07-16-2017, 06:14 PM | #1 |
Rep 314
Low coolant warning
While driving home from work, my low coolant warning came on in my M240xi. After it cooled down, I filled it up with about 24oz of coolant before it was back up to the proper level. With only 11,000 miles, this seems like a bit much. I know I'll lose some water, even though it's a closed system, but this has me a little worried. Anyone else have similar issues? Going to have it check d out this week.
07-16-2017, 06:49 PM | #2 | |
Newer 2er
296
Rep 474
Drives: 2017 M240i (Sold)
2017 BMW M240i (Sold)
2021 F-150 Raptor 2017 Porsche 718 Cayman S 2017 Audi Q5 |
07-17-2017, 07:10 AM | #3 | ||
Rep 314
Should I fill it back up with 1:1 still, or would 1:2 coolant to water be better since its losing water and that would help to keep it 1:1 through the summer? |
07-18-2017, 03:57 PM | #5 |
Rep 23
My 230xi had the same issue, I ended up adding coolant twice. After the second instance it was due for the 10k mi service, when I took it in they replaced the water pump under warranty.
Keep an eye out. |
07-18-2017, 07:47 PM | #6 | |
Newer 2er
296
Rep 474
07-20-2017, 07:05 PM | #7 | ||
Rep 314
07-23-2017, 10:25 AM | #8 |
Rep 671
I don't have this problem, but I've always added distilled water only when I've had this happen in other vehicles. I figure it's water evaporating, so that's what I add back in.
'20 240ix convertible
07-25-2017, 01:04 PM | #9 |
Rep 194,596
Probably water evaporating, that being said check for leaks
07-27-2017, 08:19 PM | #10 |
Kingslayer
412
Rep 1,481
Generally coolant to water ratio is 50:50. as neither straight coolant or water handles the job of dissipating heat very on their own. The correct mix can operate under pressure at temps well beyond the boiling point of plain water.
A couple of things to note here the system is pressurized and does allow for expansion and contraction within the system. This is the reason why you should check the level in the reservoir when it's cold. Also air can become trapped in the system and is vented through the release valve which is generally built into the reservoir cap. With a new car a lot of times air is inadvertently trapped in the system during assembly. The air eventually works its way out which in turn drops the level of the coolant. Check out the B58 forum the same thing has plagued quite a few cars.
Previous Cars: 2008' 135i, 2010' 328i, 2013' 328i, 2016' M235i, 2017' X1, 2019' M240i, 2019' X3, 2021' M3 Comp, 23' Camaro SS 1LE, 24' Lexus IS500 Current Cars: 23' Tesla Model Y Performance, 11' BMW 335I. Coming Soon: 25' BMW M2 Manual |
05-12-2018, 10:53 AM | #11 |
Rep 11
Coolant issues
Took my M240i in for a coolant warning at approx 6 months/2500 miles. They blamed it on the cool weather. Well now it's in the 100's in Texas, and the warning started coming up again. Dealer said they topped it off and ran a pressure test... and sent me home with a jug of coolant. Said that was all they could do. How is this acceptable for a $53k car?
05-12-2018, 12:17 PM | #12 | |
Rep 5,582
05-12-2018, 02:34 PM | #13 |
Rep 5,478
True but that doesn't explain why many B58 owners are having to top off routinely, well after a few months ownership.
05-12-2018, 08:39 PM | #14 | |
Rep 67
05-12-2018, 09:00 PM | #15 |
Rep 16
05-12-2018, 11:22 PM | #16 | |
Rep 5,478
Some B58 owners have had their turbos replaced because BMW said the coolant was leaking into the turbo turbine and being consumed. The B58's air to water intercooler, which is built into the intake manifold, is much like the S55's in the M3 and M4 and I've seen pictures of coolant leaking from the M3/M4 air to water incooler into the intake runners. That scary. Perhaps something similar is happening on the B58? I'm not trying to be alarmist but BMW's history with coolant systems it amusingly terrible. |
amw896585.50 |
05-13-2018, 05:56 PM | #17 | ||
Rep 67
05-14-2018, 12:19 AM | #18 | |
Rep 400
It's most likely under filled from factory. My coolant bottle was empty after about 8000 miles. Dealer filled it back up and the coolant level is not going down since. Of course, it's still a problem if their factory fill is not well controlled. But it's way better than leaking from somewhere. Check the level every 2~3k miles after you (or dealer) topped it up. If the coolant level still goes down, that's the time to worry. |
05-14-2018, 06:32 AM | #19 |
Rep 67
Seems like it might be time for a poll. I read where Wards Automotive named the B58 as their top engine for 2017 so I would hope much of the mystery coolant loss is due to low fills at the factory. But it would be nice to get fresh feedback from B58 owners across all the different series of BMW's. Maybe something for the general board rather than just here on the 2 Series?
05-14-2018, 06:34 AM | #20 | ||
Rep 67
05-14-2018, 09:02 AM | #21 |
Rep 400
After top off, I drove about 4000 miles.
Coolant level did not go down at all. (I checked every 1000 miles or so) If it was steadily consuming/leaking coolant, it should be half way down in the bottle by now. So, I'm not worry too much about it. Granted, there are more things to break in this cooling system. (2 separate cooling circuits, 3 coolant pumps, so many heat exchangers...) Yet, I don't see many complaints about turbo or engine issues regarding the cooling system. There are some, but not a lot. That tells me if there is any cooling related issues, it is most likely manufacturing quality issues, not the fundamental design issue. |
05-14-2018, 09:52 AM | #22 | |
Rep 3,611
Exceptions aside, BMW has a long history of significant issues with each model. I learned this almost 40 years ago with my E12 5 Series, which developed a warped head. That was a $2K repair, back when that was real money. Seems everyone but me knew that an E12 head would warp right around 60K - the shop I used knew it, and the used car dealer I eventually sold the car to certainly knew it. That car had an electrical issue that cost me $2K, too. For perspective, the car cost me $11K with 8K on it. Having been introduced to BMW "quality", my next purchase was an M6. Go figure. |
