02-05-2018, 07:20 PM | #1 |
Rep 48
Questions regarding aftermarket exhaust
After digging around the forums for the last 2 weeks, I am finding a bit of mixed information on putting on an aftermarket exhaust. I am curious if someone could confirm my understanding:
-To put on any exhaust designed for the 235 to a 228 requires a change to the rear valence -Attaching a 235 exhaust to a 228 will require some custom fabrication as the diameter of the pipes is different where they join. If those are correct, I have a few questions: -If my 228i has the M sport package, will all 235 valences fit (there are 2?) -Does the 228 have a valve control for the stock exhaust or is that only for the 235? -Where does the diameter change? I assume the cats are different and to go to the 235 piping would mean changing everything or have someone fabricate a sleeve to work with 235 mid sections? Does the SuperSprint race for the 2.8 drone? Which exhausts do not drone? What about the M Sport? Also considering akropovich and eisenmann (had one on my E46 and loved it). Thanks in advance! I'm trying to summarize a few different threads I have read. |
02-06-2018, 04:47 PM | #2 |
Rep 194,563
I dont know about supersprint but REMUS and Active Autowerke both do not drone
02-07-2018, 04:42 PM | #3 | |
Rep 555
-Yes -It should line up just fine, if you just use the muffler, should be pretty stander connect and clamp. -If you have the Msport package on the 228, the rear diffuser should be able to pop right in, as it is essentially the same rear bumper. -Yes you have a valve for your exhaust as well, it blocks off one of the tips basically. Here is a thread on this very subject: http://www.2addicts.com/forums/showt...=992564&page=2
02-11-2018, 12:33 AM | #4 | |
Rep 48
Am I better off changing to a m235 aftermarket midpipe as well while I do this? How does it mate to the stock cats which I do not want to change (e.g., bolt on, size reducing sleeve)? |
02-11-2018, 01:15 PM | #5 | |
Rep 194,563
Catback will always sound better than axle back specially if you are keeping stock cats
02-11-2018, 03:31 PM | #6 |
Rep 48
What is involved to make the 235i mid pipe work with the 228 cats? Is this something I can order parts for or do I need to go to a shop and have them do it? While I am a very good DIYer (e.g., engine swap, full suspension, etc.) I'm not a fabricator (cannot weld).
02-11-2018, 04:40 PM | #7 | |
Rep 194,563
03-08-2018, 10:36 AM | #8 | |
Rep 5
I put a fabspeed muffler bypass exhaust on my 228. Any 235 diffuser will work. The cars are the same dimensions. Any custom exhaust shop can hook you up. |
