
Upload CSVs to datazap if you want anyone to look at logs.
You're running 8psi peak (i.e. stock boost) with a target of 16psi. If you bought the JB4 used and didn't start with default settings, start there. Willing to bet dash menu 4 is set wrong though, like 4/4. |
07-21-2022, 04:30 PM | #7 |
Rep 6
Did you ever find the problem? Have I b very similar issues, replaced all vac lines and adjusted wg arms, still sounds like it happens by my BOV thinking that's what it is
